Culito 11010101
Joined: December 07, 2006 Posts: 5863 Location: Columbia Missourah
Posted: Sun Jun 17, 2018 8:48 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Hey guys, could I get a tire size suggestion?
64 bus
straight axle rear, thing drums, stock 15" bus wheels
flipped spindle front, stock beam, stock 15" wheels
I'd like to find the largest tire I could squeeze under the front and rear without too much rubbing.
Bonus points if I could get the front and rear sizes to match. I had bookmarked a 205/65/15 for both but that seems pretty big.
Thanks!! _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20233 Location: Sandpoint, ID
Posted: Sun Jun 17, 2018 8:59 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
The 205/65 will likely rub the spring plate with stock bus 15's. 195/65 will clear just fine. They will also work up front with your setup, but may rub with a full load up front on large bumps and big sweeping turns. _________________ nothing |
Culito 11010101
Posted: Mon Jun 18, 2018 10:10 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
cdennisg wrote: |
The 205/65 will likely rub the spring plate with stock bus 15's. 195/65 will clear just fine. They will also work up front with your setup, but may rub with a full load up front on large bumps and big sweeping turns. |
Cool. I did forget to mention that it is a 68 bug trans with long axle / long spline, if that matters. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Jun 18, 2018 10:27 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I've run a 185/60/15 on a stock bus wheel up front, and it rubbed a little too much for my liking (height wise). I have since swapped those out for a 175/ 55/ 15 Continental Smart car tire up front. My bus is on BRM's now...but it was the same way when I had the Stock bus wheels on it.
I run a 195/ 60/ 15 on the rear. Corey is right, I think a 205 on a bus wheel would rub the spring plates. I had the same 195's on Bus wheels, and they were really close to the plates. |
Posted: Mon Jun 18, 2018 4:13 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
My old 65 Riviera had 195/60's up front, and 205/65's out back but I had the wheel centers moved inward 3/4" in the hoops to give springplate clearance.
Here's the stance. Flipped spindles and 68 beetle trans, long/long axles, modified axle tubes and spring plates. Not offset spring plates, just notched.
Culito 11010101
Posted: Mon Jun 18, 2018 6:35 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
That's pretty sweet, and what I was going after. I don't really like the "rubber band" look. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Posted: Mon Jun 18, 2018 7:12 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Culito wrote: |
That's pretty sweet, and what I was going after. I don't really like the "rubber band" look. |
That is exactly what I was trying to avoid, and it worked. I like the tire to fill the wheel well, and the bus to still be driveable on everyday roads. _________________ nothing |
73sparks Samba Member
Posted: Fri Aug 31, 2018 10:01 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
evening guys, having a bit h of time with my rear tranny set up on my bus
bought offset springplates with a 67 type1 on my 1960 bus.
when I went to put tires on they press against spring plate and toe in bigtime.
wide five guy arron,I think. says to use spacers,I cant see this making all the much of a difference.
any ideas.
type241 Samba Member
Joined: June 02, 2006 Posts: 971 Location: MOSES LAKE, WA
Posted: Fri Aug 31, 2018 10:35 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Option #1: Thing Brakes
https://www.thesamba.com/vw/classifieds/detail.php?id=341707
Option #2: 4 lug brakes & 4-5 bolt adapter/spacer
Option #3: what you have now with a spacer
I have done #1 and #2 |
Posted: Sat Sep 01, 2018 4:25 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Option #2 is the most common and least expensive. Another option is 4 lug type 3 brakes with a 4-5 lug adapter. The advantage is having larger braking surface, too. You can also do 5 lug type 3 drums, but they can be pricey. _________________ nothing |
Posted: Sat Sep 01, 2018 5:17 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
so I am going with option 3 spacer, my question is what length lug nut
do I use with spacer. |
Posted: Sat Sep 01, 2018 5:24 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
73sparks wrote: |
Can't tell if you are using lug bolts or studs with lug nuts, as your photo is blurry. If you go the spacer route, you may need to install studs and use lug nuts to hold the wheel (not sure if extra length lug bolts are available). Length of stud will be determined by the thickness of the spacer. _________________ nothing |
kombi kid Samba Member
Posted: Sun Sep 16, 2018 7:20 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
before: bone stock 1962 kombi
after: vintage warehouse 4" beam, flipped spindles, old speed spring adapters, 1968 wide axle, 185's front/145's rear of 5.5 BRM's, black KYB's all the way around, stock height steering box with a skid plate from boat yard!
_________________ check out my cool VW videos on my YouTube channel
https://www.youtube.com/channel/UCTrPaygs5pLPPfqNQ8yZ4VQ
I asked god for my first VW, I know he doesn't work that way so I stole a bug and asked for forgiveness!
my "car guy 401k"
1963 kombi (now running and driving
1956 oval sad to see it go!
1966 ghia coupe
1963 bug (sold at prado)
1968 porsche 912
1964 super stock dodge factory light weight 426cu 425hp |
VWcollector1 Samba Member
Posted: Wed Mar 06, 2019 4:27 pm Post subject: can someone help with correct cable size for e brake |
Anyone got the correct cable lengths to use with lowered straight axle kit for e brake handle on splitty? _________________ VW Collector1
San Jose, CA
Wanted: VW dealership items: giveaways, advertising pieces, literature, postcards, business cards, photos, signage, books, badges, pins, coins, pens, lighters, keychains, etc. |
Posted: Wed Mar 06, 2019 4:29 pm Post subject: Re: can someone help with correct cable size for e brake |
vwnut_98 wrote: |
Anyone got the correct cable lengths to use with lowered straight axle kit for e brake handle on splitty? |
What year bus and what year trans/brakes? _________________ nothing |
Posted: Wed Mar 06, 2019 4:31 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
1961 crew cab. Installed a Benco freeway flyer tranny and used a bug straight axle and type III brakes. _________________ VW Collector1
San Jose, CA
Posted: Wed Mar 06, 2019 9:24 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
There is a specific thread about this exact situation. I cannot seem to find it. I will keep looking, but if anyone else knows what I am talking about, please jump in.
You may need to do some custom work with your cables. The answer is out there. I have done a big nut trans in a 57 bus and used buggy style brake cable shortening adapters with good results. Your situation is similar. _________________ nothing |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Thu Mar 07, 2019 7:30 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
'64-'67 cables and cable spacers.
'61 was the transition year.... If you're cable mounts on the handle are under the cab floor, you'll need to shorten the cables. If they are in the cab, no change in cable length should be required. _________________ Aaron D. Badertscher
Click here for ALL my links. |
Posted: Thu Mar 07, 2019 10:39 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Thanks all for your help on this issue. The cables are under the bus and come up through the floor. I purchased the right cables, but they came up short. So you are saying to get '64-'67 cables with spacers? Any idea where I can buy those?
Thanks,
Brendan _________________ VW Collector1
San Jose, CA
german_metal Samba Member
Joined: April 15, 2003 Posts: 411 Location: Mile High Wolfsburg
Posted: Tue Mar 12, 2019 12:06 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Hi-
Does anyone have a recommendation regarding tire sidewall strength and size for the rear? I have a lowered '59 camper that the PO put bug axles on so there's plenty of clearance to the body with the wide 5, 5.5 rim, but the tires seem like they are not strong enough on the sides for the weight. I searched but I'm not coming up with anything for lowered camper and tire ratings for sidewall strength.
Thanks in advance! |
