mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Mar 12, 2019 12:19 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
the weight of the bus does not change when it is lowered. you will need to find a tire that matches the original tires as far as load index goes. Don't put tires for a 3000 pound subcompact car on a bus that can way 4400 pounds. _________________ regards
Uli
german_metal Samba Member
Joined: April 15, 2003 Posts: 411 Location: Mile High Wolfsburg
Posted: Tue Mar 12, 2019 12:27 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Thanks, I realize the weight doesn't change when lowering. I'm looking for recommendations on tire sizes, a brand, and that has strong enough sidewalls for a lowered bus that needs to handle the kind of weight that a camper has compared to say a single cab (when empty). I don't think a stock height bus with those rated tires will fit on my lowered bus.
Thanks! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Tue Mar 12, 2019 5:20 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
german_metal wrote: |
Hi-
Does anyone have a recommendation regarding tire sidewall strength and size for the rear? I have a lowered '59 camper that the PO put bug axles on so there's plenty of clearance to the body with the wide 5, 5.5 rim, but the tires seem like they are not strong enough on the sides for the weight. I searched but I'm not coming up with anything for lowered camper and tire ratings for sidewall strength.
Thanks in advance! |
There is a bunch of info about this in the tire threads, but the basic breakdown is this: You will not find a reinforced or C or D rated sidewall in low profile tire sizes. Trucks/vans that require those tires don't use those tire sizes.
The good thing is that by design, a low profile tire like that used for you lowered bus, already has a stiff sidewall. 50-55-60 series tires tend to be fairly stiff if they are a sports car oriented design. Stay away from cheap tires for a basic honda civic. _________________ nothing |
Posted: Tue Mar 12, 2019 7:13 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
cdennisg wrote: |
Hi-
The good thing is that by design, a low profile tire like that used for you lowered bus, already has a stiff sidewall. 50-55-60 series tires tend to be fairly stiff if they are a sports car oriented design. Stay away from cheap tires for a basic honda civic. |
Thank you very much cdennisg for the information. I, for some reason, couldn’t find that. I have 60’s on there now but they appear to be cheap ones. I’ll look for sone better quality tires of the same size. Any vendor recommendations? |
Posted: Tue Mar 12, 2019 10:56 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
cdennisg wrote: |
Hi-
I like Cooper tires. I have run Michelin and Bridgestone with good results, too. _________________ nothing |
Posted: Wed Mar 13, 2019 10:59 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Thanks! |
i think you missed what i was trying to say.... the load index of a say 185/14c tire that would be stock replacement for a Split or bay bus in germany has a load index of 102. A passenger tire may have a load index of 88 or so. The closer you can get to a load index of 102 the better the tire will handle the weight of a loaded bus _________________ regards
Uli
Filipke Samba Member
Posted: Mon Apr 15, 2019 3:27 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Does anyone have recomandations on tire sizes?
I have 5x205 original 14inch wheels. 5j
Irs with type 3 drums at the back with adjustable spring plates
In the front dropped spindels with adjustable beam. (No steeringbox adjustments)
Painted my wheels in the bottom original color of my bus (mousse Grey)
And i would like to instal white walls so still need to have Some space for these...
Thanks for the info.
I was thinking 195/65/14 back
165/55/14 front... |
Posted: Mon Apr 15, 2019 9:03 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
You are probably in the ballpark with the sizes listed, but I'm pretty sure you will not find those in white walls. _________________ nothing |
Posted: Mon Apr 15, 2019 1:20 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I al gonna place white walls by atlas.
Also did this in my bug wheels and i am very happy with the result...
see picture my bug wheels on the bus...
Posted: Mon Apr 15, 2019 1:29 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
AKA Port-A-Walls. _________________ nothing |
brokevwguy Samba Member
Joined: November 03, 2012 Posts: 269 Location: Upstate New York
Posted: Sat Apr 27, 2019 1:44 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
any opinions on these. I'm only using flipped spindles and an adjustable spring plate. I do not know what is a good shock to use and was given these as an option. Just want to know before I order these. thanks.
https://www.amazon.com/Empi-Coil-Over-Shocks-Front...&psc=1 _________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
Posted: Sat Jul 20, 2019 9:34 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I have finished the final iteration of my suspension, mostly just tuning left.
Front suspension specs: wheels O.Z Fittipaldi 8.5” x 17”,tires 235/40/17
928S4 upper and lower arms, spindles, Brembo calipers, Rabbit rack&pinion
Bilstein coil-overs 700# springs, 1.25” hollow splined sway bar .188” wall.
Rear suspension specs: wheels O.Z. Fittipaldi 9”x17”, tires 255/40/17
944S2 torsion housing, stock torsion springs, early offset 944 aluminum arms, S2 Brembo calipers. 1.5 ratio rocker arms connecting to Bilstein coil-overs 600# springs, 16mm 944S2 sway bar.
_________________ Porsche powered mid-engine double cab build
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
wardvwracer Samba Member
Joined: July 19, 2002 Posts: 489 Location: De Pere, WI
Posted: Tue Aug 06, 2019 4:38 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I'm looking to have a pair of stock 15" bus rims widened to 6", but I'm having trouble finding a place to do it. I am being told that finding a source for the right size "cans" (the actual rim part) is the problem. They aren't out there any longer.
The VW center is an odd size and today's suppliers for the rim part (the "can") don't manufacture them anymore.
Anyone out there have a source?
Can anyone confirm that these rims are no longer being made?
Years back I used a place out in Fontana CA that did up a pair of smoothie's for me at 6", but I can't find the place (out of business). _________________ David Ward
ACME Berrien Buggy Street/Strip racer build
1963 Single Cab
1969 Beetle Convertible
63 11-Window Kombi Bus
Cornpanzers |
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Tue Aug 06, 2019 6:04 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I think W.W. (Wolfsburg West) re pops those rims. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Tue Aug 06, 2019 6:14 pm Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
Busted-bolt wrote: |
I think W.W. (Wolfsburg West) re pops those rims. |
He is looking for someone to widen a stock rim, not just to buy stock rims.
I have heard of wheel shops adding a strip of metal into the hoop to widen them, that way the whole hoop needn't be replaced. Not sure if anyone still does that. _________________ nothing |
samotorsport Samba Member
Joined: December 04, 2013 Posts: 199 Location: Luxembourg
Posted: Mon Dec 23, 2019 9:56 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
So here is my split.
Flipped spindles stock beam , running on 165/50/15 on 5,5 x 15 ET (offset) , but it drives like sh&%t like this , alignment is spot on .
Therefore I will switch over to 4,5 x 15 ET25 with different tires on
Was thinking about 165/60/15 but not sure if it wont rub inside the arches as I don't run a narrowed beam.
Anybody has a similar setup and can give me some advise ?
Thanks in advance
Sam
_________________ 1958 Dragster 1835cc Topchop
1962 Split Panelvan Camper
1967 Herbie the love Bug
1970 Karmann Ghia 14 |
Stephbong Samba Member
Joined: January 11, 2010 Posts: 167 Location: Brussels
Posted: Tue Dec 24, 2019 3:14 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
I've 165/65 on 5.5 front with og beam dropped spindles adjustable if needed and no rubbing at all |
Posted: Tue Dec 24, 2019 3:37 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
What offset do you run ?
What do you mean with adjustable ? _________________ 1958 Dragster 1835cc Topchop
Posted: Mon Dec 30, 2019 3:24 am Post subject: Re: Specs. of tire, wheel, and suspension - Lowered Buses |
By adjustable I mean "with an adjuster" in the middle of the beam so I can play with the height a little bit if needed.
I don't know the offset right now, but it's sprintstars 5.205 |
