busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Feb 28, 2007 7:34 pm Post subject: Source for flat Westy pop top seal ?? |
Anyone know of a supplier for the OG style flat seal across the top of the roof on a westy? My searching has come up empty. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
atmellovw Samba Member
Joined: September 05, 2006 Posts: 1652 Location: Minnesota
Posted: Wed Feb 28, 2007 8:13 pm Post subject: |
Did you try West Coast Metric? _________________ 1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex |
Posted: Wed Feb 28, 2007 11:11 pm Post subject: |
No, that is the one place I forgot to check.
Anyone seen their product? Close to stock and not the universal round bead stuff ?? How about the side pop top seal ? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Birdibus Samba Member
Joined: January 30, 2006 Posts: 933 Location: Inland SoCal
Posted: Thu Mar 01, 2007 1:03 am Post subject: |
I know of two suppliers, GoWesty and the Bus Depot _________________ `
'74 Westfalia Yosemite Yellow
'71 Bus Niagra blue and white |
Posted: Thu Mar 01, 2007 10:28 am Post subject: |
The bus depot stuff looks wrong. I'm sure it works but I'm looking for an equivalent to the glue on OG. Can't see the profile in gowesty's photo, anybody used it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
kim57 Samba Member
Joined: October 09, 2006 Posts: 5 Location: SOGGY DEVON
Posted: Thu Mar 01, 2007 2:53 pm Post subject: |
This is my photo of the GoWesty seals I bought for my '74 Westy. The instruction call for using glue on the top flat piece, but I didn't use it. The seal seems secure as is.
_________________ `
aircedar Samba Member
Posted: Thu Mar 01, 2007 3:02 pm Post subject: |
The Bus Depot poptop seals are far superior -- and much closer to stock -- than the GoWesty ones. In fact, the GoWesty flat seal is /ugly/. |
vwbusbusvw Banned
Joined: December 07, 2005 Posts: 1337 Location: San Diego
Posted: Thu Mar 01, 2007 3:07 pm Post subject: |
aircedar wrote: |
Ugly? That's a weird thing to say. Jackass. _________________ 1994 Dodge Neon w/supercharged 1500dp
OMVWC
Quote: |
stuped is stuped duse |
Posted: Thu Mar 01, 2007 3:13 pm Post subject: |
I prefer the luggage rack seal offered by busdepot, but I'm content with the GoWesty flat seal. The squared off part flattens out when you attach it to the top and helps hold it on. The photo shows the seals untrimmed and still rolled up, so there is some tape glue you can see. That cleaned up nicely. _________________ `
Posted: Fri Mar 02, 2007 1:27 am Post subject: |
vwbusbusvw wrote: |
aircedar wrote: |
Ugly? That's a weird thing to say. Jackass. |
Well. Considering the point is both form and function... I found their seal to be. Frankly. Ugly. Wasn't a personal attack, just a thoughtful observation from someone who happens to be familiar with both versions. |
Posted: Fri Mar 02, 2007 11:12 am Post subject: |
Thanks everyone,
I've got function now in the form of the seal busdeopt sold a few years ago (middle one in photo).
What I'm after is original appearance, gowesty's looks close, anybody have a pic of WCM's? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Busdepot Samba Member
Posted: Tue Mar 06, 2007 10:40 pm Post subject: |
busdaddy wrote: |
Thanks everyone,
What I'm after is original appearance, gowesty's looks close, anybody have a pic of WCM's? |
If it is supposed to be the flat seal that goes between the poptop and luggage rack, and it looks like the middle one in the above photo, you didn't get it from us (or you ordered the wrong seal). That is a poptop seal, and although many other vendors sell it to replace the flat seal, we don't.
GoWesty has a pretty good flat seal (pictured on the right). But theirs requires gluing, whereas ours looks similar but has an impregnated aluminum clip so it grips tightly without glue.
There are other differences between our seals and everyone else's. The others sell the same seal for both the poptop and luggage rack, and we don't. (Notice that in the picture of the GoWesty set, two of the three seals are identical.) In our case, all three seals are different, each specifically suited for its purpose. Our luggage rack seal lacks the insulation bulb (as did the original), because such a bulb can block rainwater drainage and cause rust and debris accumulation under your luggage rack. (Look at your luggage rack. It has holes in the bottom for rainwater to go through and exit into the rain gutters. If you obstruct the edges of the luggage rack with a big insulation bulb, how will the rainwater get into the rain gutters?) Also, our seals have a smoother finish that more closely matches the original German seals - not a pebbled finish like the ones that everyone else sells.
Poptop seals were the Bus Depot's very first product, a decade ago. I designed them myself, because I'd tried the other seals on my own Bus and found all of them lacking in both functionality and stock look. A decade later, our seals still look AND work closer to stock then any other product on the market. Each seal is specialized for its purpose, as with the original design. But since they require no glue for installation, and don't rust, they're actually better than stock. (Do I sound like a proud parent? ) _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
Posted: Wed Mar 07, 2007 11:22 am Post subject: |
Wow, thanks Ron,
I'm sorry, I didn't intend to mislead anyone.
I thought I got it from you but now I'm not so sure. (may have been a deal in the bargain bin).
I'm very happy with the round bead seal and will no doubt end up with some of your flat stuff as well unless I find an exact duplicate of the OG stuff. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 07, 2007 11:41 am Post subject: |
No apology necessary; I just wanted to set the record straight to avoid any confusion about what we sell. As for the original German flat seal, you will not find one by itself, as it never existed as a separate part from VW. It came connected to the 3-sided poptop seal, so you had to buy an entire poptop seal to get that section. When last available (not sure if available anymore; nobody's asked) the poptop seal was about $600 (!!!!!) from Volkswagen ... and since it used steel rather than aluminum clips, it would soon start to rust out and sag, leaving you right back where you started (but $600 poorer). This is one of those rather rare cases where OE German isn't even worth seeking. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
billbeemer Samba Member
Joined: March 10, 2005 Posts: 169 Location: Los Angeles, CA 90016
Posted: Sat Jun 02, 2007 3:04 pm Post subject: |
A slightly related question...
I have the opportunity to reset the placement of the rear luggage rack on my 1971 westy, and was curious if busdepot or anyone else had a suggested distance between the two fiberglass pieces. e.g. should the two pieces completely overlap, partially overlap, or just barely touch? (this is, of course, before the seal is put in place)
PS, I just put in the order for all three seals from busdepot _________________ 1971 Westy "Chester" |
