Zarwerks - johnshenry - [email protected]
Page: Previous  1, 2, 3
Viewing feedback for: johnshenry
Email: [email protected]
Last Visited: Yesterday
56Cabrio
56Cabrio is offline
PostPosted: Mon Feb 26, 2018 2:33 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
Bought a part off John i have been wanting forever,great communication and he shipped it super fast. Thank you John
Dave
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
jcannon
jcannon is offline
PostPosted: Sat Jul 28, 2018 3:48 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
Just bought a complete wiring harness for a split convertible. It's very well made. This one was cloth wires and cloth loom. The ends are all solder dipped or have the correct ring terminals (headlight grounds, battery terminals). Even the positive battery terminal was red cloth. Nice striping and there are instructions which have a guide so you can tell which stripes/colors go with which number on the pod or headlight terminals. If you done wiring with the '52 diagram you will know why that is nice to have. I've done most of it and so far all the wires are the right length. If you have incorrect components they may not play with the harness. That is, I have a square regulator and not the D so the terminal locations are different than what is correct. Also, If you have later headlights with the bulb at the bottom, Keep in mind the harness is made for the period correct bulb holder. What I did is buy euro-terminals from Digikey so I can add a bit of wire where needed to reach my (temporary) incorrect parts. Try part 1-1776293-2-ND. These are similar to the terminal blocks that show up in the wiring by the front fuse box. it is nice the harness includes the misc wires like the ones on the pod.
I'm very happy with the harness and plan to buy another for my '52 split sedan.
ovalchris.54
ovalchris.54 is offline
PostPosted: Tue Oct 30, 2018 4:17 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
Great Seller Great price! Highly recommend John!
A fast nickel is better than a slow dime!
vwsplitman
vwsplitman is offline
PostPosted: Thu Jan 10, 2019 10:23 am    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
Just received a mirror from John. Better than I expected. Nice item, great packaging, easy and flawless transaction. Thanks John.
motofly196
motofly196 is offline
PostPosted: Tue Jun 04, 2019 9:49 am    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
I just had John rebuild (restore) a 56' flasher unit for me. Quality of work is incredible! He even included a new ground wire, replaced a missing set screw, and put on a new screw with nut for bolting it onto the bracket. Thanks John!
Scott
paulsvw
paulsvw is offline
PostPosted: Mon Sep 16, 2019 4:21 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
I got my Split Semaphores back from John, very good restoration job. Defiantly worth the money. Thanks again John!!
vw356
vw356 is offline
PostPosted: Thu Apr 06, 2023 4:16 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
I just received a split beetle dash pod assembly from John and it is VERY nice! Front and back! I will definitely be buying more from John soon!
Thank You John!
Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites..
sgmalt46
sgmalt46 is offline
PostPosted: Sat Jul 22, 2023 6:03 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
bought a set of early heater shoe boxes and 46-47 gas cap. as described.
shipped fast a++ thanks .
Steve. Very Happy
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
esde
esde is offline
PostPosted: Mon Jan 01, 2024 7:05 pm    Post subject: Re: Zarwerks - johnshenry - [email protected] Reply with quote
John helped me out with some generator wiring, which was a giant help. Many thanks and so much appreciated!!
SD
Page 3 of 3
