radrob Samba Member
Posted: Thu Mar 08, 2007 9:33 pm Post subject: 36hp rebuild |
I am rebuilding my 36 hp. Had the crank ,cam and lifters reground.
Had the rods re sized. Getting ready to put the bottom back together.
Other vw rods have a mark to know what side is up. These 36hp rods dont. Dose it matter on a 36 hp? Dose the notched brg go up or down?
This is my first time, I have a friend helping me. He has done a few vw motors back in the day.But not a 36hp.
Thanks in advance.
ROB _________________ when all else fails get a bigger hammer
56 hardtop 64 bus 66 manx
keep on keepin on!!!!!!!!!!! |
john7 Samba Member
Joined: August 06, 2003 Posts: 1542 Location: Garden grove ca
Posted: Thu Mar 08, 2007 10:18 pm Post subject: |
the bearing notch goes down |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Thu Mar 08, 2007 10:47 pm Post subject: |
Are you asking about rod bearings or the rods themselves? The rods have a number stamped into the big end that matches the numbers on the end caps. The numbers should face down when installed on the crank. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
splitjunkie Samba Member
Posted: Fri Mar 09, 2007 7:36 am Post subject: |
I don't think it matters with the 25/36 hp rods. I think they are symmetrical.
The later 1500/1600 and I think 40 hp rods are slightly offset hence the marks so you can install them correctly.
You would need to check a Bentley manual to be sure though.
Chris |
radrob Samba Member
Posted: Sat Mar 24, 2007 11:26 pm Post subject: |
here are a few pics of my progress
[img[https://www.thesamba.com/vw/gallery/pix/339462.jpg/img]
[imghttps://www.thesamba.com/vw/gallery/pix/339462.jpg[img]
[/img] _________________ when all else fails get a bigger hammer
radrob Samba Member
Posted: Sat Mar 24, 2007 11:40 pm Post subject: |
radrob Samba Member
Posted: Sat Mar 24, 2007 11:51 pm Post subject: |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Mar 25, 2007 12:39 am Post subject: |
Looks good so far! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Eric Outland Samba Member
Posted: Wed Mar 28, 2007 5:25 pm Post subject: Eric (VMR) |
Radrob Make sure that your end play is in between .003-.005, and the your deck hieght ( For maximum Preformance is set at .060 !) There is nothing set in stone for deck hieght but the rule of thumb is set it at inbetween 050-.070. so I personally choose the middle I use absolutely NO SHIMS and if I have to take .005 t0 .020 of the piston tops ( have them machined) then so be it. But no shimming under the heads can create leaking in the future. Make sure all galleys are clean no residual rust I noticed that your case looked pretty Red in some area's. other than that have fun and break her in Gently then you can look forward to a long lasting 36er. Eric (VMR) Vintage Motor Restorations |
radrob Samba Member
Posted: Fri Mar 30, 2007 9:29 pm Post subject: |
end play is at .004.
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Fri Mar 30, 2007 9:44 pm Post subject: |
looks nice what year engine is it _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
radrob Samba Member
Posted: Fri Mar 30, 2007 9:54 pm Post subject: |
engine is sept. 55. For my nov.55 56 bug _________________ when all else fails get a bigger hammer
radrob Samba Member
Posted: Tue Apr 10, 2007 7:37 pm Post subject: |
radrob Samba Member
Posted: Tue May 22, 2007 11:04 pm Post subject: |
EXITSTRATEGY Samba Member
Joined: March 27, 2006 Posts: 450 Location: rolling thunder river company, nantahalla gorge. NC
Posted: Wed May 23, 2007 10:07 am Post subject: |
now that's a quality engine. _________________ I'm living down by the river and i don't even have my 'van'... |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
radrob Samba Member
Posted: Wed May 23, 2007 9:38 pm Post subject: |
today was my maiden voyage,now that i have my charging system working.I had the generator rewound for 12volts.
It ran great!I put about 30 miles on it today and plan on driving 50 to 80 miles tomarow.I will fill alot beter after i put a few hundred miles on it.
This was my first rebuild.
Thinking of taking it on a 350 mile round trip next weekend to the show and drags in woodburn Org.
I think the fuel pump should have a hump where this one has the screen. So i need to look for that,and a coil strap with a oval hole?
Anything else? _________________ when all else fails get a bigger hammer
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Wed May 23, 2007 9:47 pm Post subject: |
It would look sweet with a NOS brown distributor cap. _________________
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
joe h. Samba Member
Joined: September 04, 2005 Posts: 782 Location: Seattle, Wa
Posted: Wed May 23, 2007 11:28 pm Post subject: |
Looks good Rob.
How did you clean your case? |
radrob Samba Member
Posted: Thu May 24, 2007 12:42 am Post subject: |
Hi joe it was good seeing you last weekend. I had the case hot tanked at our shop. And painted it with seamore castblast. I looked at the pic's of you vert. very nice job.
