Generator or Alternator?
Page: Previous  1, 2, 3
MRJEL
MRJEL is offline
PostPosted: Sat Oct 13, 2012 8:51 pm    Post subject: Reply with quote
Did the early Kubels (hand cranked) have magneto ignition?
Generator or alternator, you gotta have some sort of power to get things sparking.
Semper_Dad
Semper_Dad is offline
PostPosted: Sat Oct 13, 2012 9:24 pm    Post subject: Reply with quote
The Army's tech manual is in the Technical Archives.
http://www.thesamba.com/vw/archives/manuals/TM_E9_...swagen.pdf
74 VW Thing - WalkŁre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sun Oct 14, 2012 3:03 pm    Post subject: Reply with quote
A magneto is what is required to fire a engine without a battery. It has permanent magnets the will generate enough power to fire and ignition and bring a engine to life.
Just like your push hand crank start lawn mower. No battery, just a magneto.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
BJT
BJT is offline
PostPosted: Tue Oct 23, 2018 10:46 am    Post subject: Re: Generator or Alternator? Reply with quote
So My 74 Thing is relatively new to me, and Iím learning about VWs fast, put in new Thing correct front end and exhaust and other minor stuff so far...
Looks like Iíve got some oil leaking from under the generator stand, to replace those gaskets and deflector, I assume the generator will have to be removed, which from what Iím reading requires removing the engine or dropping it at least to get the shroud off. Has anyone found another way to change the gaskets and deflector without dropping the engine?
kenj06
kenj06 is offline
PostPosted: Tue Oct 23, 2018 5:45 pm    Post subject: Re: Generator or Alternator? Reply with quote
From Page 1
uberautowerks wrote:
Let me give you all a tip that makes getting a generator or alternator out of our VW's, Things and beetles, heck even busses.
Use a 36mm socket and a longish breaker bar to remove the nut holding the fan to the generator. You know the one around the back? Leave the pulley on use a screwdriver to hold the pulley(as you would while changing the belt).
Once the nut is off, and it's washer, you'll have a lot easier time removing the generator and backing plate. Leave the fan in the shroud then reattatch when reinstalling the generator.
With this tip you don't need to remove or move the intake nor do you have to remove the shroud. You may still need to lift the shroud up a bit to get to the bottom two backing plate bolts, but you only need to lift it an inch or so.
I changed out the generator without removing the fan shroud. I think you should be able to get to the gaskets under the stand.
Page 3 of 3
