hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Mar 15, 2007 2:50 pm Post subject: Early Link Pins |
just saw these pop up in the classifieds:
http://www.thesamba.com/vw/classifieds/detail.php?id=430045
so ronnie, what's the story?
how are the bearings caged, metal or plastic?
how is the head of the pin shaped, is it gonna fit under the cap? some of the late kits don't work very well.
how does the quality seem to be?
do the caps have the little edge/lip around the bottom of them to help hold them in the spindle?
how are the shims, are they decent, or are they kinda flimsy?
and now the million dollar question, who's gonna try them first and report on them? it's about time someone started making these.
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Mango Juice Samba Member
Posted: Thu Mar 15, 2007 3:30 pm Post subject: |
Hope they are not like the repro asian safari windows
How about you you try them out Jon!!
I have a stack of front axel beams I could drop off to you for rebuilds |
commercial air Samba Member
Joined: July 19, 2005 Posts: 230 Location: Driving in the crumple zone...Regina, Saskatchewan, Canada
Posted: Thu Mar 15, 2007 6:28 pm Post subject: |
Just got a set a from Concept 1. The bearings are metal caged, pin head seems bang on, caps have the lip, the shims are solid and really nice, the oversized extra bushings are a nice touch, and the quality seems great.
All that being said, I'm sure someone will get them installed before I do and be able to give a better report on the kit. In the box they look good... Going on the bus is the real test.
Chris _________________ Northern United Transporter Society
www.nuts.commercial-air.com |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Thu Mar 15, 2007 9:36 pm Post subject: Re: Early Link Pins |
hazetguy wrote: |
As stated in the thread above
I am installing a set on my DC, 5" dropped spindle disc brake yadda yadda. I have serious dollars in this bus so if they break I'm out a ton of dough and nobody likes to loose money.
They are made in a foreign country, have that smell (the preservative these coat stuff with)
Over-all a decent kit and the king pin bushings in two sizes with shims is an added bonus.
I only have one set left as of the time on the post (they went FAST)
I wil have more and am sure the market place will be fooded with them soon. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Tue Dec 16, 2008 1:50 pm Post subject: |
http://www.bustoration.com/Link-Pin-Kit-Type-2-1955-1963_p_2-849.html
ok Ronnie, or anyone else who has bought, installed, or used this kit, what's the scoop on it?
-are there needle bearings for the link pins? are they metal caged?
-are the heads of the link pins acceptable, or do they make it nearly impossible to get the dust caps on like the brazilian late style link pins do?
-how is the quality?
-how do the races fit in the king pins?
-how thick are the shims (in mm please), and are they nice and crisp or do they have stamping flash on them?
-has anyone used this kit? comments or feedback?
does anyone have better pics of the parts other than the crappy generic looking stock photo in the ad?
thanks for any feedback, i need a couple sets of early link pins, came across that page on Ronnie's site. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
sled Samba Member
Posted: Tue Dec 16, 2008 2:11 pm Post subject: |
I used that exact kit (although not purchased from ronnie) in my 61 kombi and the fitment was perfect.
-yes needle bearings, yes metal caged
-sorry dont know about dust caps, I have dropped spindles
-quality appeared very nice to me, the fitment was excellent
-I will try and measure some left over shims tonight, they are crisp with no flashing or burrs
-feedback? I would buy this kit again.
sorry dont know if that helps your decision _________________ drive your split. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Tue Dec 16, 2008 3:57 pm Post subject: |
hazetguy wrote: |
thanks for any feedback, i need a couple sets of early link pins, came across that page on Ronnie's site. |
I ordered a set from Wolfsburg West last month expecting the worst and was pleasantly surprised. The oversized kingpin bushings had the grease groove already machined in them which was cool. The 12 kingpin seals included did not feel as nice as the ones available seperately from WW. They felt more like rubber rather than the plastic feeling ones WW sells. I figured the plastic ones might work better fighting against grease. I didn't realize these two items were included so that was a bonus. The bearings were needle bearings with metal cages and the quality seemed good. The outter races fit slightly looser than the originals (a very tight slip fit rather than a press fit). I did not measure the shims but the thickness seemed similar to the originals. They were a bit rough and had some flashing on them, and did not sit 100% flat when looking on them at the side......especially when stacked up. I spent a little bit of time cleaning them up to make them usable but I would have preferred good used ones instead. The included grease caps seemed to fit fine....those are always a little tricky to install but I didn't notice them to be any harder than the originals. The adjustment groove machined into the linkpin wasn't perfectly smooth like the original, but it worked fine. They also included a bunch of extra shims (not linkpin shims) to replace the phenolic kingpin washers if needed.....I ended up using a couple to take up some of the slack when setting up the end float on the kingpins. I would have preffered oversized kingpin spacers, but I don't think those are available. |
Posted: Tue Dec 16, 2008 6:17 pm Post subject: |
thanks for the input. i looked at WW, but they only have a pic of the 4 link pins, so i did not think it was the whole kit (then i read the description).
so what they sell is the same as what ronnie has pictured?
glad to hear the quality/parts are acceptable. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Tue Dec 16, 2008 6:20 pm Post subject: |
hazetguy wrote: |
thanks for the input. i looked at WW, but they only have a pic of the 4 link pins, so i did not think it was the whole kit (then i read the description). so what they sell is the same as what ronnie has pictured?
glad to hear the quality/parts are acceptable. |
The kit I received looked identical to the one Ronnie has pictured. It came all neatly packaged in a white cardboard box with no markings that would indicate the country of origin.
Posted: Tue Dec 16, 2008 6:23 pm Post subject: |
thanks again for the info. (my guess is china) _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Culito 11010101
Joined: December 07, 2006 Posts: 5863 Location: Columbia Missourah
Posted: Tue Dec 16, 2008 8:10 pm Post subject: |
So as long as the king pins themselves are not badly scored or pitted, everything else to do both sides is in this kit?
If the king pins are worn a bit, can you dress them up with a file and/or emery cloth?
Just making sure. My king pins are wobbly as hell. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed Mar 11, 2015 9:33 am Post subject: |
Anyone have recent info on which link pins to buy for an early bus? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Wed Mar 11, 2015 11:26 am Post subject: |
I don't know which are the best, but there are some crappy sets out there. I rebuilt a set for a guy and one pin was slightly larger than the other. The shims all had huge burrs on them. I'm sure someone else here as more for you. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Thu Mar 12, 2015 8:39 am Post subject: |
Anybody know where to get the best pins for an early? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
