Posted: Thu May 17, 2018 9:04 pm Post subject: Re: Official "What oil / additives should I use" topic |
norris wrote: |
Wildthings wrote: |
VW says to drive your engine moderately until the oil engine is warm. They define neither "moderate" nor "warm" Nor do they say that they want you to drive moderately because of the oil and not for some other reason such as the metallurgy of the engine. Someone in Alaska might keep his revs below 1/2 of factory red line until his oil is 20°F above the cold cranking temperature for his oil weight and feel he has met VW's requirements, while someone in California following the same instructions might baby his engine at an ambient that is over 100°F hotter.
Personally if I spend the night next to the road at 30°F and pull directly out on the highway when I wake, I will keep the revs below 2500-3000 as I go through the gears and before a mile is behind me an going to be running 65mph, feeling I have fully met VW requirements. I doubt that in 40+ years of driving ACVW I have even once waited until my oil was 212°+ to rev my engine to whatever speed I wanted. In a cold climate ACVW's have enough trouble with moisture building up in the oil so prolonging the "cold start" by warming the engine up more slowly seems counter productive.
I will let others worry about this latest fad of oil not being able to lubricate until it is above 180 or 212°F and will stick with the SAE's concern that cold starting (when the oil is <180°F) is hard on an engine due to moisture buildup in the oil and that one should warm their oil quickly to avoid moisture caused problems. |
I know what moderate and warm is! Wow......how about "common sense" |
And since VW doesn't define them your moderate and warm may well to be different from someone else's, just like your "common sense".
VW advice is:
Quote: |
do not try to warm up the engine by letting it idle with the car stationary... drive off immediately and maintain moderate speed until the engine is warm. |
To me the "cold oil will not lubricate crowd" is denying "common sense". For a 10w** oil the cold pumping temperature is -22°F and the cold cranking temperature is -13°F, so if you are 20°F above that the oil is going to be flowing very well throughout the engine and there is just no call for one to believe the oil isn't getting to everywhere in the engine well enough to give good protection. There is reason to worry that oil below 10°F is picking up a lot of moisture and other contaminates so driving the engine hard enough to warm the oil quickly is common sense. I for one am not going to pull out into traffic and then dawdle at 35 mph max until I think my oil reaches someone else's definition of warm.
https://www.thesamba.com/vw/archives/manuals/oct73bus/page22.jpg
https://wiki.anton-paar.com/en/sae-viscosity-grades/ |
thunderhead289 Samba Member
Posted: Wed May 23, 2018 7:30 am Post subject: Re: Official "What oil / additives should I use" topic |
Allow me to annoy everyone.
I use whatever oil weight gives me a hot idle of 20-30 PSI (i dont drop below 10w-30) and with flat tappet stuff i add a zinc additive.
in race engines i use synthetic because it doesnt break down under heat as bad - id assume air cooled vw stuff is the same since they get pretty hot.
when i run zinc additive, i have never had to readjust my flat tappet solid lifter v8 cars that run way more spring pressure than these vw's.
in my mind, adjustment needed = missing material.
accomplished v8 engine builder (knuckle dragger to you all im sure ha!) |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Wed May 23, 2018 7:14 pm Post subject: Re: Official "What oil / additives should I use" topic |
thunderhead289 wrote: |
VW engines dont have that much psi @ idle more like 10-20, I've been using diesel oil for 10+ years, daily driving a bug with a 2100cc for the last 3 years, still waiting for it to explode _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
turbotype1 Samba Member
Posted: Thu May 24, 2018 6:06 am Post subject: Re: Official "What oil / additives should I use" topic |
vugbug68 wrote: |
VW engines dont have that much psi @ idle more like 10-20, I've been using diesel oil for 10+ years, daily driving a bug with a 2100cc for the last 3 years, still waiting for it to explode |
After reading all this..... your head is more likely gonna explode before your motor ever will.... _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
Posted: Thu May 24, 2018 9:00 am Post subject: Re: Official "What oil / additives should I use" topic |
turbotype1 wrote: |
vugbug68 wrote: |
After reading all this..... your head is more likely gonna explode before your motor ever will.... |
yes! exactly _________________ 71 Super - Backroad Thrasher
DeathBySnuSnu Samba Member
Posted: Thu Jun 14, 2018 5:37 pm Post subject: Re: Official "What oil / additives should I use" topic |
So.....
I have been reading a lot of good stuff about this next generation of modern oils. As I understand it the oil companies are addressing some of the issues that have come up with low zddp oils.
I do not know if it will ever get there or not but oil is still changing.
I hear good things about this one (in other weights also).
I am looking at trying this one (weight too) in mine.
I am nearing 3000 miles and all well with 5w20 dino.
Intend to go synthetic.
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Zundfolge1432 Samba Member
Posted: Fri Jun 15, 2018 11:44 am Post subject: Re: Official "What oil / additives should I use" topic |
DeathBySnuSnu wrote: |
So.....
You like that? You’ll love the new 0w16 getting ready for roll out later this year. |
Posted: Fri Jun 15, 2018 3:19 pm Post subject: Re: Official "What oil / additives should I use" topic |
Zundfolge1432 wrote: |
This was not primarily about the weight. It is available in other weights if that is what you like.
But instead is about the capability of the this brand and type of oil and if anyone else has used or researched about what is happening with oil. _________________
modok wrote: |
Thread Samba Member
Joined: June 25, 2017 Posts: 47 Location: Portland, Or
Posted: Thu Jun 21, 2018 12:18 am Post subject: Re: Official "What oil / additives should I use" topic |
Figured I should contribute. 67 Type 1 I’ve owned for 25 years
Engine is a 1776
Dual relief with stock springs and pistons
Full flow oiling system
Gene Berg 26mm oil pump
Gene Berg 239 pressure relief cover
Gene Berg 3.5 quart street sump
Remote oil filter
I had been running the “traditional” 20w-50 for as long as I can remember because “that’s what everyone said to do” and well the samba wasn’t around back then. And I pickled the car for about 10 years after the clutch cable tube broke free and I was getting a family going.
Anyways, it’s back on the road now. Initially with this motor I was again running the 20w-50 and getting OMG oil pressure when cold. It would of course drop when it got hot but would also get hotter than I liked when on the freeway. Pushing 240 at times.
Read this thread a few times and being older it made a lot of sense. So I put some Amsoil signature 5w-30 in it and have been very pleased. When cold it’s got much less pressure but it’s steadier on the gauge. Likely because the pressure relief system can actually work. And as it warms pressure does not start to drop as drastically.
It got up into the 90s today and driving on the freeway a new thing happened. It never got above 215 UNTIL I pulled off and was idling. At idle I had just under 10psi pressure which is fine but, the temp would inch up to maybe 230. That is until I moved again and very quickly the temp would drop to a steady 215. Which to me means the cooler is actually doing its thing and the oil isn’t bypassing it because the pressure is high. At no point driving, even on the freeway would it go past 215 even doing 70.
With the 5w-30 the oil really seemed to reach an equilibrium on temp and pressure the 20w-50 just couldn’t.
Interestingly enough, with the 5w-30 the straight cut cam gears aren’t as noisy either. I like the noise they make, it’s just quieter with the 5w-30 oil. But that could be more the Amsoil than the weight. I don’t know.
I’ll be sticking with the 5w-30, it seems that it’s workkng well. |
norris Samba Member
Posted: Thu Jun 21, 2018 8:53 am Post subject: Re: Official "What oil / additives should I use" topic |
I've been using that exact same Amsoil for about 3 years with the exact same results in my 2276. I'm sold on the product for sure. It's a bit more expensive than most, but after reading some extensive unbiased test results and my personal experience, it'll be all I ever use as long as it's available. |
Frodge Samba Member
Posted: Thu Jun 28, 2018 4:25 am Post subject: Re: Official "What oil / additives should I use" topic |
I was told by several older acvw mechanics that have been doing this stuff for decades to run a good 10w30 or 10w40 on a stock engine and change it frequently. That’s basically what I do. |
mark tucker Samba Member
Posted: Thu Jun 28, 2018 7:15 am Post subject: Re: Official "What oil / additives should I use" topic |
5-20 syn for about 80,000 miles sofar for mine.but Ive only been into vw's for about 17 years, so I havent learned all the old antiquated crap....although I do have a model T roadster..... |
Motor60 Samba Member
Posted: Thu Jun 28, 2018 8:32 pm Post subject: Re: Official "What oil / additives should I use" topic |
What oil are you running if you have a Webcam?
Says will void warranty if racing oil is not used....
Does Mobil 1 count? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Thu Jun 28, 2018 8:37 pm Post subject: Re: Official "What oil / additives should I use" topic |
Motor60 wrote: |
What oil are you running if you have a Webcam?? |
Hah, Do they now make a webcam to monitor inside your engine, to let the world watch it while your lifters fail or other bad things happen? _________________ Andy T.
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Jun 28, 2018 10:58 pm Post subject: Re: Official "What oil / additives should I use" topic |
Valvolone VR 1 conventional with my Web cam on 2 different engines _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Fri Jun 29, 2018 10:41 am Post subject: Re: Official "What oil / additives should I use" topic |
PennGrade 1 is suppose to have good zinc levels and should be good for a Camper Special motor or application where zinc containing oils are specified
https://www.penngrade.com/penngrade-1/
Now available at Halsey Motors in Portland _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
Bruce Samba Member
Posted: Fri Jun 29, 2018 10:50 am Post subject: Re: Official "What oil / additives should I use" topic |
otiswesty wrote: |
PennGrade 1 is suppose to have good zinc levels and should be good for a Camper Special motor or application where zinc containing oils are specified |
It does look good. Except that 20W-50 is the wrong viscosity for our engines. _________________
Toller Samba Member
Joined: March 27, 2018 Posts: 2 Location: Ontario Canada
Posted: Sat Jun 30, 2018 5:12 am Post subject: Re: Official "What oil / additives should I use" topic |
Here in the Great White North an oil has been developed specifically for flat tappet engines. http://www.camoils.com
I have gone the route based on recommendations on this forum with worst being synthetic which i found would leak out of places that conventional Dino grade would not. Unfortunately, availability is limited to Canada and contrary to statements on the web site we now have two distributors in Ontario. At under $10 CDN when I buy a case it has accomplished everything that it has advertised it is capable of doing for my 47 year old 1500. Temps are in spec, pressure is has been lowered and the valve noise has been reduced. Not as quiet as my Hemi in the Ram but it is noticeable |
Bruce Samba Member
Posted: Tue Jul 03, 2018 12:05 am Post subject: Re: Official "What oil / additives should I use" topic |
Toller wrote: |
Here in the Great White North an oil has been developed specifically for flat tappet engines. http://www.camoils.com |
Our engines were designed to use 30 wt oil. In the modern world of multi-grades, that means 10W-30, or 5W-30.
I would never use 15W-40, it's the wrong viscosity. _________________
Mr Beckstar Samba Member
Joined: April 11, 2015 Posts: 25 Location: The Entrance, NSW, Australia
Posted: Tue Jul 03, 2018 3:31 am Post subject: Re: Official "What oil / additives should I use" topic |
Bruce wrote: |
Toller wrote: |
I would never use 15W-40, it's the wrong viscosity. |
VW seem to think it’s okay so it could hardly be “wrong” unless you use it in the wrong climate.
