udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Oct 12, 2020 12:21 am Post subject: Re: Official "What oil / additives should I use" topic |
There was a change to SN rated oil....(SN plus)
API SN Plus Introduced in May 2018
Licensed from May 1, 2018, API SN Plus is a new API classification that can be used alongside API SN, API SN with Resource Conserving and ILSAC GF-5. It was developed in accordance with OEMs request for motor oils that can protect from the potentially catastrophic effects of Low-Speed Pre-Ignition (also known as LSPI
Engine manufacturers have been striving for a long time to reach higher and higher efficiency in their engines combined with lower and lower fuel consumption. One of the most efficient ways for a gasoline engine to operate is to use direct injection. LSPI can only happen in engines using gasoline direct injection technology.
So, what is LSPI and why does it happen? When the fuel is injected in the combustion chamber it may form a liquified solution with the thin residual layer of oil that sits on the cylinder wall. This fuel-oil solution is then pushed upwards by the piston during the compression stroke and the pressure may cause it to ignite, thus resulting in an unplanned combustion pressure wave. This is the LSPI event. Afterwards, the spark plug ignites the remaining fuel-air mixture that results in a second combustion shockwave. The combined force of the shockwaves is enough, in the long run, to create cracks in the piston and eventually to cause sections of the piston to break away completely.
Realizing this problem, engine manufacturers turned to oil companies for help. Oil companies changed their additive packages in such a way that would prevent the fuel-oil mixture from combusting and thus preventing the uncontrolled combustion. The American Petroleum Institute introduced a supplement to their API SN specification – called API SN Plus – that also includes tests to verify that the oil protects against LSPI.
And for the first time ever I was not able to get Valvoline VR-1 Racing 10w-30 at my NAPA (distribution store). Asked if I could order it. Response....No can do. Looks like Amazon it is. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Oct 12, 2020 5:50 am Post subject: Re: Official "What oil / additives should I use" topic |
Lingwendil wrote: |
Interesting that they couldn't order it, did they say why? Discontinued, NLA, etc? |
None given. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 573 Location: South of Raleigh
Posted: Thu Oct 15, 2020 9:12 am Post subject: Re: Official "What oil / additives should I use" topic |
Interesting....I just picked up a 6 pack of VR1 at my local NAPA yesterday. Might be a local thing |
modok Samba Member
Posted: Thu Oct 15, 2020 6:14 pm Post subject: Re: Official "What oil / additives should I use" topic |
Probably a liability thing. Somebody somwhere out that in their new car and voided the warranty and made the EPA mad. |
Silver65 Samba Member
Posted: Fri Nov 27, 2020 10:37 pm Post subject: Re: Official "What oil / additives should I use" topic |
Im in New England, guy who owned the car before me used SAE 30. Im cool with that, but what about winter? I don't plan on driving the car after the first snow storm but I do wanna let it run every few weeks. I was thinking of going 10w30, but if I kept it at a standard 30 would it really hurt anything?
Also whats the deal with everyone running diesel oil? I see a lot of people using rotella ? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Nov 28, 2020 10:47 am Post subject: Re: Official "What oil / additives should I use" topic |
I'd use 10W30 so you are covered year-round without thinking about it.
I use Rotella here because I like using 15W40 for Arizona.
The 40 is for when it's hot.
It's cheap and comes in a huge jug and ran cooler for me in the summer than when I tried another oil (I think it was Valvoline)
Rotella is/was often recommended because it had a better mix of chemicals (zddp ) that other normal modern "car" oils. _________________ How to Post Photos
wcfvw69 Samba Purist
Posted: Sat Nov 28, 2020 10:50 am Post subject: Re: Official "What oil / additives should I use" topic |
Gmanvr6 wrote: |
Look up VR1 racing oil by Valvoline. In my research, it has the right zinc and phosphorus in its makeup. I run 10-30 year around in Phoenix on engines with tight tolerances. Even in the summer heat, I have plenty of oil pressure. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Nov 28, 2020 11:20 am Post subject: Re: Official "What oil / additives should I use" topic |
Gmanvr6 wrote: |
30wt is fine, it doesn't use viscosity modifiers which can degrade from heat. No reason to start you car and run it, in fact it may well cause water to build up in the oil over time, a big negative. Fill your tank with ethanol free gas and block off the fuel inlet and run the engine at a fast idle until the carb is dry of fuel.
I run synthetics because they can take a lot of heat and its great having an all season oil like the 5w40 I like to use. Rotella T-6 though no longer carries an "S" rating which used to indicate it was suitable for use in gas engines. Don't know if this is really a problem or not, because VW air cooled engine are not at all typical in their needs. There are still other 5w40 Diesel oils that do carry a "S" rating, like Mobile 1 Turbo Diesel 5W40, which I continually look for on sale and sometimes find very good deals on. |
Posted: Sat Nov 28, 2020 11:46 am Post subject: Re: Official "What oil / additives should I use" topic |
Lingwendil wrote: |
I've noticed at tractor supply recently that there's a gas truck version of rotella now, might be worth looking into for those that like the stuff. |
It says "high mileage" which may or may not mean it has enough potentially cat clogging antiwear additives to protect the lifters, I have not checked this out. **W-40 oils were not restricted in the amount of ZDDP they can run but a 5W30 or 10w30 SN "NON-HIGH MILEAGE" oil would have been restricted. Just don't know for sure where this oil sits.
Wonder how it compares to Mobile 1 0W40 with rates well in various wear tests? |
Posted: Sat Nov 28, 2020 1:46 pm Post subject: Re: Official "What oil / additives should I use" topic |
wcfvw69 wrote: |
Gmanvr6 wrote: |
Look up VR1 racing oil by Valvoline. In my research, it has the right zinc and phosphorus in its makeup. I run 10-30 year around in Phoenix on engines with tight tolerances. Even in the summer heat, I have plenty of oil pressure. |
How much zinc and phosphorus is suggested? |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Nov 28, 2020 4:57 pm Post subject: Re: Official "What oil / additives should I use" topic |
Wildthings wrote: |
Lingwendil wrote: |
The picture I see says "ALL-Mileage", not "high mileage." _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Sat Nov 28, 2020 6:21 pm Post subject: Re: Official "What oil / additives should I use" topic |
SBD wrote: |
The picture I see says "ALL-Mileage", not "high mileage." |
Yes you are correct, but what the heck is an All-Mileage oil? |
KTPhil Samba Member
Posted: Sat Nov 28, 2020 6:54 pm Post subject: Re: Official "What oil / additives should I use" topic |
Wildthings wrote: |
SBD wrote: |
Sounds like a car repair sign I saw that made similar nonsense:
"Specializing in All Makes and Models."
There is even a current ad stating this oxymoron:
https://www.pachecoworldwide.com
Maybe suggest that the owner google "specialize"? |
SBD Samba Member
Posted: Sat Nov 28, 2020 8:26 pm Post subject: Re: Official "What oil / additives should I use" topic |
Wildthings wrote: |
SBD wrote: |
I don't know but I don't like the idea of high-mileage oils because, along with the higher zinc some claim to have for older flat-tappet engines, they nearly always claim to have additives that soften the seals and make them swell to help stop the leaks in all of those "high-mileage" engines. I don't need that in my newly-built ACVW motor with new seals. Somehow I can't imagine that stuff being good for brand new seals, but maybe I'm wrong? _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat Nov 28, 2020 10:38 pm Post subject: Re: Official "What oil / additives should I use" topic |
Perfect oil for my VW = 50/50 mix of Brad Penn 10w30 + Motul 300V 0w40 ester based racing oil
My secret recipe has been spilled _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
airschooled Air-Schooled
Posted: Wed Dec 02, 2020 9:02 pm Post subject: Re: Official "What oil / additives should I use" topic |
Cleaning out my late grandfather's tool box after it sat in limbo for a decade…
Looks like the man would have fit right in with the VW crowd.
"Custom blended oil for your specific application"
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
