Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Mon Mar 19, 2007 3:27 am Post subject: 64-67 Trailing Arm Needle Roller Bearing Number |
Does anyone know what the bearing number for 64-67 trailing arm needle roller bearings is? Are the top and bottom the same size? does any where stock them?
Any info would be great, thanks. _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
pandanom Samba Member
Joined: March 16, 2005 Posts: 1166 Location: Lexington, S.C.
Posted: Mon Mar 19, 2007 4:58 am Post subject: |
Where exactly are you talking about?
Most bearings can be found locally at a bearing distributor house. Is there a number on the old ones? _________________ It is never too late to have a happy childhood! |
Scotty Samba Member
Posted: Mon Mar 19, 2007 5:46 am Post subject: |
It is the number that is stamped on the bearing that I need, but I'm not 100% sure if there is a number on there. I wondered if the number was listed in any parts catalogues. _________________
EverettB wrote: |
Clara Samba Member
Scotty Samba Member
Posted: Mon Mar 19, 2007 7:18 am Post subject: |
From the diagram it looks like part number 10 as that looks like the needle roller. I guess 13 is the inner bearing?
Well my beam is off being re-worked at the moment, but I was cleaning up the trailing arms and found that the bearing surface (the collar in this instance) has rusted quite badly, so I figured the bearings would have gone the same way. I haven't checked the bearings yet, but I figured if I could get new ones it would be much better. I may be lucky, but time isn't on my side at the moment.
Thanks for your help. _________________
EverettB wrote: |
Damon22 Samba Member
Joined: January 03, 2006 Posts: 238 Location: New Forest, Ingerland.
Posted: Mon Mar 19, 2007 3:06 pm Post subject: |
What's the dealio with your trailing arms Scotty? BD beam different no? I presume you're doing some mix 'n' match. I just got Adey to build me a Boxwagen beam to fit my early trailing arms, came with new bearings, maybe give him a call? |
