Mr Brown Samba Member
Joined: January 30, 2006 Posts: 161 Location: Somewhere In Canada
Posted: Mon Mar 19, 2007 8:11 pm Post subject: Metal flakes in oil |
I pulled apart my oil filter today to have a look at the paper element. I noticed some copper or brass coloured flakes, not a lot but more than I would have expected. Where could this material be coming from? Filter was on for about 5000kms. Engine is a 2.0 AC with 186,000 kms on the bottom end. |
?Waldo? Samba Member
Posted: Mon Mar 19, 2007 8:45 pm Post subject: |
Inner bearing material or distributor drive gear or possibly valve guides. Regardless, that's not a good sign.
Andrew |
BuckP1 Samba Member
Posted: Tue Mar 20, 2007 8:07 am Post subject: |
Did you manually turn the engine backwards by hand recently? |
URQ Samba Member
Joined: April 12, 2006 Posts: 140 Location: San Diego
Posted: Tue Mar 20, 2007 9:18 am Post subject: |
looks like your filter is doing a good job? |
Posted: Tue Mar 20, 2007 8:52 pm Post subject: |
Andrew A. Libby wrote: |
Andrew |
Could be the distributor drive. The heads are new and so are the rod bearings.
I have been turning backwards, how would that cause brass contamination? |
tencentlife Samba Member
Posted: Tue Mar 20, 2007 9:07 pm Post subject: |
Quote: |
The heads are new and so are the rod bearings. |
You didn't say that before.
How did it get rod bearings without getting rings?
And what were you asking about flakes in the OF? |
dr. no Samba Member
Joined: August 06, 2004 Posts: 578 Location: Santa Fe
Posted: Tue Mar 20, 2007 9:12 pm Post subject: |
Turning backward is hard on the distributor drive gear... _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
Posted: Tue Mar 20, 2007 9:20 pm Post subject: |
[quote="tencentlife"]
The PO changed the rod bearings, pistons, rings, sleeves, heads,etc.. just before I bought the van. I did get some plain bearing material in the first filter after I bought the van but that has stopped. The brass is new so just wanted to know if anyone else had seen that before. I will cut apart the filter at the next oil change to see if it is getting worse.
Is the distributor drive gear hard to get out? |
