incynr8 Samba Member
Joined: September 23, 2003 Posts: 822 Location: Soylent Green is PEOPLE!
Posted: Tue Mar 20, 2007 7:15 am Post subject: 36hp question... Should I change the fan? |
I asked this in ENGINES section but no-one either knows or cares.
Is there any advantage of using a bastard 40 or 40hp (are they even different?) FAN in a 36hp? I was wondering if any invisible air upgrade (still wanna use control ring) is possible.
Is it correct to assume these even fit? I thought I heard reference to a '40hp' fan ina 36, but not sure if it's bastard 40 or 40 or if that even matters.
Thank you _________________ ..........
Do it right, or don't bother. |
Braukuche Samba Member
Posted: Tue Mar 20, 2007 11:29 am Post subject: Re: 36hp question... Should I change the fan? |
incynr8 wrote: |
Thank you |
Interesting question. If you are using a stock 36hp shroud it is the same as 40hp stale air shroud, right? So, a 40hp fan should work if that is the case. I know there is one year that has a bunch of holes in it, is that the air control ring style fans?
--Dan |
Posted: Tue Mar 20, 2007 11:39 am Post subject: |
yes 36hp fans have 'speed holes'
Just wondering if there is a fan that delivers more air now that I have the motor to longblock _________________ ..........
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Mar 20, 2007 11:43 am Post subject: |
i put stale air 40hp fans on 36hp engines. they have more blades (and the holes), and i believe they blow more air, and i feel that is important, especially with that tiny engine pushing a bus. i also think it helps with "heat" inside the bus.
the most important thing though, is that the fans absolutely MUST have the holes in the "flat" section if you use the thermostat ring. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Mar 20, 2007 11:49 am Post subject: |
so any 40hp fan with the 'speed holes', and I guess with the associated 6v nut area 'dimple' I will call it, either bastard or stale air 40 is cool?
Is the bastard 40 and the stale air 40 the same fan?
The additonal vanes and possibly therefore more CFM at a given speed is why I was considering it.
Thanks Jon _________________ ..........
Posted: Tue Mar 20, 2007 12:00 pm Post subject: |
and finally what about the 356 fan?
any further advantage if it fits? It should I expect. _________________ ..........
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Sat Mar 31, 2007 7:21 am Post subject: |
on a side note, about the thermostat ring. what is the factory cold setting for this? it a later model with the rubber stop, should it be set with the rubber against the fan shroud. or should I set it with a gap? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14218 Location: Casa de Oro, California
Posted: Sat Mar 31, 2007 8:25 am Post subject: |
I always wondered what those hole were for. |
Posted: Sat Mar 31, 2007 8:29 am Post subject: |
20 mm opened hot, from edge of ring to closest point on shroud until 1955
25-30mm opened hot after that.
The stop prevents the ring going into the engine too far and the adjustments should be made with the consideration of the opened position being within range.
It is not the 'at rest' position, necessarily, and the 2 36ers I have here are both opened at a slight angle with it not touching adjusted for 30mm (57 and 59 engines) _________________ ..........
Posted: Sat Mar 31, 2007 8:31 am Post subject: |
the holes I predict, are for a supply of air to cool the generator with the ring in the closed position, and some sort of bleed through of air for the heads (although not much) _________________ ..........
Posted: Sat Mar 31, 2007 9:20 am Post subject: |
incynr8 wrote: |
It is not the 'at rest' position, necessarily, and the 2 36ers I have here are both opened at a slight angle with it not touching adjusted for 30mm (57 and 59 engines) |
but it is cold sitting on the bench, what is a factory preset for this? |
Posted: Sat Mar 31, 2007 9:23 am Post subject: |
"resting slightly preloaded on the flange/stop"
Gotta check hot to make sure you get the sped opened though through t stat adjustment.
opening too far...hit fan.. _________________ ..........
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat Mar 31, 2007 10:46 am Post subject: |
BarryL wrote: |
Hi BarryL,
To suck cooling air through the generator.
Later in the 1500 upright engine VW redesigned the fan tin with ducting so as to allow pressurized air from inside the shroud to blow through the generator.
One can install the much later SP up to 29 mm, or DP 33, 34, or 35mm wide fans also in earlier engines. At the least drill out the two small holes in the later fans to earlier fan holes size to keep air being sucked through the generator. Laying out, center punching a few more pairs of holes to this area is not that hard. Using a small hole saw is probably the easiest tool to use for making these holes. A full sized drill in a drill press has the tendancy to grab the sheet steel as it goes through, and possibly fling the fan across the room if not locked down properly.
Also make sure to keep the .080 space between the fan, and the fan tin with generator pulley spacers. _________________ In Stereo, Where Available! |
BarryL Samba Member
Posted: Sat Mar 31, 2007 7:09 pm Post subject: |
E&B:
Quote: |
much later SP up to 29 mm, or DP 33, 34, or 35mm wide fans also in earlier engines |
Do those fans fit a single width shroud or do they have to have their respective width shrouds (if there is such a thing)? |
Posted: Sun Apr 01, 2007 8:27 am Post subject: |
Hi BarryL,
All the fan shrouds we have (1952-79) are the same thickness. So installing any fan just depends on shimming. _________________ In Stereo, Where Available! |
Posted: Sun Apr 01, 2007 9:42 am Post subject: |
I suspect a DP fan and a 36hp air control ring might not get along?
I think the 40hp with holes or later 356 fan with holes is still going to be a significant increase in air over the 16vane 36 stock fan, I'm too paranoid and would have to have the fan balanced after trying to make holes in it. _________________ ..........
Posted: Sun Apr 01, 2007 11:18 am Post subject: |
Hi incynr8,
Being the DP fan is deeper there should not be any interferance problem with the control ring. As for balancing if you take the same amount of metal off each side it should be no problem. Plus so far inside the outer diameter it is going to affect it much less than any changes on the rim of the fan.
Kind of like that one fellow who went for the worlds land speed record. He picked up a military surplus jet engine that had a broken off blade on one of the turbine fans making it terribly unbalanced. He opened the inspection plate for that fan and counted the blades on it. Then with that fin count figured out which blade would be exactly opposite of the broken off blade, and broke that one off. Result was a perfectly balanced engine. Funny part is when he started to make the news the military stopped by and insisted he could not have a top secret engine like that. He had to show the sales receipt that he had bought the engine legally...... _________________ In Stereo, Where Available! |
Posted: Mon Apr 02, 2007 5:27 am Post subject: |
interesting. I have not heard of the DP fan ever being fitted to a 36hp, seems like an ideal circumstance for Okrasa/Denzel and Judson equipped engines, especially with the oil cooler lines.
I found a 40hp with the 'holes' , so I will be using that, but if anyone has a 36er with a 34/35mm fan, I'd like to hear form them for how the fitment was.
Weird how VW increased the fan size as needed without going for max airflow from the beginning , given space being the same?
Sounds like it would work, since the Doghouse is bigger...at the doghouse only really.
I'm tempted to go with a DP welded and balanced Berg-style fan with the holes added and a 356 pully for a leaf blower in there! _________________ ..........
Posted: Thu Apr 05, 2007 7:35 am Post subject: |
incynr8 wrote: |
Weird how VW increased the fan size as needed without going for max airflow from the beginning , given space being the same? |
Hi incynr8,
Is interesting how as the fan got bigger that lower pulley got smaller. Then somewhere starting in the late 1960's this pulley went back up in size up till the 1970s DH "D" lower pulley, but even then that was still smaller than the 36 or even bigger 25 HP lower pullies. Seems the original designer of the fan shroud left the extra space in the fan shroud as a hedge against future engine size increase and/or hotter climate operations. Check out the 1963-67 Transporter Workshop Manual about the suggested bigger lower pulley to be used on 40 HP Bus engines, and the head fin drilling to increase cooling. _________________ In Stereo, Where Available! |
Posted: Fri Apr 13, 2007 4:29 am Post subject: |
I finally found a chart of fan CFM at particular RPM for engine until about 1968 (who cares after that here).
I will scan it and get it up on the samba for those interested.
The 40hp fan is a 1cfm increase over the 36 btw, and close to the airflow on a 1500 SP.
Most of the fans are close.
Unfort it doesn't show CFM over rpm ranges, just at max working engine RPM. _________________ ..........
