HoJu Samba Member
Joined: January 27, 2003 Posts: 40 Location: covina, californication
Posted: Thu Mar 27, 2003 1:59 am Post subject: disc brake conversion |
| has any one purchased a kit from either Topline, CB Performance, or Aircooled.net. If you have, how complete was the kit and how east or hard was the instalation(asuming you did it yourself). Thanks for the feed back. 72 super beetle |
HoJu Samba Member
HoJu Samba Member
Posted: Thu Mar 27, 2003 2:00 am Post subject: disc brake conversion |
| thats the link to my car up above |
NYBugman1972 Samba Member
Joined: March 03, 2003 Posts: 57 Location: Brooklyn NY
Posted: Thu Mar 27, 2003 4:22 pm Post subject: disc brake conversion |
I have used the Topline kit on my 72 super in standard 4x130 and now drilled and grooved 5x130 with pressed in studs. Never had a problem mechanically. The kit is very complete, and will bolt on. I did get a set of bad braided lines from them, but they were replaced at no cost.
Personally, I will only use Topline for my suspension. I trust them more than any other retailer out there. I have used their weld-a-struts, sport+ springs, disk kit, and I now run their MaXX struts. Everything I have of theirs worked as advertised.
If you need any more help or advise, or just want to talk supers, visit www.superbeetlesonly.com You will find like-minded people there.
P.S. Nice car! |
HoJu Samba Member
Posted: Fri Mar 28, 2003 12:08 am Post subject: disc brake conversion |
Vwbugman ..
Thank you for your post i think that i will go with topline on this one. If you haven't had any problems with them, then neither should I. thank a bunch |
Superman Samba Member
Posted: Mon May 05, 2003 6:34 am Post subject: disc brake conversion |
Topline is now the only kit on the market with aluminum billet (not steel welded) caliper brackets. Their kit is complete and superior quality to others.
Topline also sponsors our Super Beetle car club and that's not why I say they are the best. I picked them as our sponsor because they are the best!
www.superbeetlesonly.com |
Posted: Mon May 05, 2003 6:36 am Post subject: disc brake conversion |
| Opps, forgot to say... Nice drag Bug Marcus! |
davidw Samba Member
Posted: Wed May 14, 2003 12:57 pm Post subject: disc brake conversion |
What is the advantage to going with disc brakes on the front. Super Beetles stop well with droms on all corners. I've been debating with myself on going with discs but haven't quite come up with a good reason. Any comments?
Dave
'73 Sport Bug. |
72bug Samba Member
Joined: April 21, 2003 Posts: 92 Location: Harrisburg, Pa
Posted: Wed May 14, 2003 1:23 pm Post subject: disc brake conversion |
an excerpt from Aircooled.net
1)A They are self adjusting (VW drum brakes need to be manually adjusted).
2)In wet weather, you will have great stopping power because they are "self cleaning" and shed themselves of excess water and dirt. Drum brakes do not.
from aircooled.net |
