fakirone Samba Member
Joined: March 13, 2013 Posts: 51 Location: Atlanta, GA
Posted: Thu Mar 28, 2013 10:24 am Post subject: 1964 Brake master cylinder line leaking - need a little help |
So I went to drive off yesterday and found that I had basically no brakes. So, turn around, head home and park till last night. When I got home from work I took a look around and noticed that there was no fluid in the brake resovoir so I filled it up. A couple pumps of the pedal later and I had brakes. This morning I came out a noticed that there was a little puddle of brake fluid in the driveway when I was leaving, so I put the car up and took a look at the master cylinder and brake system.
The good news is he car has all new brake lines, among many other parts underneath. Win! The bad news is the PO looks to have jerrymandered the line leading from the resovoir. It look like it a modified brake line just jammed into a rubber fitting and the fluid is clearly leaking from this union.
So question is, how is this supposed to be and where do I buy whatever part is supposed to go here?
....___
..,(___),
(Ö\_|_/Ö)
McGuirk Samba Member
Posted: Thu Mar 28, 2013 10:49 am Post subject: |
With that fitting just dangling there it looks like your PO did just get a brake line from the local parts store, but the original set up is the same: metal brake line from the reservoir to a plug on top of the MC. The plug gets hard and cracks & you get leaks. Some of the aftermarket plugs also don't fit well and leak off the bat. You can get a good quality plug & brake line from Wolfsburg West:
http://www.wolfsburgwest.com/wolfsburg_new/brakes/bug_brake/bug_brakes.cfm |
chieftomahawk Samba Member
Posted: Thu Mar 28, 2013 11:01 am Post subject: Line |
if you want to keep the original look then you will have that metal line going into the M/C. If you want a safer system you could switch over to a dual circuit M/C and put the reservoir on top of the M/C. so that way if you lose your rear brakes you still have your fronts. i just did this to my 64 i even wen through the trouble mounting a new reservoir in stock location but it would leak when bumped at the M/C grommets. So i got a 83 BMW reservoir from my local junk yard and popped it right on. no more leaks and now i have the safety of dual circuit. also you can use some 80-91 model volvo or you can get one from empi. Just my two cents. |
Posted: Thu Mar 28, 2013 11:08 am Post subject: Re: Line |
chieftomahawk wrote: |
So to go to dual circuit you buy the 80-91 Volvo MC? |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu Mar 28, 2013 11:09 am Post subject: |
X2 on both posts. I would add that you can leave a dummy reservoir in place for stock appearance. _________________ Plate of shrimp |
Posted: Thu Mar 28, 2013 11:13 am Post subject: Re: Line |
fakirone wrote: |
Or you can go to the same website, Wolfsburg west, and order a 67-77 dual circuit mc. They run about 95 bucks for German, and a bit cheaper for brazilian. _________________ Plate of shrimp |
Posted: Thu Mar 28, 2013 11:20 am Post subject: Re: Line |
panicman wrote: |
fakirone wrote: |
Or you can go to the same website, Wolfsburg west, and order a 67-77 dual circuit mc. They run about 95 bucks for German, and a bit cheaper for brazilian. |
i would go with the 67-77 beetle dual circuit m/c you just need the reservoir from the volvo or bmw if you have the varga (brazil) one, if you get the german one you need to get the reservoir off a rabbit cause the nipples are diffrenet sizes. so that you can just pop it right on top of the mc |
Posted: Thu Mar 28, 2013 11:29 am Post subject: also |
i would also like to say be carefull taking out your old mc there are some metal bushings that will fall into the pan and its a pain to fish out. with out these the bolts will crush the pan. the way i found a reservoir that popped right on top of the mc after reading allot of posts here i just took my new mc to the junk yard and pulled a couple of reservoirs till i found one that fit snuggly. |
Posted: Thu Mar 28, 2013 12:57 pm Post subject: Re: also |
I read this last night, but thank you for the warning. That would have definitely sucked. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Fri Mar 29, 2013 5:07 am Post subject: |
McGuirk wrote: |
While you are deciding about the duel master, get 2 replacement rubber plugs. Pull out the old one witrh the metal line. Lube with brake fluid a new plug, and using a big C clamp gradually tightened, put the new plug in place. Look at the profile of the hole- you can see the ridges that make the ribber seal, and the new plug ha to go striaght in, not at an angle. Once it is seated, lube the metal line and work it thu the plug hole. I put a mark on the metal line first at the depth of the rubber plug to make sure it is all the way down. The metal line should have a flare on it at the end, which is why it is a PITA to get thru the rubber plug
The second runbber plug is in case you tear up the first one doing the install. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Fri Mar 29, 2013 7:03 am Post subject: |
my59 wrote: |
McGuirk wrote: |
The second runbber plug is in case you tear up the first one doing the install. |
