SCOTTIE BEE Samba Member
Posted: Fri Mar 23, 2007 8:50 am Post subject: where do i get longer rear studs for custom alloy wheels ? |
just got new/used aftermarket wheels, and they do not allow enough stud through to put on lug nuts.
any info is appreciated thanks
please email [email protected] subj. studs _________________ Click to view image
my #1 super hero...
O.G. BUMBLE BEE (no relation) |
rs251 Samba Member
Joined: April 30, 2005 Posts: 15 Location: Pacific Northwest
Posted: Fri Mar 23, 2007 4:21 pm Post subject: |
You can use studs from the front of a 1970's Bus, or buy the factory VW studs used on the Carat Wanagons with alloy wheels. You can also buy studs intended for Porsches from a number of aftermarket companies in all sorts of different lengths ( companies like Automotion, Tweeks, Paragon Products etc.) The 911 also uses 14x1.5 mm threaded studs same as the vans. |
Dogpilot Samba Member
Tank83 Samba Member
Joined: October 13, 2006 Posts: 115 Location: Germany - near Heilbronn
Posted: Fri Mar 23, 2007 5:31 pm Post subject: |
on a 2wd you can use the syncro studs, or you can use the studs of the vw lt transporter (do you have lt transporter in the usa?) |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Fri Mar 23, 2007 7:33 pm Post subject: |
The CIP1 studs do work well and they're cheap. I've used them several times, but since they are not threaded to the very end the advertised length is a little misleading.
Also, Vanagons equipped with factory alloys use the same short studs as the steel rim versions. VW just specified a taper seat lugnut rather than a ball seat in order to reach deeper into the alloy rim.
David |
Posted: Fri Mar 23, 2007 8:43 pm Post subject: |
thanks for all the feedback here and in emails.
cannot wait to get the new shoes on and piks taken.
thanks again all!! _________________ Click to view image
my #1 super hero...
