Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Fri Mar 06, 2015 12:29 pm Post subject: |
Bruce Amacker wrote: |
I think you have a Mig, right? Get some steel pallet strapping from a warehouse near you, or in their dumpster. It's a thin spring steel that fits and works perfect. It takes 5 minutes, cut and grind a piece of pallet strap and tack it to the cast block the adjusters go into. I have some pics but can't find them, and it worked great.
The hardest part is finding steel pallet strap, much of it these days is FG.
Good Luck! |
Found it- here's one I did lately on a Super Beetle, it worked like OEG.
_________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Fri Mar 06, 2015 3:10 pm Post subject: |
Did you just press in the "v" that drops Down into the grooves in the stars? _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
Posted: Thu Mar 12, 2015 11:37 am Post subject: |
Measured the remaining one on my ear brakes and it's 10mm x 50mm. I just laid the end of the sprung steel on top of a slightly cracked vise and used a chisel to put in the "V". Then it will simply be a matter of cutting the scrap to that 10 x 50 size and tacking it on (or drilling and screwing). Just noticed it looks like it's cracked and my finger is showing through...it is not.
Posted: Fri Mar 13, 2015 6:26 am Post subject: |
Good Luck! |
Did you weld to the casting? Have to use TIG, right? _________________ Looking for a correct 1967 rear seat
Posted: Fri Mar 13, 2015 6:35 am Post subject: |
Good Luck! |
You were able to MIG the pallet strapping stuff to the casting? Didn't think that would work. Did you heat the casting at all first or just tack away? _________________ Looking for a correct 1967 rear seat
Posted: Fri Mar 13, 2015 10:21 am Post subject: |
I shall... just for you. Gonna throw in a Brazillian too. I'll PM you the pictures. _________________ Looking for a correct 1967 rear seat
Posted: Mon Mar 16, 2015 3:19 pm Post subject: |
Just to add to the information somebody might wanna get out of this thread...
The spring is crimped in the channel and it's 10mm wide (50mm long as I said before). _________________ Looking for a correct 1967 rear seat
Posted: Tue Mar 17, 2015 5:04 pm Post subject: |
I was able to get the new fabricated piece into the old uncrimped groove, and get it solidly seated! No drilling...no welding. Very pleased. I bent the middle a little so it would decrease it's width. Then, once in the correct position I was able to use a punch and hammer to flatten it out...increasing its width, into the old groove.
Posted: Wed Mar 18, 2015 5:55 am Post subject: |
Nice work.
Still waiting for your pictures....... |
OK...couldn't send a picture to your PM, so I'm posting that Brazilian here!!!
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Mar 18, 2015 9:50 am Post subject: |
kenshapiro2002 wrote: |
Nice work.
oh!? brazilian bus, my mind went somewhere completely else... _________________ regards
Uli
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
Posted: Sat Jan 23, 2016 8:27 pm Post subject: |
ritchiet002 wrote: |
2Pack wrote: |
I made some once using a strip of sheet steel from the hardware store. I attached them using hollow aluminum rivets also from the hardware store. The rivets worked well, but didn't turn out real pretty. I was happy with the fix overall. This was for front brakes on a 64.
Is the one on the left the original? Mine are a little different, but what you made should work. Nice fabricating!
Doing the front brakes on my buddy's '62 SC and the adjuster springs are rusted completely off. Went trolling through The Depot's hardware isle and found this cool little thing that is going to work great. It's replacement wheels for a screen door. Ground the rivet off the wheel mount and pulled out the tension spring.
I'll use a small pop rivet to attach the tension spring to the backing plate.
_________________ 1956 Oval
and a barn full of VW parts
1956 Oval build thread
1962 Single Cab Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?p=7959298#7959298
1967 Beetle Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=495269&highlight=larrys |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Sat Jan 23, 2016 8:48 pm Post subject: |
Nice work.
Oh Ken! You are killin' me! Funny!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Phillip3560 Samba Member
Joined: December 17, 2019 Posts: 48 Location: atlanta, GA
Posted: Wed Apr 22, 2020 8:05 am Post subject: |
How were you able to put crimp in middle of fabricated piece? Using a punch? I am having the same problem with a broken spring but I cannot get the backing plate off so I have been trying to use a punch to install the new one while the plate is still on the car----not an ideal situation. |
Almir Samba Member
Posted: Fri Apr 16, 2021 5:44 pm Post subject: |
BulliBill wrote: |
While replacing a leaky rear wheel cylinder on my '67 Bus and freshening everything up in there, new cylinders and a set of shoes on both sides, I noticed that one half of the adjuster spring leaf broke off on both sides (one adjuster star being held in place and the other not).
Okay, other than spending a lot of time trying to make some up from scratch, or locating and buying new or used backing plates in good condition, does anyone know of a source, either NOS, used or repro, of a quality replacement brake adjuster leaf/tension spring "correct" for the rear brakes on a 1967 era Bus?
I hear/understand that you can't really successfully weld spring steel to the cast housing metal (incompatible), that one could try to un-swedge the casting to remove the old and install the new spring and re-swedge, or drill small holes and hollow-rivet the replacements in. I plan to do the latter if I can locate a suitable pair of replacement leaf springs.
I found some on cip1.com for my '71 Super Beetle. I'm just now sure how to install them?
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D311%2D609%2D485
Does anyone have any ideas or can you direct me to a suitable fix? Thanks for any assistance! Really!
Bill |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Mon Apr 25, 2022 11:02 pm Post subject: Re: Brake adjuster leaf spring |
### Edit - I've answered my own question ###
I'm case anyone else is looking for the front star adjuster leaf springs for a 55-63 ... BBT in Belgium have some in their NOS stock. They don't have the rivets though.
Keift en klok list the rivets (N134041) but the shipping is ridiculous, so now I need to work out the size and find an equivalent. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Fri Apr 29, 2022 3:26 am Post subject: Re: Brake adjuster leaf spring |
Who.Me? wrote: |
Keift en klok list the rivets (N134041) but the shipping is ridiculous, so now I need to work out the size and find an equivalent. |
That's weird, I thought I'd posted a follow up to this just now.
Anyhow, the adjuster springs arrived today and they're correct, so if anyone needs them, try contacting BBT and asking them to check their NOS stock to see if they have more. The part number is 211 609 185B (the B is important, none of the other styles are correct for 55-63 front brakes).
I contacted BBT because they have replacement back plate assemblies made that include the springs, so I figure their manufacturer is making the springs and maybe they could sell them separately. As it turns out, they have NOS ones...
Couldn't find the correct 2.6 x 5mm DIN 660 dome-head rivets, but found some 2.5mm x 6mm ones on ebay, so I've bought a bunch and some spares to try. The DIN 660 spec seems to have a +/- 0.1mm tolerance on the diameter, so I'm hoping those rivets will work. _________________ Andy
