notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Sun May 13, 2018 10:28 am Post subject: Re: Wide five disc brakes for type 3 |
Bobnotch wrote: |
Tram wrote: |
notchboy wrote: |
Well the logical mind just takes over. Why would I want to remove a perfectly good pair of spindles off my 64? OH! to put the disc brakes on.
Disc brakes are actually the one nod to modernity I would consider on my '63. Now that I am thinking about it, this would be a good way to have discs while having the complete drum brake setup already on spindles to keep with the car. |
That's the idea of them. It should keep the 5 lug cars 5 lug, since front drum parts are getting so hard to find. Well, that and the "hoarders" don't want to get off any parts for those trying to rebuild a set of wide 5 drum brakes. |
That's odd. I've found brake sourcing completely the opposite. It seems with today's social media reach, brakes and parts for earlies are fairly abundant. Sometimes pricey, but at least fairly available.
Its great to see ISP making these simple sets available. Safer is better. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
GearheadJim Samba Member
Joined: April 10, 2003 Posts: 178 Location: Columbus Ohio
Posted: Sun May 13, 2018 6:39 pm Post subject: Re: Wide five disc brakes for type 3 |
This is exactly what I've been looking for so that I can install my BerT3 dropped spindles. I wanted to keep the 5 lug,did not want to modify the spindle to fit the T1 kit, and the CSP kit is too pricey. Way to go ISP! _________________ Drive 'em!
65 Notchback build: https://www.thesamba.com/vw/forum/viewtopic.php?t=773405 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Mon May 14, 2018 9:46 am Post subject: Re: Wide five disc brakes for type 3 |
GearheadJim wrote: |
This is exactly what I've been looking for so that I can install my BerT3 dropped spindles. I wanted to keep the 5 lug,did not want to modify the spindle to fit the T1 kit, and the CSP kit is too pricey. Way to go ISP! |
I was just trying to find out if there's been any feedback on fitting them to regular disc spindles. I hadn't really thought of the lowered spindles.
If they're looking for a "crash test dummy" I'm willing to give them a try, and tell them my thoughts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue May 15, 2018 10:52 am Post subject: Re: Wide five disc brakes for type 3 |
notchboy wrote: |
Wont the spindle placement alter the caliper placement to stock? |
I don't think so, since I believe Bert used the spindle shaft itself to locate the caliper on those he had made. That dimension shouldn't change.
I wonder if these disc kits still retain the inner dust shield. I only mention it, as all of the other wide 5 conversion kits delete it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue May 15, 2018 1:37 pm Post subject: Re: Wide five disc brakes for type 3 |
Bobnotch wrote: |
I wonder if these disc kits still retain the inner dust shield. I only mention it, as all of the other wide 5 conversion kits delete it. |
I doubt dust shields are included - they're not really needed anyway. I have them on my daily driver and the only thing they're good for is picking up rocks and making a god-awful screeching noises.
notchboy wrote: |
That's odd. I've found brake sourcing completely the opposite. It seems with today's social media reach, brakes and parts for earlies are fairly abundant. |
I have found the same - early drum brake parts are pretty easy to find now that I don't want them. |
HenrikL Samba Member
Posted: Tue May 15, 2018 11:29 pm Post subject: Re: Wide five disc brakes for type 3 |
Very nice, but where is the information about possible change in track after the brakes is upgraded? I would like to know that before placing an order. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Wed May 16, 2018 9:35 am Post subject: Re: Wide five disc brakes for type 3 |
ataraxia wrote: |
Bobnotch wrote: |
I doubt dust shields are included - they're not really needed anyway. I have them on my daily driver and the only thing they're good for is picking up rocks and making a god-awful screeching noises. |
No, what I was getting at was being able to use the stock dust shields that are already on the car.
Good to hear Eric, as my son and I were talking about that last night, and wondering if there was any offset in them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed May 16, 2018 11:46 pm Post subject: Re: Wide five disc brakes for type 3 |
Erik G wrote: |
Michael has said zero offset change (on a facebook post)
When you call to order, they can confirm |
I already run CSP.
My post was more to point out that important information is missing in the ad. I would also want a picture of the brakes installed on a car. |
Braukuche Samba Member
Posted: Fri Jan 26, 2024 9:35 am Post subject: Re: Wide five disc brakes for type 3 |
Reviving this thread.
I went the route of getting disc brake spindles for my ‘63 and using the AC Industries (So Cals kit) with my stock 15 inch wheels and there is interference on the caliper. Like bad interference. I tried clearencing but after grinding off a good 1/4 inch of material there is still rubbing. My only other option is to grind the “hump” on the inner rim down where it is still scraping. Anyone else have this issue with these calipers? They seem to be a generic type 1 replacement and not purpose designed for early type 3 using a stock rim. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jan 26, 2024 1:49 pm Post subject: Re: Wide five disc brakes for type 3 |
Braukuche wrote: |
I went the route of getting disc brake spindles for my ‘63 and using the AC Industries (So Cals kit) with my stock 15 inch wheels and there is interference on the caliper. Like bad interference. I tried clearencing but after grinding off a good 1/4 inch of material there is still rubbing. My only other option is to grind the “hump” on the inner rim down where it is still scraping. Anyone else have this issue with these calipers? They seem to be a generic type 1 replacement and not purpose designed for early type 3 using a stock rim. |
Yeah, I don't know that I'd grind on the wheels. How about spacers? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Jan 26, 2024 10:10 pm Post subject: Re: Wide five disc brakes for type 3 |
Tram wrote: |
Braukuche wrote: |
Yeah, I don't know that I'd grind on the wheels. How about spacers? |
Considered that, but I’m not sure how much offset the disc set up has. But I guess if there is no other option… _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Jan 27, 2024 7:31 am Post subject: Re: Wide five disc brakes for type 3 |
I have the EMPI 3/8" aluminum spacers on my square.
Your stock wheels should fit fine unless you lower it drastically.
I bought longer Mercedes style lug bolts from www.ezacessories.com _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Jan 27, 2024 9:00 am Post subject: Re: Wide five disc brakes for type 3 |
Mike Fisher wrote: |
I bought longer Mercedes style lug bolts from www.ezacessories.com |
Stock height.
Guess I’ll get the spacers. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
