joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Mon Feb 01, 2016 11:07 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
lasvegas13window wrote: |
Ok, so I am buying some metal for my 55 Wolfsburg deluxe and I have some questions.
1. I need lower rear corners. Are the corners the same 55-67?
2. Is the Klassic Fab 55-57 decklid with the 3rd brakelight correct or does it need to be modified to be correct?
3. Are there any differences in belly pans? |
1. not 100% sure but I think the only difference on the corners from beltline down is tail lights position and reflectors
2. not sure about the KF one but the wolfsburg one the inner pressings are made of 4 pieces so there are seams near the corners
3. ??????? _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
oloyer Samba Member
Joined: April 13, 2005 Posts: 19 Location: Calgary, AB, Canada
Posted: Mon Apr 25, 2016 2:52 pm Post subject: |
thom wrote: |
Wolfsburg buses don't have the 'lip' around the fresh air inlet screen above the windshield. |
My Jan 56 bus has the lip around front vents. |
EmpiGT Samba Member
Posted: Mon Apr 25, 2016 4:00 pm Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
joe56vw wrote: |
3. ??????? |
1. Corners are different from 64-67 from the beltline down. The rear hatch goes into the corner on wide hatch busses,
2.. Correct above.
3... The belly pans are the same thru 1959 as Wolfsburg built. They are longer on the side panels and extend to a third outrigger in front of the rear wheels. One outrigger farther back than the rear jack point. |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Tue Apr 26, 2016 2:43 am Post subject: |
oloyer wrote: |
thom wrote: |
My Nov 55 bus also has the lip _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Tue Jul 19, 2016 12:52 pm Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
hey wolfsburg geeks, check out this early bus (chassis number 20-118229) advertised as a '56, but it is a '55:
http://www.thesamba.com/vw/classifieds/detail.php?id=1950623
_________________ .
Wanted:
AlteWagen Troll
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
VWLooseNuts Samba Member
Posted: Wed Dec 28, 2016 10:04 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
Lots of good info in here. Thanks. I have a July 55 Single Cab so this helps _________________ Jeremy
www.vwloosenuts.com
www.facebook.com/VWLoosenuts |
johndeluxe Samba Member
Posted: Sun Mar 19, 2017 6:59 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
Hi,
I'm searching for the correct headlight lenses for my February 56 originally delivered to Canada.
Does anyone have any pictures of the lenses?
Thanks John |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 19, 2017 9:18 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
johndeluxe wrote: |
Hi,
Thanks John |
Welcome to The Samba... well, to posting anyway.
At the top of the Split Bus forum... there's a Sticky:
Split Bus FAQ and How Tos - *Read before posting*
From there, you can scroll down and see a section titled "Glass" and a thread topic:
Headlight Glass
As far as I know... Canada used North American lenses... so, US spec.
The Headlight Glass thread would be a better place to pursue the info. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Sun Mar 19, 2017 4:22 pm Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
easy e wrote: |
johndeluxe wrote: |
Hi,
Thanks John |
Headlight Glass
The Headlight Glass thread would be a better place to pursue the info. |
Yes.
From that thread above, it's the "E1" lens like this
_________________ How to Post Photos
easy e Samba Member
Posted: Sun Mar 19, 2017 5:45 pm Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
There's two "E1" and do we know when the cutoff is from "E" to "no E"?
"E1.0671.01" across bottom, both Hella (top) and VW logos--'56-'63
- "25484" along inside top of rim--'56-~'58
- "25484" in lower left corner-- ~'59-'63
No "E" number, just Hella logo at top and VW logo at bottom--'53-'56
- No vestigial oval in center of lens--late '55-'56 _________________ aka: Evan
VintageWayne71 Samba Member
Joined: February 21, 2016 Posts: 4 Location: United Kingdom
Posted: Fri Aug 24, 2018 3:31 am Post subject: |
BUCIOBATISTI wrote: |
one percenter wrote: |
...Also, were bullet turn signals used from the beginning of production of post barndoor buses? I mean is a semaphore wolfsburg bus a euro model or was it a few thousand buses into production before you see bullets? What I can find on the subject is a little vague.
This thread is great. My Wolfsburg is a ways from the road but I will have to get some detailed feature shots up soon. Its a April '55 semaphore (in case you hadn't guessed) kombi #20-122*** |
My early April '55 Kombi is also a segapone Bus. I believe that all of the Buses through about May or maybe early June-ish had semaphores regardless of destination. The earliest bullet '55 that I can think of off the top of my head was a June '55. I've actually seen a couple June '55's that had bullets. Anyone else know more specifically on this one? I'm just curious. |
Bit late on this thread but My May 55 has bullets |
RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Wed Sep 19, 2018 2:01 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
Cab doortops...vent window tabs...
Late barndoor shape:
Flat, no rib, convex top curve (similar to the barndoor safari dashtabs.
Did this tab design carry over to late 55/56? _________________ -StockRocks- |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Wed Sep 19, 2018 8:13 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
RockStock wrote: |
Did this tab design carry over to late 55/56? |
It changed sometime in ‘57. |
D-train Samba Member
Posted: Thu Nov 29, 2018 2:08 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
Now before anyone asks the question, this is the original fresh air box cover, it hasn’t been changed.
Dove blue inside, pgsg outer, with some dB seen through the chips.
Which actually brings me onto this possible feature or change.
This is the original fresh air flap, dove blue seen on one side. But the strange thing with it is the flap is held together with split pins instead of rivets. I only removed it yesterday so it’s a surprise for me also.
This bus is in Australia, the birth cert says bound for England, but it’s a west Germany bus.
_________________ shiny paint doesnt make it worth any more |
Travis Woodard Samba Member
Posted: Wed Sep 04, 2019 7:29 pm Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
April of 1955 double door panel I found last week.
_________________ 56 PGSG OG paint Wilson Avenue church
59 mango
69 bay deluxe bay
66 beetle |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon Sep 09, 2019 7:34 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
More pics! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Mon Sep 09, 2019 7:44 am Post subject: Re: Post Barndoor, Wolfsburg Bus Features And Changes |
59 mango
69 bay deluxe bay
66 beetle |
