igraul Samba Member
Joined: July 12, 2006 Posts: 84 Location: '71 Fastback
Posted: Wed Apr 11, 2007 5:44 pm Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=223867&highlight=
...just recovered from this heart attack. Oil/filter change seems to have done it for me. _________________ ike
'71 Fastback (in assembly)
'86 Weekender (burned down)
'86 Weekender (t-boned)
'82 Vanagon L (burned down) |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Wed Apr 11, 2007 2:01 pm Post subject: Re: oil pressure woes |
[email protected] wrote: |
I would have your oil pressure checked right away with a gauge.
Need to rule out low oil pressure. |
Ill second that, dont run the risk (like i did) of trashing your motor because of questionable oil pressure. I instaled the oil pressure kit from VOLKS-cafe, i like it. Some might say it gives you another thing to worry about, i say its pretty valuable information. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
Posted: Wed Apr 11, 2007 1:45 pm Post subject: oil pressure woes |
jmfoust Samba Member
Joined: February 01, 2005 Posts: 130 Location: Des Moines, Iowa
Posted: Wed Apr 11, 2007 1:43 pm Post subject: |
LukeD23 wrote: |
I just had the oil changed...but ill check the level |
What filter and grade of oil? Some people have success with using an OEM filter (mann or mahle) and 20w50 oil.
jamie |
LukeD23 Samba Member
Posted: Wed Apr 11, 2007 1:37 pm Post subject: |
It only comes on once it gets warmed up.
It is not constant..only at idle
And even the slightest bit of throttle makes the light go away.
I just had the oil changed...but ill check the level _________________ 1984 Westy
1973 superbeetle - (sold) |
Posted: Wed Apr 11, 2007 1:33 pm Post subject: oil light woes |
if the engine is cold, is the oil light on at idle? or only when really hot?
how much do you have to rev it for the oil light to go out?
is it consistent?
could either be a bad oil light sender, the engine is low on oil, or real low oil pressure.
check the engine oil level right away!!! |
Posted: Wed Apr 11, 2007 1:30 pm Post subject: Oil Light on at idle..Off driving |
I picked up my van from the shop yesterday and drove on the highway for a few minutes. When I got off the oil light came on.
The oil light then turns off as soon as I give it Gas.
So idleing = oil light
driving or any gas given at all = no oil light
Im stumped???
I am planning on going on a trip tomorrow will I be ok?
ps...oil cable was disconnected when I bought the van and this was the first drive with it reconnected.
Thanks for any help! _________________ 1984 Westy
