floor vent covers
ghiajake
ghiajake is offline
PostPosted: Mon Oct 13, 2014 6:01 pm    Post subject: Reply with quote
I had a hard time figuring where the cables/levers routed, so thought I would share. Neither end of the cable is adjustable, so you need to "dry fit" it before it's hidden behind carpet.
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Apr 19, 2007 8:39 am    Post subject: Reply with quote
Icy wrote:
Ghiaddict wrote:
Icy wrote:
70 140 wrote:
Find someone parting a car out. They should come with the cable and levers as well - to open and close the vents.
70 floor vents don't have cables. They are operated by hand with a direct lever on the vent.
And no, they aren't the same as Beetle vents. IIRC, the cable vents started in 1973.
A point of clarification:
1969 & 1970 floor vents do originally have cables, with the
operating lever mounted high up on the corner underdash kick panels.
1972-1974 floor vents have the cable to the heater control knobs/levers.
Are you sure about 1969? IIRC, a 69 I parted out had the hand lever operated vents. I even remember seeing a friend's 70 with them. Perhaps it was a retrofit?
Yes, I'm sure.
But sometimes you see the cables eliminated
by a PO and they just install a knob at the floor vents,
or they swap out the plastic covers to some with handles/knobs.
Here's a pic, 1969 KG convertible, underdash levers, cables
properly hidden behind kick panel carpeting:
Karmann Ghia & Beetle parts available.
Convertible tops installed.
Gary
Person of Interest
Gary is offline
PostPosted: Thu Apr 19, 2007 8:30 am    Post subject: Reply with quote
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Achilles3588
Achilles3588 is offline
PostPosted: Thu Apr 19, 2007 7:09 am    Post subject: Reply with quote
bfy obsolete parts might also have them, used IIRC.
Larry V.~
'91 Syncro Doka 1.9L TDI 'AFN'
Ghiaddict
PostPosted: Thu Apr 19, 2007 6:40 am    Post subject: Reply with quote
Gary
Person of Interest
Gary is offline
PostPosted: Wed Apr 18, 2007 6:23 am    Post subject: Reply with quote
70 140
70 140 is offline
PostPosted: Wed Apr 18, 2007 6:13 am    Post subject: Reply with quote
freekazoid
freekazoid is offline
PostPosted: Wed Apr 18, 2007 3:40 am    Post subject: floor vent covers Reply with quote
Does anybody know where I can get some front floor vent covers for my '70? I don't suppose the beetle ones are the same are they?
