Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Apr 18, 2007 11:18 am Post subject: 72/AT |
We tried to turn over the 72. The torque converter is spinning, but the engine isn't? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Apr 18, 2007 11:31 am Post subject: |
Either someone removed the bolts that hold the torque converter to the drive plate, or the crankshaft is broken. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Posted: Wed Apr 18, 2007 12:00 pm Post subject: |
Missing dowel pins? |
Posted: Wed Apr 18, 2007 12:27 pm Post subject: |
We just towed it home w/sea blue rebuilt never fired engine bolted in. I can see the flatish flex plate next to the roundish torque converter. I guess I better pull the engine to see what the PO left out! |
vwfye Samba Member
Posted: Wed Apr 18, 2007 12:33 pm Post subject: |
mike, did you trailer or dolly the car? if you dollied the car and didn't unhook the axles, your tranny is toast! i hope that isn't the case _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Wed Apr 18, 2007 12:37 pm Post subject: |
We tow dollied w/rear axles on the dolly. |
vwfye Samba Member
Posted: Wed Apr 18, 2007 12:47 pm Post subject: |
good... the trans acutally needs to be cirulating fluid while the axles turn.
hey tomnotch, is that picture you have of the hole in a case from towing an auto trans or an engine? _________________ 64 No'back Speedster "Pearl"
Posted: Wed Apr 18, 2007 1:36 pm Post subject: |
Can we balance the engine on a 12" X 12" heavy plywood & floor jack to drop it down? I guess I oughta take all stock exhaust/heater boxes off that I just got on yesterday |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Wed Apr 18, 2007 2:14 pm Post subject: |
Why don't you check to see if the TC is bolted to the flex plate, before pulling the engine?
Not seeing how you can get the TC spinning if the engine isn't running (unless it's by hand from the access cut out). If so you should be able to check the bolts.
good luck _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
Posted: Wed Apr 18, 2007 2:54 pm Post subject: |
The flex plate is NOT bolted to the torque converter! I can spin the TC and see the bosses for the bolts. I guess I'll lever the engine around to find a bolt hole on the FP. |
Posted: Wed Apr 18, 2007 2:55 pm Post subject: |
COFBack wrote: |
good luck |
Exactly. Maybe they just didn't bolt it in.
Sounds like this should be my car, anyways... hopefully you haven't yanked the FI yet? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Apr 18, 2007 2:56 pm Post subject: |
Tram wrote: |
COFBack wrote: |
good luck |
Sounds like this should be my car, anyways... hopefully you haven't yanked the FI yet? |
Edit: Guess you found out already. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Apr 18, 2007 3:10 pm Post subject: |
Late model IRS block w/Solex's! I got a box of FI parts, but no ECU or electric fuel pump. |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Wed Apr 18, 2007 11:26 pm Post subject: |
Mike Fisher wrote: |
you've got a P...
nah, ill let tram take this one
im flat broke anyways. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Sun Apr 22, 2007 2:51 pm Post subject: |
Pulled the engine/ground the MT cases for room for wrench on flex plate bolts/reinstalled and bolted up to AT & IT'S ALIVE!!! |
Anniehum Samba Member
Joined: November 23, 2003 Posts: 1197 Location: Kingston, Washington
Posted: Sun Apr 22, 2007 6:04 pm Post subject: |
Congratulations. Can I have your FI stuff?
Cheers _________________ Ho'oponopono |
fasty69 Samba Member
Joined: November 28, 2006 Posts: 213 Location: CANADA
Posted: Sun Apr 22, 2007 8:42 pm Post subject: |
what kind of bolts did you use for the flex plate,?
if you use normal non hardend bolts they will stretch, come loose and start to machine the back of your engine case (dont ask me how i know) _________________ Newest member of the family+New project
69 Fastback-Free of Rust |
Posted: Mon Apr 23, 2007 4:30 am Post subject: |
They are stamped 8.8 like the original. |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Mon Apr 23, 2007 6:38 am Post subject: |
So, the motor runs o.k. Mike? _________________ '63 Ragtop |
Posted: Mon Apr 23, 2007 7:40 am Post subject: |
I might have exaggerated a little. We're only getting gas squirting out of the right carb. It was popping back like the cap wires might be wrong? We quit there yesterday, but I'm gonna get back on it this morning. How long do you think the car has been sitting? The gas smelled like varnish, but we just dumped more gas in it to dilute it. PS Mark is the PO |
