Nose cone
jroymcd
jroymcd is offline
PostPosted: Thu Apr 19, 2007 12:24 pm    Post subject: Nose cone Reply with quote
how can you tell if your nose cone is damaged? i just did my mounts. the front mount was really bad. just got the car so dont know how long they were like that. put all new heavy duty german mounts in but did not inspect the nose cone.
www.cultwagen.com
sled
sled is offline
PostPosted: Thu Apr 19, 2007 3:12 pm    Post subject: Reply with quote
if the nose cone is broken then it will possibly leak and also under acceleration it will buck and lurch. your shifting may be difficuly and erratic as well.
jroymcd
jroymcd is offline
PostPosted: Thu Apr 19, 2007 3:42 pm    Post subject: Reply with quote
So would the motor move back and fourth like it did with the broken front mount? can you tell by looking under the car?
www.cultwagen.com
KantDriveFast
KantDriveFast is offline
PostPosted: Thu Apr 19, 2007 5:54 pm    Post subject: Reply with quote
I've seen a few broken ones, and its usually the square boss with the mounting holes in it. Snaps right off the nose cone body. Look for a big crack. Wink
jroymcd
jroymcd is offline
PostPosted: Thu Apr 19, 2007 10:29 pm    Post subject: Reply with quote
did not see any big cracks and it was pretty dry so i think im good. looks to have a small leak where there is a threaded sensor (reverse light?)
www.cultwagen.com
Herby
Herby is offline
PostPosted: Thu Apr 19, 2007 10:50 pm    Post subject: Reply with quote
Check to see if the holes where the studs for the tranny mount on the nose cone have ovaled. I recently changed my tranny and this mounting area had oval holes instead of perfect circles, which most likely caused the tranny to teeter and most likely cause my shifting problems since they went away when I added a midmount a couple months ago.
62 Beetle
73 Super Beetle German Look project
03 TDI Jetta
Airspeed
www.airspeedvwclub.com
"Do not assume that there isn't room for improvement just because VW didn't do it."
Samba #34091
RIS
RIS is offline
PostPosted: Thu Apr 19, 2007 11:32 pm    Post subject: Reply with quote
This is from the inside, but I guarantee if you're nose cone is cracked you will have more than a little leak. I dumped all my gear oil in under a 1/4 mile....
[/url]
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
jroymcd
jroymcd is offline
PostPosted: Thu Apr 19, 2007 11:35 pm    Post subject: Reply with quote
ouch.
my bug is a 65. it has a sensor in the nose cone. was that for a reverse light? so do i have a later tranny?
www.cultwagen.com
sled
sled is offline
PostPosted: Fri Apr 20, 2007 12:07 am    Post subject: Reply with quote
yes you do
bill may
bill may is offline
PostPosted: Fri Apr 20, 2007 3:46 am    Post subject: Reply with quote
jroymcd wrote:
ouch.
or a 67 and newer nosecone on earlier transaxle.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
