60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Mon Apr 23, 2007 5:48 pm Post subject: '85 Cabriolet oil pan seal question |
i want to put a new seal on the oil pan on my '85 Cabriolet because it's leaking some oil. any tips?
_________________ 77 Westy - Cape Cod Sage
LLAP |
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Mon Apr 23, 2007 7:37 pm Post subject: |
When I did mine I bought a 10 mm universal/ flex socket to get at the bolts on the tranny side. I bought a 3/8 drive one and it barely fit. I'd recommend one in 1/4 inch. The only other thing I recommend is to retighten the bolts after a few days. When I checked mine a week or so later (after finding an oil puddle on the ground) they were all loose. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
Posted: Mon Apr 23, 2007 7:51 pm Post subject: |
should i use some thred lock? _________________ 77 Westy - Cape Cod Sage
LLAP |
cub Samba Member
Posted: Tue Apr 24, 2007 6:26 am Post subject: |
If you can spend a little extra money and the car isn't going to get lowered go ahead and put the oil pan, gasket, and bolts from a '90-'93 2.0L Passat...it'll give you an extra 3/4qt capacity. Don't use threadlock. _________________ I love old cars |
Posted: Tue Apr 24, 2007 5:02 pm Post subject: |
cub wrote: |
If you can spend a little extra money and the car isn't going to get lowered go ahead and put the oil pan, gasket, and bolts from a '90-'93 2.0L Passat...it'll give you an extra 3/4qt capacity. Don't use threadlock. |
that will fit on my 8v? _________________ 77 Westy - Cape Cod Sage
LLAP |
cub Samba Member
Posted: Wed Apr 25, 2007 10:23 am Post subject: |
The one you posted is the cheapo version. The Passat 2.0L 16V oilpan gasket is alot thicker (probably close to 1/2" or a little thicker) and has a piece of aluminum sandwiched between two pieces of rubber. Also just making sure you have the larger 5qt(4.7) oilpan. I did a 16V conversion on my '77 and used larger pan and gasket will both raise oil capacity but also aid in engine cooling and longevity. My engine is from a '93 Passat but all pans/gaskets are the same from '75-'98-ish. _________________ I love old cars |
Posted: Wed Apr 25, 2007 11:18 am Post subject: |
cub wrote: |
The one you posted is the cheapo version. The Passat 2.0L 16V oilpan gasket is alot thicker (probably close to 1/2" or a little thicker) and has a piece of aluminum sandwiched between two pieces of rubber. Also just making sure you have the larger 5qt(4.7) oilpan. I did a 16V conversion on my '77 and used larger pan and gasket will both raise oil capacity but also aid in engine cooling and longevity. My engine is from a '93 Passat but all pans/gaskets are the same from '75-'98-ish. |
do you have any links to pages that have these parts? _________________ 77 Westy - Cape Cod Sage
LLAP |
