bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Thu Apr 26, 2007 6:30 am Post subject: Deciphering watercooled head markings. |
I'm trying to figure out how to decipher the markings on the VW watercooled heads. Most have a clock looking thing between #3 and #4 injector (which nobody seems to know how to decipher either) but mine has a circle with the numbers (from top to bottom) 23 11 8. I want to be sure the head I have will work on it before I tear it apart. The head I have is the original head off my 85 Jetta (with the clock thing on it) and the motor in it now in the pic is supposed to be from an 84 Rabbit. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Fri Apr 27, 2007 10:34 am Post subject: |
You know, I've never heard anyone mention those markings before, nor seen them referred to in any factory manuals. I thought they were casting or production code numbers that were mostly meaningless.
As long as the engines are both 1600s, and you choose the correct thickness diesel head gasket, I think it should work OK. |
cub Samba Member
Posted: Fri Apr 27, 2007 11:29 am Post subject: |
They are a build time/date stamp. I asked this many, many years ago to a retired VW tech but that's all I know. _________________ I love old cars |
vwpikup1 Samba Member
Joined: August 16, 2006 Posts: 12 Location: greenfield wisconsin
Posted: Fri May 11, 2007 4:07 pm Post subject: |
yes they are manufacture markings nothing that is importance to the consumer !but you mention using a 84 head on a 85 make sure your 85 is not hydrolic because the 84 is mechanical! and stick with the same size head gasket! piston stick up past the top deck of the block is determined by the thikness of the head gasket and you did not change any of that !
Duane |
Posted: Fri May 11, 2007 4:25 pm Post subject: |
I thought that on Diesel engines, 1985s still had mechanical lifters and didn't go hydraulic til 1986. Or wait, hold on, was that a mid-year change? |
