Fix that Loose sliding door handle on an early Vanagon
Page: Previous  1, 2, 3
BulliBill
BulliBill is offline
PostPosted: Wed Jul 29, 2009 9:34 pm    Post subject: Reply with quote
Hi all,
I have a '87 Westy and I just noticed that my outside cargo door handle is missing about half of the plastic seal/escutcheon between the handle and the body. Now water will be able to get inside the door.
Question #1: Is this seal for an '87 handle to body still available anywhere, and if not, is there an alternative seal or fix. Or does somone out there have a decent condition used seal?
Question #2: Is there a write up on how to remove the inner door panel and outer handle to add a new seal for the "later" '87 Vanagon, or is the procedure the same as the "earlier" handle.
Thanks for pointing me in the right direction towards a new (or used) seal, and directions on how to get it done!
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
wbx
wbx is offline
PostPosted: Mon Jun 14, 2010 4:57 pm    Post subject: Reply with quote
FWIW, my modification/reinforcement to the handle is still holding up after 3 years...
Just thought i'd throw down that little update. Smile
'84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go.
DAIZEE
DAIZEE is offline
PostPosted: Sat Jun 26, 2010 2:21 pm    Post subject: Reply with quote
I don't have a problem with the key or lock. For some reason or other the aft latch is not releasing. I can open the door from the outside but from inside I pull the handle and throw my body at the door and it opens real easily! Tomorrow I will slowly and carefully remove the door liner. Hopefully info in my on board Bentley.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Sat Jun 26, 2010 6:10 pm    Post subject: Reply with quote
you will find that you probably need to adjust cable in door that goes from handle to rear latch.
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
westylife
westylife is offline
PostPosted: Sat May 10, 2014 2:54 pm    Post subject: Reply with quote
Is there a way to tighten the front sliding-door lock? (p.58.3) I have changed out the handle twice and replaced all the hardware to make sure its all correct and the handle is still very loose. If I move the handle and watch the screw, it looks like the lock mechanism it-self is loose. No matter how tight I tighten the screw, the inner part of the door lock seems to be moving around.
Do these wear out?
Thanks for any help.
1983.5 Westfalia Bostig RG1
AKWesty
AKWesty is offline
PostPosted: Sat May 10, 2014 11:39 pm    Post subject: Reply with quote
Hey neighbor, I just replaced my sliding door handle because it was extremely loose. Upon replacing I inspected the worn areas of the latch assembly. The new handle is much tighter but I could see wear inside the door assembly and though better, it is still a little loose.
I took my panel off thinking I needed to adjust my cable. I PB blasted the rear locking mechanism but my cable was tight. Door opens and shuts much easier after PB blasting years of crud off the mechanism but the handle is still a little loose. I decided there was nothing more I could do besides finding a new handle mechanism off a salvage door.
84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir
westylife
PostPosted: Sun May 11, 2014 7:28 am    Post subject: Reply with quote
Thanks, AKWesty.
Yeah I was afraid someone was going to say that. I don't know about in Haines, but there are not any vans in the local junk yards here. Ill have to use the classifieds. I wonder if they are the same for all vans without auto locks?
AKWesty
AKWesty is offline
PostPosted: Sun May 11, 2014 9:04 am    Post subject: Reply with quote
When I bought my handle from BD there were only two choices for the handle. I am assuming the difference between the power locks and manual. Not exactly sure though.
No choices for this kinda stuff in Haines. We are headed south next week and I have some stops planned along the way to look for random parts. Its the Alaska penalty. You can ship it here but its gonna cost you.
84' Westy 2wd
GW +1.5 Springs
215/70-16's
MacDude
MacDude is offline
PostPosted: Mon Aug 18, 2014 9:41 am    Post subject: Reply with quote
Thanks for the thread and the info from those on it.
My problem isn't so much that the handle is loose (it is a bit), but that it's so stiff to open that my wife can't do it a lot of the time. She pushes down but she doesn't have the necessary leverage. Now she's no weakling, she's just not as strong as I am. I give it a sturdy shove downward and it pops open.
Would taking it apart and greasing it help in that situation?
PS, the Key doesn't work on that lock and the rear catch doesn't catch anymore (spring issues), but that's different and not as urgent
'84 Wolfsburg Westfalia
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
cs44
cs44 is offline
PostPosted: Wed Mar 30, 2016 10:36 pm    Post subject: Re: Fix that Loose sliding door handle on an early Vanagon Reply with quote
Just piling on...
Here's my destroyed sliding door handle. Good times.
Scamper-Van
Scamper-Van is offline
PostPosted: Wed Apr 04, 2018 10:16 am    Post subject: Re: Fix that Loose sliding door handle on an early Vanagon Reply with quote
To anyone still reading this thread: GoWesty has a good DIY video that shows how to remove & replace a Vanagon sliding door handle.
There are two different door handles: one for 1980 - early 85 vs. another for later 1985 - 91 Vanagons. Replacement parts may be out-of-stock & hard to find. These handles get a lot of wear & tear, obviously.
And yes, it looks like DRY graphite powder is recommended for the locks, not grease.
AndyBees
AndyBees is offline
PostPosted: Wed Apr 04, 2018 10:30 am    Post subject: Re: Fix that Loose sliding door handle on an early Vanagon Reply with quote
Thanks for the GoWesty link. I purchased a handle for my 84 (long one) about two months...... just haven't got around to tackling the job.
Maybe this video will motivate me!
'84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Page 3 of 3
