Oldie_but_goodie Samba Member
Posted: Sat Apr 28, 2007 9:44 am Post subject: 1971 DP 1600 - Air cleaner |
The following picture illustrates the engine in my Ghia convertible. Can anybody describe why this has such a complex air intake/cleaner system compared to other 1600 engines.
Would yanking this air contraption off and replaceing with something simpler and with a better flow help the horsepower?
Ok thats really 2 questions, I'm mostly curious about this particular design and why it suddenly showed up on the 71 dual ports?
Thanks. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Apr 28, 2007 9:59 am Post subject: |
If it's all in good shape, I'd leave it stock, the stock air cleaner works very well, and is designed to properly flow air into the carb.
By complicated, what do you mean? Most of that "extra" stuff is emissions related and doesn't hurt anything to leave hooked up. In the picture you have a preheat hose coming off the engine with a thermostat-operated flap on the air cleaner, a crankcase breather, and a line coming to it from the evaporative fuel tank vent system -(with a charcoal canister to hold the fumes) - all of that is passive and doesn't hurt anything.
and actually, the preheat thermostat on the 1971 models is simpler than on 68-70 models, where it was cable operated to an arm coming off of the cooling flaps of the engine. |
blackthree4me Samba Member
Joined: February 11, 2005 Posts: 77 Location: South TX USA
Posted: Sat Apr 28, 2007 12:24 pm Post subject: |
man yall are right up my ally today
I was wanting to know about the filter asembly inside of the unit
I stuck mine in for pre powder coating bake out and came out with a few uhh ohhs
melted some plastic bushings for the pre heater and linkage
(no biggie I can get a replacement pieces off of a doner)
the big question was, what is or should I say "was"
inside the filter assembly?
sorta looked like moss coming out ?
what could I use in its place?
I know I can never put it back, but was thinking of a filter that just lays on top of the waffel instead of between it and maybee tie wire down
just a thought
as for leaving it or going to something else
yours looks pretty stock it kinda rare to see one in that kinda shape if it was mine I would leave it its worked for all thease years why mess with it
there are alot of fools out there changing intakes to gain 100 HP
give me a break
dont be one of them. LOL
at best you might get 2HP
you could get that much by greasing your wheel bearings ( finaly)
blackthree4me _________________ 1968 spatz dune buggy
1971 karmann Ghia |
Posted: Sat Apr 28, 2007 12:48 pm Post subject: |
blackthree4me wrote: |
the big question was, what is or should I say "was" inside the filter assembly? |
Over the years I've heard two different explanations of what that mesh which "wicks" the oil up and and catches the particulates in the stock air cleaners. One that is was coconut fibers, the other that was copper wool (like coarse steel wool, only made of copper) |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sat Apr 28, 2007 2:55 pm Post subject: |
It really isn't that complex of a system, in fact it is quite straightforward. Just keep the oil fresh in the filter and everything else is worry free. If you strip it all out and just run a paper filter on top of the carb you lose the pre-heat, you end up with a lower quality filter, and you may run into tuning problems.
If you have a complete working system leave it in place. The only way I would get rid of my oilbath was if I switched to dual carbs. |
Posted: Sun Apr 29, 2007 6:02 am Post subject: |
thanks
on a 71 air cleaner it was definatly the cocanut type filter !
I was pretty close on the moss thing. LOL!
I was thinking of using a house type fiberglass filter then just cutting it down to fit the inside
what if I used some air filter pre oiled foam on top?
any one any one.
the powder coating came out great and looks supper sharp in black wrinkel.
thanks for any help yall can give _________________ 1968 spatz dune buggy
1971 karmann Ghia |
hogboy52 Samba Member
Joined: April 11, 2007 Posts: 66 Location: Portland,OR
Posted: Sun Apr 29, 2007 9:30 am Post subject: |
The fact is, there's a considerable clearance problem with the low deck lid compared to the bug, even with dual carbs. |
KG Fan Samba Member
Posted: Mon Apr 30, 2007 7:54 pm Post subject: |
Oldie But Goodie,
If you decide to leave your stock arrangement and you would like to sell me your thermostat off the oil bath filter, I am looking for a working one.
Thanks, Randy _________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
-Dr. Suess
"Oh that thing? That's just a gaurd, you really don't need that. I'd just take it off."
-Three Fingered Jack |
70 140 Samba Member
Posted: Mon Apr 30, 2007 8:11 pm Post subject: |
KG Fan wrote: |
Oldie But Goodie,
Thanks, Randy |
Look at similar era busses as well, they used the same oil bath filter. |
KG Fan Samba Member
Posted: Mon Apr 30, 2007 8:23 pm Post subject: |
70 140,
Thank You.
Any idea how many different styles of those thermos were made? Of course, I need the proper length. Any more specifics on what years of the bus thermos would fit my '71 Coupe? Sure appreciate any help finding a working one.
(Maybe I should start a new thread)
-Dr. Suess
70 140 Samba Member
Posted: Mon Apr 30, 2007 8:36 pm Post subject: |
KG Fan wrote: |
70 140,
Thank You.
Randy |
No idea, there were at least two different styles of thermostat for the warm air intake. In 1973 the type 2 switched to a type 4 engine and dual carbs, so the filter was abondoned.
From what I have seen (and this may not be how it was originally)
- the 68-70 had a cable that actuated the warm air intake - it connected to the flaps on the rear of the cooling shroud - i.e. as the flaps opened, the cable closed the warm air intake.
- the later cars had a thermostat right on the filter... which I'm guessing was warmed by the air being drawn in through the warm air intake.
Either filter would fit your car and work, but the cable that connects the earlier model is NLA.
The photo of the engine above - which I think is from my gallery? Shows the later style filter.
This is the earlier unit. The mechanism that opens and closes them is on different sides. You can also see the little arm that supports the cable casing:
Posted: Tue May 01, 2007 6:03 pm Post subject: |
Those spring loaded thermostats lasted only one year (1971) on both the Type I and Type II After that they used the vacuum-operated t-stat. |
74Ghia Samba Member
Joined: December 17, 2003 Posts: 2131 Location: Middle of Georgia
Posted: Tue May 01, 2007 6:35 pm Post subject: |
Biggest problem I've noticed with the 71 on stock air cleaner system is that the plastic pipe from the air cleaner to the top of the carb always rubbed a hole through the plastic rain tray.
As for clearance issues with dual carbs, not a problem if you have the short intake manifolds. Even with the air cleaners, I have about 3/4 inch between the top of the air filter and the bottom of the deck lid hinge. _________________ Allen C.
2012 Silverado
53 FiberFab MG TD Replica (VW)
Life is hard and its harder if you're stupid. |
70 140 Samba Member
Posted: Wed May 02, 2007 6:21 am Post subject: |
glutamodo wrote: |
How did this work? Where did the vac line draw from? How did it decide when to close the flap? |
Posted: Wed May 02, 2007 10:07 am Post subject: |
It was pretty simple acually, the air cleaner had a temperature-sensitive vacuum valve mounted in the air cleaner housing. The vacuum signal came off of the manifold and supplied enough vacuum mostly at lower RPMs, so combined together, it would only supply vacuum to open the preheat air flap at lower engine speeds and only when the air cleaner was below a certain temperature. Here's a pic of the layout from the 74 Ghia owner's manual. The vacuum valve is on top, Hose E is the one that goes to the manifold.
70 140 Samba Member
Posted: Wed May 02, 2007 10:47 am Post subject: |
Thanks for that info. I had never seen that set-up before. |
52brezelfenster Samba Member
Posted: Fri May 19, 2023 7:43 am Post subject: Re: 1971 DP 1600 - Air cleaner |
Happy Friday, reviving an old thread.
Does anyone know the part # of the 1971 air cleaner setup?
Thank you |
kingkarmann Samba Member
Posted: Sat May 20, 2023 1:18 pm Post subject: Re: 1971 DP 1600 - Air cleaner |
52brezelfenster wrote: |
Thank you |
Of course Airhead Parts shows it as Out of Stock but they list a part#
Hopefully its correct.
211-129-607 C Y
https://airheadparts.com/vw-part/air-cleaner-side-thermostat-spring-211-129-607-c/ _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Sat May 20, 2023 1:43 pm Post subject: Re: 1971 DP 1600 - Air cleaner |
Does anyone know the part # of the 1971 air cleaner setup? |
kingkarmann wrote: |
Hopefully its correct. 211-129-607 C Y |
Yep, that's the number that was on the air cleaner from my '71; HTH
Posted: Sun May 21, 2023 6:28 am Post subject: Re: 1971 DP 1600 - Air cleaner |
Thank you very much for the information!
Dustin |
