jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Sun Apr 29, 2007 11:45 am Post subject: new bosch svda dizzy with 30/31 carb |
can anyone tell me which vacuum port to use with the 30/31 carb. there are 3 on this carb _________________ www.cultwagen.com |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Sun Apr 29, 2007 12:01 pm Post subject: |
The port for vacuum advance is the one pointing out to the side on the left side of the carb. This is true for any stock-type Solex carb.
Note this - If this is a standard H30/31, then it won't provide enough vacuum to pull an SVDA's diaphram around much. So your distributor will act mostly like an 009. ( Aircooled.net sells a modified H30/31 and a tweaked SVDA are supposed to function together properly. )
How do I know this about the H30/31? Last spring I did testing and wrote a report with pictures about it. You can find it here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=185095 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76899 Location: Sneaking up behind you
Posted: Sun Apr 29, 2007 12:51 pm Post subject: |
A stock 034(SVDA) and H30/31 do not work together. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Apr 29, 2007 7:51 pm Post subject: |
Glenn wrote: |
A stock 034(SVDA) and H30/31 do not work together. |
but would it be worse the the 009? _________________ www.cultwagen.com |
Glenn Mr. 010
Posted: Sun Apr 29, 2007 7:53 pm Post subject: |
I had a Solex H30/31PICT on a bone stock 1600 and tried a 009, 034 , 019 and 010 and found the 019 and 010 were better than the 009 or 034.
Member #1009
#BlueSquare |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Apr 30, 2007 11:47 am Post subject: |
This has been covered - vac signal is weak - so its like running an SVDA without the vacuum line connected. The proper Vac advance dist has a larger vacuum can to work with the lower vac signal - Aircooled.net also has an SVDA that is set up to work with the carb. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue May 01, 2007 12:46 pm Post subject: |
so what would be the best set-up for my car?
my motor is a 1600SP
should I run the SVDA or 009 with a different carb. (34 pict)
the 30/31 carb with a stock dizzy. _________________ www.cultwagen.com |
dog_jr911 Swamp Donkey Assistant
Posted: Tue May 01, 2007 1:15 pm Post subject: |
i would never run an 009. just get some dual kads....will run well with SVDA! _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
Glenn Mr. 010
Posted: Tue May 01, 2007 2:02 pm Post subject: |
jroymcd wrote: |
the 30/31 carb with a stock dizzy. |
Run a 019...i liked how my 1600DP with Solex H30/31PICT ran with it. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 01, 2007 3:33 pm Post subject: |
Glenn wrote: |
jroymcd wrote: |
Run a 019...i liked how my 1600DP with Solex H30/31PICT ran with it. |
Got any for sale? PM me _________________ www.cultwagen.com |
Glenn Mr. 010
Posted: Tue May 01, 2007 3:35 pm Post subject: |
Not at the moment, but there's a few in the classified. _________________ Glenn
Member #1009
#BlueSquare |
