kidosteele Mr. Butthurt
Joined: July 14, 2004 Posts: 116 Location: Saint Petersburg, FL
Posted: Tue May 15, 2007 7:39 pm Post subject: question about installing a 12v item in a 6v car |
ok i have a stereo that i want to put in my beetle and i don't really wanna convert to 12v, i have ran all the wires and have put a 12v gel cell battery in the back with the 6v battery... the only problem i'm seeing is charging the 12v batt. i dont want to have an extension cord to my car every night....
now the question.... has anyone every used a bike light generator as a charging system, off the motor or off the wheels on the car already? if so how should i go about doing that
or should i not waste my time and just convert to 12v??
thanks any help will be good help |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Tue May 15, 2007 8:42 pm Post subject: |
Unless you have some huge amp etc you wont need to charge the battery every night. If you wire the radio so you can shut it completely off ( loose your presets) once a week of so is all you'll need. Radio shack and other places used to sell a 6/ / 12v power inverter that worked OK.
I don't know if they still do but I see them pop up all the time on E/B & our classified on the Samba.
(edit) Like this one
http://www.thesamba.com/vw/classifieds/detail.php?id=422194
Better buy it quick.
In the long run I think 12v is less headaches for a semi daily driver. I've converted all my old cars even the split window. _________________ Midwest Autosavers, Inc. Woodstock, IL |
bugntjw Rants Lurker
Joined: February 11, 2004 Posts: 698 Location: Purgatory
Posted: Tue May 15, 2007 9:29 pm Post subject: |
I would convert to 12v. Worried about the look, get a Porsche gernerator. I would put an Alt. in it, though. _________________ A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Wow...that was fun!"
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together. |
Posted: Wed May 16, 2007 4:42 pm Post subject: |
DrDarby wrote: |
In the long run I think 12v is less headaches for a semi daily driver. I've converted all my old cars even the split window. |
good looking out.
the only problem with that one is that it's only 3amp and i need atleast 15amps |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu May 17, 2007 2:09 am Post subject: |
Here's a more modern (and expensive) inverter that puts out more juice. 10 amps continuous with 15 amp peaks. I think it would work OK if you used this in tandem with your gel battery. It's either this or convert to 12V.
http://www.powerstream.com/dc6-12.htm
