westcoastbullies Samba Member
Joined: July 02, 2002 Posts: 302 Location: DIABLOS SHADOW
Posted: Wed Aug 21, 2002 11:49 pm Post subject: cooling dilemma |
I have a 65 Westy and 1500 single port, that after being loaded with camp gear,kid,dog, wife, etc.., likes to run HOT. Everyone I ask locally has a different opinion of cooling tecnics...I have a new external cooler floating around and also most of a doghouse..also is there a way to tap into the block (oil pump) without machining? please the more opinions or facts - the better! thanks |
flat4 Samba Member
Posted: Thu Aug 22, 2002 8:05 am Post subject: cooling dilemma |
Your best bet is to convert to the doghouse offset oil cooler. stock on dual ports but i think you can convert your SP engine. you can add a full flow oil pump that doesn't require machining but will (I believe) require you to split the case just enough to pull the old pump out. Check out type2.com for other info from more knowledgeable sources. but remember, you are trying to push a heavy ass Brick full of gear with a tiny engine so its gonna make some heat!!
Happy Motoring. Gary |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu Aug 22, 2002 9:18 am Post subject: cooling dilemma |
Not that I doubt what you're saying, but how are you determining that it's overheating? Oil temp? Subjective judgment? Just curious. |
IndianaVWKid Samba Member
Posted: Thu Aug 22, 2002 11:53 am Post subject: cooling dilemma |
You don't have to split the case a for a full flow, it's simple...I have a tech on my site, for a full flow with pump, but realy it's the same thing...without the pump. The only bad thing about the full flow with dual outlets, is the fact that you are now running oil in a hose that could leak, to a differnt part of your car...meaning, if you spring a leak, well, let's just hope you don't! But I must admit, with the larger gears in the pump...Well, WOW! oil pressure has never been better, and i notice a difference just from that! When she's hot, she's still got pick up!
try Running higher octane fuel if you already aren't. |
Posted: Fri Aug 23, 2002 12:28 pm Post subject: cooling dilemma |
Scat and CB Performance make full flow pumps. i know for sure that CB do a pump with an inlet and outlet allowing external filter and cooler to be installed. |
Posted: Sun Aug 25, 2002 9:20 am Post subject: cooling dilemma |
Any Updated on what your doing with your bus? Just curious to see if you came across any good news. Peace! |
Posted: Mon Aug 26, 2002 8:11 pm Post subject: cooling dilemma |
I drove a '69 Westy with the whole family and camping gear for nine years...the doghouse cooling system is your answer (although the original '65 system should also work fine if the parts are functioning properly). External oil coolers will not necessarily solve an overheating problem, if your timing is incorrect, parts are worn out, etc. The heads could be running hot for a variety of reasons. I've never run anything but the stock oil pump and cooler and they work fine as intended. Have a German mechanic check your compression, ignition timing, etc. |
Posted: Mon Aug 26, 2002 9:42 pm Post subject: cooling dilemma |
well thanks alot everybody!! I went with the doghouse, and I hooked up the oil temp gage again...it stays at about 210 (warm? but at least Ill quit losing my hair over it)..also adjusted valves and timing again...thanks again for the support! |
Posted: Tue Aug 27, 2002 3:52 pm Post subject: cooling dilemma |
My '69 Westy would sometimes run as hot as 225 degrees in the summer, climbing a steep mountain grade or driving against a strong wind. Some of the European VW books say that is normal and I certainly didn't ever have any problems. Once it exceeded 225 degrees, I would pull over for a break and let the motor cool down. Also, I recommend 20W50 oil in the summer and 92 octane (96 RON) gasoline. In the winter, I go back to 5W30 and 87 octane...just in case. |
