DeMinimis I Eat Glue
Joined: November 16, 2004 Posts: 1846 Location: Down in the pig mine
Posted: Thu May 17, 2007 3:44 pm Post subject: Dick & Jane Beam Question |
Ok, I know I should know this answer, but I don't. What is the measurement of a stock link pin beam (and where are you measuring it from)? I'm not sure if my beam is 9 or 10 over (I think its 9, but need to verify). Need to know as I'll be replacing my beam when going coilover. Thanks. _________________ Yes Virginia, beer can make you smarter.
'78 SB CEII In Progress. |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Thu May 17, 2007 6:56 pm Post subject: |
from what ive been using a stock LP beam is about 34 inches _________________ never forget 1-31-07 |
Nicksan Samba Member
I got 34" from tube end to tube end. I could be off around 1/4 inch or so. |
Posted: Thu May 17, 2007 6:58 pm Post subject: |
Damn U penguin, I almost killed myself fumbling around in the garage to measure an old beam I have. and you beat my post. |
Skidmark Samba Member
Joined: June 17, 2005 Posts: 2988 Location: Minden, NV
Posted: Fri May 18, 2007 8:28 am Post subject: |
Thanks for the help guys. One of life's little misteries is now solved. Now, I feel like leaving work to go measure my beam so I know what I've got (and finish up my front engine mount). Thanks again! _________________ Yes Virginia, beer can make you smarter.
Posted: Sat May 19, 2007 12:16 pm Post subject: |
Holy frick'n frick! I knew my beam was big, but at 47" from tube end to tube end, its enormous. I guess if I get a 10" over beam when I make the c/o switch, I'll be ok.
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Sat May 19, 2007 7:12 pm Post subject: |
you're measuring end to end of the beam and not including the trailing arms, right? your beam does not look like it's 15" over stock... _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
riNR Samba Member
Joined: June 28, 2006 Posts: 1223 Location: Whitby, Ontario, Canada
Posted: Sat May 19, 2007 9:37 pm Post subject: |
47" - 34" = 13"
Math 101
Posted: Sun May 20, 2007 9:04 am Post subject: |
Looks like Arnold needs to increase school funding down there. Yes, from tube end to tube end = 47". 2 1/8" dia too. _________________ Yes Virginia, beer can make you smarter.
Posted: Sun May 20, 2007 10:23 am Post subject: |
slight miscalculation. either way... _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Sun May 20, 2007 11:49 am Post subject: |
If it helps with the visulization, it is 30.5" from outside to outside of the top beam clamps. With my current front and rear arms, the front track is a bit wider than the rear. Its not going to stay that way, but that's how it is now. Will switch to a 9-10" wider c/o front beam with +4 arms and 3x3 rear arms. That should get things into correct proportion. _________________ Yes Virginia, beer can make you smarter.
