risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Sat May 19, 2007 8:02 pm Post subject: Progressive Weber 32/36 Intakes -Anyone know the difference? |
Putting a centermount progressive setup on my baja and have some questions....please don't offer chitty advice like "trash that pos weber" or "go for duals" or "good luck tuning that one". Thanks in advance!
Top intake & carb is about 10 years old, off a 1600cc dual port, empi brand I think. The other intake is a bit different. Notice the lower intake has longer runner tube. Any ideas on which one is better or what brand they are? Also, the weber has the port for vacuum and I can blow air thru it so I'm guessing that it works with a vacuum advance dizzy. I have three dizzys to choose from --009, 034 svda, and type k vacuum only--which one works best with this carb?
rterfert Samba Member
Joined: October 08, 2003 Posts: 1419 Location: Yuma Arizona
Posted: Sat May 19, 2007 8:16 pm Post subject: |
Someone may have shortened the runners on the black intake??....I have run Many of the bottom style manifolds
(I bought a 20+ lot of new ones years back and finally used/sold the last one)
IMO As long as the runners under the carb have two seperate holes rather than an open plentum......they all work the same....
The open plentum seams to loose a little on the lower end and has more of a stumble.
again, IMO I think becuase the air velosity is slower? |
Josh_crosson Samba Member
Posted: Sat May 19, 2007 11:41 pm Post subject: |
i think the one the carb is already hooked to is a holley intake for the bugapray. only thinkg i can come up with. |
sammyphsyco Samba Member
Joined: August 07, 2005 Posts: 1093 Location: Terry Cloyd's neighbor
risk Samba Member
Posted: Sun May 20, 2007 11:46 am Post subject: |
Yeah, I read those threads when I did the search. I'm gonna pull the carb to see if the intake is open plenum or not. Still trying to figure out which dizzy to use..... |
risk Samba Member
Posted: Tue May 22, 2007 6:42 pm Post subject: |
Pulled the carb and noticed that the guy I got this from had used a time sheet to make a carb gasket. Nice, very nice....
Intake on the right is cast that way, not ported out. Anyone had experience using either of these intakes?
Posted: Wed May 23, 2007 9:37 pm Post subject: |
As long as you have seperate throats for each barrel till it hits the cross section they should be/act like the same manifold.
As for the gasket (his rebuild kit) must have been a little vauge where it said paper gasket |
risk Samba Member
Posted: Thu May 24, 2007 8:59 am Post subject: |
the carb has a vacuum port .... can I use vacuum advance dizzy?? or am i stuck with 009? |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Sun Oct 04, 2009 5:35 pm Post subject: |
i searched a buncha and instead of starting a new thread ill resurrect this one...
is the vacuum signal from a weber 32/36 string enough for a german 034 svda?
id like to ditch my utoh nine
and am about to send my 034 to be redone ( finally )
and dont have the cash to go back to dual carbs yet. _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
mharney Samba Member
Posted: Sun Oct 04, 2009 6:08 pm Post subject: |
Yeah, it has plenty of vacuum for an SVDA. |
Posted: Mon Oct 05, 2009 5:22 am Post subject: |
THANKS MARK. _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
