vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Mon Dec 17, 2007 10:42 am Post subject: |
Diamond Hell wrote: |
I ran 15" Merc C-Class rims on my T25 Syncros for years without them coming off. It should be noted that I swapped rims a fair bit, too as I was running road and off-road tyres. I always ran them with standard steel nuts on standard 'lugs' (or studs in this country). |
i believe that, i think the person on here that did lose a wheel maybe had conical nuts. the stock nuts seemed...ok....but you could tell the ones loogy has with the merc seat and vw thread fit perfect and seated much better. to me it's cheap insurance. |
floggingmolly Samba Member
Joined: April 06, 2007 Posts: 1106 Location: San Diego, CA
Posted: Mon Dec 17, 2007 10:50 am Post subject: |
To me it's not a matter of cheap insurance, it's a matter of getting the right part for the job. Loogy has done learned me reel good about the difference between rim type and nut seating types. Ball seat needs ball nuts. _________________ '85 Wolfsburg Weekender |
vwlovr Samba Member
Posted: Mon Dec 17, 2007 11:00 am Post subject: |
floggingmolly wrote: |
To me it's not a matter of cheap insurance, it's a matter of getting the right part for the job. Loogy has done learned me reel good about the difference between rim type and nut seating types. Ball seat needs ball nuts. |
right, but if you have steel vw rims you have ball seats...just not the right size. |
Posted: Thu Dec 20, 2007 8:00 am Post subject: |
Gotcha _________________ '85 Wolfsburg Weekender |
brooklynvanagon Samba Member
Posted: Thu Dec 20, 2007 10:47 am Post subject: |
vwlovr wrote: |
Absolutely,
I have c class alloy mercedes wheels... using dough to make and impression and comparing the vw ball seat stock nuts, with the actual mold shows *clearly* go with Loogy. The actual seating surface is very important. Thanks to Loogy for his great service as well. He also has wheel locks, rear studs, and front hub conversion studs. I bought all that stuff, lol and because of the huge supply of 16" wheels I will still save $ over buying a set of used vw carat wheels. |
Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Thu Jan 22, 2009 10:30 am Post subject: |
Any updates, reports on these steel wheels? I sent out some pmails prior to making my purchase, but go zero replies.
Mercedes dealers were over 100.00 per wheel and it appears that Small Car purchased all the steel wheels offered by Tire Rack. Small Car bumped the price per wheel to 49.00, but they did cut the lug holes to work with stock Vanagon alloy lugs. I ordered five and await delivery......... |
Posted: Thu Jan 22, 2009 11:15 am Post subject: |
pachec wrote: |
... but they did cut the lug holes to work with stock Vanagon alloy lugs..... |
Wow! I would be very careful. From what I can gather, the use of tapered lug nuts is what got Mike (the fellow in this thread who had a wheel come off) in trouble. The issue is that the tapered lug nut would bottom out on the hub/shoulder of the stud giving a false torque reading while leaving the wheels slightly loose. And if SmallCar cut the holes even larger, as it appears on the picture on the web site, that would allow the lug nuts to move even closer to the hub.
Aftermarket tapered lugs might be okay since they have a slightly shallower reach than the factory alloy lug nuts, but I'm not sure.
I'm not saying this to spite SmallCar at all, I just don't want you to have the same experience as Mike did. Just check everything out carefully before setting out on the road. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Thu Jan 22, 2009 12:43 pm Post subject: |
Ok, following Loogy's advice.......I contacted Small Car and it turns out they only cut them when you order them. I changed my order to 'uncut' so I will be ordering the lugs Loogy recommends.
They assured me that the lugs make full contact, etc., but I still went with the uncut version. The white van, under the 229.00 wheel package on Small Car website, shows their delivery van, which runs parts, daily, with the wheels cut to accept stock VW alloy wheel lugs.
Loogy, can you please resend lug email you sent earlier this week? I'm ready to order........
Thanks |
Posted: Thu Jan 22, 2009 1:22 pm Post subject: |
pachec wrote: |
The white van, under the 229.00 wheel package on Small Car website, shows their delivery van, which runs parts, daily, with the wheels cut to accept stock VW alloy wheel lugs. |
Well, maybe I'm wrong about the situation that Mike had. Either way, I would still be inclined to do my own checking before assuming that it's all okay, if someone decided to go with the cut version that is. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Nov 24, 2009 12:42 am Post subject: |
Sorry guys, I just spotted this thread.
I've been running the 16 x 7 ET37 C Class rims on my daily driver for the better part of a year. I used the Vanagon wheel nuts and bolts to mount the whole shebang, 205/55- 16 Michelins and all and its a great setup!
There is very little clearance from the sidewall to the upper control arm but they don't rub so...
I re-tightened after a week and that was the last time I've touched them except to check tire pressures.
I picked up another set of Craigs List for my other van. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Vernthebusdriver Samba Member
Posted: Thu Nov 26, 2009 12:46 am Post subject: Eurovan /snowwheels/Tirerack |
I am running Eurovan tirerack snow wheels on my 87 Syncro with a 6mm spacer front and back. It all fits and handles OK but I need a source for longer studs (65 mm ) ? |
vwlovr Samba Member
Posted: Thu Nov 26, 2009 2:54 am Post subject: Re: Eurovan /snowwheels/Tirerack |
Vernthebusdriver wrote: |
i got longer ones from van cafe, they have 72mm ones. they are longer than i needed, but still do the trick. |
youremyboyblue Samba Member
Joined: December 01, 2009 Posts: 38 Location: whereever my tdi syncro will take me!
Posted: Fri Dec 11, 2009 8:54 am Post subject: best deal? |
using http://www.primepartssuperstore.com , the best price i'm coming up with is 98.40/wheel.
does anyone else have any suggestions for finding the best deal on five of these wheels?
additionally, is there a recommended method to retain the finish? |
fredn Samba Member
Posted: Thu Sep 23, 2010 10:44 pm Post subject: Re: back to 16's |
mcsyncro wrote: |
i decided to go back to 16" wheels and tires for that more off-road look.
thought i'd show 'em off
Really sorry about resurrecting such an old thread,(although it is a good one) but any idea where I can find that spare tire rack? sweet looking ride by the way. (compliment years too late)
Anyone who can help thanks
Fred |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Thu Sep 23, 2010 11:01 pm Post subject: |
It looks a lot like a fiamma bike rack but not a vanagon version. |
Masta Shake Samba Member
Joined: October 29, 2010 Posts: 198 Location: San Diego, CA
Posted: Mon Nov 15, 2010 11:06 am Post subject: |
Just got off the phone with 2 local MBZ dealers (San Diego). The wheels in the OP are now $134 each...
Apparently in JAPAN there is a MBZ steel wheel part number 203 400 16 02 that is a 16" with ET31. The dealer's listing did not say the wheel width however. _________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship". |
Worms Samba Member
Joined: May 19, 2009 Posts: 279 Location: Whangarei, New Zealand
Posted: Mon Nov 15, 2010 4:10 pm Post subject: |
Masta Shake wrote: |
Apparently in JAPAN there is a MBZ steel wheel part number 203 400 16 02 that is a 16" with ET31. The dealer's listing did not say the wheel width however. |
Yup, I got a set from Singapore . NZ$900.
they are 16" x 7.0" I have 215 65 16's on, and they are great. My steering is actually lighter now than with 205/70/14's!
They are very nice wheels, I painted them with spray on silver Hammerite smooth. look mean. The bolt holes are good for 14mm, They require ball seats.
Allan. |
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Fri Nov 26, 2010 12:52 pm Post subject: |
what is the narrowest 16 or 15 inch benz steel wheel that will fit? part number? is the w203 chassis the only appropriate model for donor steel wheels, without using spacers? |
Worms Samba Member
Posted: Sat Nov 27, 2010 1:18 am Post subject: |
there are 15x6, and 16x6.5 I've been told.
Some newish Vito's had 16x6.5's, but with a much higher offset - 60??? I was going to get a set of them, and have the centre removed, machine some of the lip of the back, and reweld them in - cheap!.
No idea of part numbers for the other wheels. |
Tmcd Samba Member
Joined: April 24, 2010 Posts: 16 Location: Shawnigan Lake, Vancouver Island, BC Canada
Posted: Fri May 13, 2011 10:45 pm Post subject: |
Will 225/75/16 tires on merc 16" x 7 steel ET37 rims fit on my stock '87 2wd Westy? Got the rims for $20 for all 4 and have found a set of michelin ltx's for cheap!
Thanks! |
