cityside Samba Member
Joined: October 12, 2006 Posts: 84 Location: monterey bay
Posted: Fri May 25, 2007 12:07 pm Post subject: batteries no charge |
OK all you smart guys. Please spend a minute helping a dumb guy avoid spending the whole three-day weekend grumbling and cursing.
Main battery is doing great but my two auxiliary batteries (in "Patience," my '89) won't hold a charge and won't recharge when the engine is running. They will, however, take a charge from trickle charger when I plug in to outside power and will hold said charge for a few days.
The first auxiliary battery, under the driver seat, powers the stereo and apparently the door locks and alarm--or, i should say, it powers them occasionally.
No, I haven't tested the batteries yet, but i will tomorrow. And I'll be checking all the connections, of course. But if the Waldemars and Buckos of the westy world have a tip or two to speed me on my mission, I'd be glad to hear them.
Thanks in advance. You're the best _________________ ----------------------
There are only two things in life, ... but I forget what they are.
'89 westy
'90 325ci |
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Fri May 25, 2007 12:30 pm Post subject: |
my .02's is a grounding issue.
I really not that versed in electrics...
If it tingles the fingers, its hot...
Big tingle...
Nothing better than being tossed across a photo studio when a 2400 w/s pack lets go ist full charge with your finger tips in the way. _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Fri May 25, 2007 12:58 pm Post subject: |
How did you wire up these two aux batteries? Did you use a schematic that was posted here on this site? Did you use a relay?
If you have 3 batteries tied into your single alternator, that alternator is going to work overtime to charge all 3 of them. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Posted: Fri May 25, 2007 1:04 pm Post subject: |
Previous owner installed the extra batteries about four years ago, and I presume he did not go to any extra expense. there are relays all over the place and I haven't sorted them out yet. _________________ ----------------------
'89 westy
'90 325ci |
bucko Samba Member
Posted: Fri May 25, 2007 1:14 pm Post subject: |
It would be of great help if you could snap a photo of the wiring of these aux batteries. This way we could study them to see if the problems in this wiring.
A search on "dual batteries" or "auxillery battery" should yield many threads on this. There are also several pictures and schematics to be found on this as well here on previous threads.
Here is one:
singlewc Samba Member
Posted: Fri May 25, 2007 1:45 pm Post subject: Re: batteries no charge |
cityside wrote: |
OK all you smart guys. Please spend a minute helping a dumb guy avoid spending the whole three-day weekend grumbling and cursing. |
Simple. quick check, before you get dirty, and start to grumble and curse, <g> is to do whatever you do, to be thinking that everything is charging, such as relays, or switches that you would know about.
If you are now running the engine, and thinking that all the batteries are being charged, measure the voltage at each battery. Gotta be 13.5V, or they won't charge. If its 13.5V and maybe a tad more, they should be charging, and you have battery issues.
If any of them are less than 13.5V, now its time to dig into the wires, and get to that cursing thing
No solutions there, but an easy test to find out which direction to go it.
John |
Posted: Fri May 25, 2007 7:38 pm Post subject: |
You answered the question I was trying to ask. _________________ ----------------------
'89 westy
'90 325ci |
backcountrymedic Samba Member
Joined: February 17, 2006 Posts: 583 Location: Monterey, CA
Posted: Sat May 26, 2007 3:02 pm Post subject: |
I seem to remember when seeing your aux. battery setup that it was a bit oddball. Seems like your best bet would be to return the wiring setup to as stock as possible, and then make any mods you're interested in. That way you can track any problems down a bit easier.
Cheers!
-Jared _________________ No need to bear the weight of your worries, you let them all fall away...
Sector 9 longboard
Kona Kikapu Deluxe MTB
Novarra Big Buzz
Electra Cruiser
'01 Toyota Tacoma 4x4 |
Posted: Mon May 28, 2007 4:13 pm Post subject: |
As singlewc suggested, I tested and found power not getting through to the auxiliaries except from the trickle charger.
Haven't had a moment to decipher the connection from main battery to auxiliary yet.
Would "weak" alternator cause this type of problem? _________________ ----------------------
'89 westy
'90 325ci |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10075 Location: Abiquiu, NM, USA
Posted: Mon May 28, 2007 4:47 pm Post subject: |
It could, but if it were, your primary battery would also show a low voltage while charging. Your system should have some kind of device to isolate the batteries when the motor is stopped. This device will put all batteries' positive poles in common while the motor is running, and the voltage measured under charge will be roughly equal at all the batteries while the motor is running. So if it was a weak alternator, your primary battery would be in the same low-charge state as your auxiliaries. The fact that your primary gets charged and keeps its charge well enough to start the motor, and the others can take and hold a good charge from your grid charger, suggests the batteries are all OK but aren't being ganged up while the motor is running. So it's the isolator system that seems most suspect. But we don't know yet what exactly you're using. There are many ways to do it. It could also be as simple as bad connections at the auxiliary batteries, or their ground cables. |
Posted: Mon May 28, 2007 7:18 pm Post subject: |
Just finished installing the Yandina 100 battery combiner that msinabottle has installed in Winston (Rob- thanks for your help and advice). Pretty simple install, and works like a charm! Links the batteries up when running, or when plugged into the trickle charger; isolates them when everything's off. Cityside, if you picked one up, it'd be a simple thing to get your system up and running again, even if you didn't want to redo your whole setup. I'd be more than willing to give you a hand at the upcoming campout. If you do decide to order the combiner, you should call vs. trying to order online. Their website isn't very user-friendly for online ordering. Once I made the call, I had the device in a bit less than a week.
Cheers!
Sector 9 longboard
Novarra Big Buzz
Electra Cruiser
Last edited by backcountrymedic on Tue May 29, 2007 6:53 am; edited 1 time in total |
msinabottle Samba Member
Posted: Mon May 28, 2007 9:26 pm Post subject: Yandina! |
It's Rob, to my friends--so I'm Rob to everybody here but one person, and he doesn't probably know who he is. Only person on the Samba who ever flamed me...
Yeah, that thing's wonderful. Once I realized what it was doing, I cheerily dismantled the entire VW system and just did it all with 21st century technology. It's really neat to see both batteries charging after even short drives--and the Yandina also takes the DC current from the Schumacher battery charger I've got hooked up to the hidden socket under the sink that charges and tops off both batteries whenever Winston's hooked up to city power.
I wish I could claim that I invented ANY of these brilliant ideas--but I didn't. Just made what other people suggested work, and wrote how.
Posted: Tue May 29, 2007 6:44 am Post subject: |
Quote: |
Only person on the Samba who ever flamed me... |
Who would do such a thing? Time for a blanket party!
Cheers!
Sector 9 longboard
Novarra Big Buzz
Electra Cruiser
