bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Sat May 26, 2007 4:53 pm Post subject: Fuchs refinishing (polishing and restoration) |
I've heard a lot of opinions on this subject, lets hear some more. Who have you had the best results with? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat May 26, 2007 6:57 pm Post subject: |
I just did my spare rim nad I found a couple of time savers. First use Aircraft stripper on the painted parts. A couple of coats should do it. Next lightly sand with 800-1000 grit sand paper with WD40 as a lubricant. Clean and use "diamondbrite polish", available at Lowes next to the truck toolboxes, to polish. I find a regular grinder type buffer works well. I finish with a "powerball" and touch up by hand. Will shine like chrome.
This is the stuff, I have tried them all. get you some......
http://www.dawsbetterbuilt.com/bbt/polish.html _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
bugginmiami Samba Member
Posted: Thu May 31, 2007 3:41 pm Post subject: |
Pretty sure he was looking for names. Al Reed and Alex Magro are both on here and come pretty highly recommended. Magro did the wheels on my bus and they look good. AL Reed I think is higher end, more detail more money.... _________________ * ---www.volksblast.com--- *
* -- South Miami - Feb 12th 2017 *
johnnypan wrote: |
Never mess with a cat who smiles for his mug shot..he gives way less of a fuck than you do.. |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Thu May 31, 2007 4:04 pm Post subject: |
Mag Masters in CA polished mine. |
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Fri Jun 01, 2007 6:40 am Post subject: |
maybe some folks who did there own could chime in with some techniques, of what worked good for them.
Don't they have a clear powdercoating, that in time leaves that white milky haze?
also what is an average dollar amount (per wheel) to have alex or al polish? |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Jun 01, 2007 12:28 pm Post subject: |
roberto wrote: |
Paint stripper takes the black paint off. Easy Off oven cleaner takes the clear annodizing off (the stuff that goes hazy) After you do both of those you have raw aluminum. Sand paper, polish, elbow grease.....
bmtx Samba Member
Posted: Fri Jun 01, 2007 9:43 pm Post subject: |
scottvw wrote: |
Thier website is gone. Does anybody have a number for them? |
808-56 Samba Member
Posted: Fri Jun 08, 2007 11:09 am Post subject: PORSCHE FUCH REFINISHING |
POLISHING A FACTORY FUCH RIM-STRIP RIM BY SAND BLASTING RIM USING GLASS BEAD. SECOND STEP-USE A VARIABLE SPEED FLEX SHAFT DREMMEL STYLE TOOL TO CLEAN UP AROUND THE SPOKE AREA USING 240 GRIT ON A STRAIGHT BARREL WITH GRINDERS GREASE (REMOVE ALL FACTORY SAND MARKS) . THIRD STEP-SAND RIM USING DRY SANDPAPER USING THE FOLLOWING GRITS IN SEQUENCE 60, 80, 100. FOLLOW UP WITH WET SANDING USING 220, 320, 400, 600, 1000, 1500. FOURTH STEP- POLISHING, I USE A VARIABLE SPEED DIE GRINDER (MAKITA) @5500 RPM. USE A SPIRAL SEWN WHEEL WITH RED ROUGE (TRIPPOLI COMPOUND). FOLLOW UP WITH USING A CANTON FLANNEL WHEEL WITH WHITE ROUGE. REMEMBER TO DRESS THE BUFFING WHEEL WITH COMPOUND AS NEEDED AND TO RAKE THE BUFFING WHEELS TO GET RID OR EXCESS COMPOUND . I LIKE TO USE CALIFORNIA CUSTOM ORIGINAL PURPLE POLISH TO UPKEEP MY RIMS. THESE ARE THE STEPS THAT I HAVE USED ON POLISHING OVER 125 FUCH RIMS. |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Jun 08, 2007 12:31 pm Post subject: Re: PORSCHE FUCH REFINISHING |
808-56 wrote: |
Damn................................. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
bmtx Samba Member
Posted: Fri Jun 08, 2007 10:26 pm Post subject: |
DOUBLE DAMN.......any pics? |
David Samba Member
Joined: June 29, 2004 Posts: 2027 Location: Raleigh, NC
Posted: Tue Sep 11, 2007 11:54 am Post subject: |
Does anyone know how bad a rim can be before they can't be repaired, fixed up and polished/painted?
How bad of curb rash, or pitting can be brought back to obtain a great wheel?
I just got a pair of 5.5s and I'm looking for advice.
I don't think mine are too far gone... I'll post pics in a bit.
Do both Al Reed and Alex Magro do repair?
Edit for Pics:
_________________ Cheers,
Dave
*October '54 Ragtop
El Guero Samba Member
Joined: January 03, 2004 Posts: 1197 Location: I.E. Y-QUE
Posted: Tue Sep 11, 2007 7:08 pm Post subject: |
get a hold of Al Reed he does repairs _________________ Praise the Lowered... |
Posted: Tue Sep 11, 2007 7:50 pm Post subject: |
Double check with Mag Masters. They do excellent work and probably cheaper than Al or Alex.
More than likely you can sand some of that curbing away and it will blend right in. |
Posted: Tue Sep 11, 2007 8:12 pm Post subject: |
scottvw wrote: |
Double check with Mag Masters. They do excellent work and probably cheaper than Al or Alex. |
That's true...............and they (Mag Masters) can repair that kind of damage back to perfection. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
David Samba Member
Posted: Tue Sep 11, 2007 10:04 pm Post subject: |
Thanks guys.
I'll give Mag Masters a call.
For ppl that come here after the fact:
MAG MASTERS
1419 East Edinger
Santa Ana, CA 92705
(714) 541-9777
Fax (714) 541-9773 _________________ Cheers,
Dave
*October '54 Ragtop
ratlookvw Samba Member
Joined: June 21, 2004 Posts: 1809 Location: midnight train to GA
Posted: Wed Sep 12, 2007 10:41 am Post subject: magro |
just pulled my deep 6's out and my 4.5 for Alex. he is very fair for the work he does. hope to have them back for bug jam! _________________ If the RV Hut is a rockin, don't come a knockn'
57 Panel, 66 highroof panel, 65 Notch, 59 Vert, 61 Vert, 1969 Fridolin, 'Reggie ' 66 RV, 65 Pipe Truck, 65 RHD T-34, 70 dbl slider panel, 1969 Deep sea green sunroof automatic square, the greypoop-on, and a shit load of wheels! |
Posted: Wed Sep 12, 2007 11:51 am Post subject: Re: magro |
ratlookvw wrote: |
just pulled my deep 6's out and my 4.5 for Alex. he is very fair for the work he does. hope to have them back for bug jam! |
I don't know what these guys charge, but I put two solid days of work into doing 4 wheels. Not to mention the money spent buying the polish, sandpaper and $40 sander. I just like trying to do stuff myself. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Wed Sep 12, 2007 12:33 pm Post subject: |
Glenn's Wheel Polishing here in Tampa is getting quite the reputation for their work. They started out simply polishing wheels but now they straighten, and can weld up curb damage and throw it in a big lathe to true it back up before polishing. May save you some shipping if the other guys are in Cali. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
sweetlokin66 Samba Member
Joined: November 15, 2006 Posts: 1220 Location: Luftwagenville, FLDuh
Posted: Wed Sep 12, 2007 2:43 pm Post subject: Re: magro |
KILLERWATT wrote: |
ratlookvw wrote: |
They done yet? _________________ Follow IG for more content @greyarearacing
Turbo type 4
http://shoptalkforums.com/viewtopic.php?f=3&t=134157
66 NA hard top
****Insert event here**** |
