jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Sat May 26, 2007 6:52 pm Post subject: oil leak |
Ive noticed a little oil puddle on my engine tin. left side of the motor under the distrubutor. where should i check first? would it be safe to make a 200 mile trip? lost about half a quart over the last month. _________________ www.cultwagen.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76899 Location: Sneaking up behind you
Posted: Sat May 26, 2007 6:53 pm Post subject: |
It could be coming from the distributor or the fuel pump. Or it could be the oil cooler is about to let go. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat May 26, 2007 6:57 pm Post subject: |
I was getting ready to go to a show in the morning. I was going over the car to make sure its ready when i noticed it. should I make the trip? cleaned it so i can try to see where its coming from but running out of time. _________________ www.cultwagen.com |
Glenn Mr. 010
Posted: Sat May 26, 2007 6:58 pm Post subject: |
I can't say.
Stop after 20 minutes and see if its still leaking. Minor leaks are OK to drive with. _________________ Glenn
Member #1009
#BlueSquare |
Randy in Maine Samba Member
Posted: Sat May 26, 2007 7:05 pm Post subject: |
Could be the O ring that is on the distributor shaft.
You can probably buy one at the show. |
Posted: Sat May 26, 2007 7:15 pm Post subject: |
Glenn wrote: |
I can't say.
Stop after 20 minutes and see if its still leaking. Minor leaks are OK to drive with. |
I will be in a caravan with about a dozen cars. we are making a few stops on the trip up. i will cheak it every time. seems minor. this is the first long trip in this car. motor only has 2000 miles on it. I did just replace the dizzy. _________________ www.cultwagen.com |
74 Thing Samba Member
Posted: Sat May 26, 2007 7:39 pm Post subject: |
Might be the oil pressure sender. Have fun at Sac |
Posted: Fri Jun 01, 2007 11:08 pm Post subject: |
so its deffently the oil cooler. anybody know what size the two nuts are on the bottom of the oil cooler? its a non doghouse 1600 SP motor. _________________ www.cultwagen.com |
