LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri May 03, 2019 8:55 am Post subject: Re: What did you do for your Bus today? |
So you get the seats too for $1? |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Mon May 06, 2019 1:03 pm Post subject: Re: What did you do for your Bus today? |
I took my 1959 Double-Cab out for a brief spin on the nearby freeway crossing over the swollen and flooding Missouri River just west of St. Louis, MO.
Then a quick stop in a local park for a shot or two. It was an overcast day so the paint job couldn't really show itself off as nice as on a sunny day.
An uneventful and fun time together...
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
EZ Westy Samba Member
Joined: July 12, 2004 Posts: 23 Location: Pennsylvania
Posted: Thu May 09, 2019 1:04 pm Post subject: Re: What did you do for your Bus today? |
Pulled the engine in my Single Cab this morning to more easily address
some maintenance/problem issues with it. Such as the starter (problem),
axle boots, re-torquing heads, fuel lines from tank, gear oil top off, general
cleaning, clutch and accelerator cable greasing, etc...
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Thu May 09, 2019 6:56 pm Post subject: Re: What did you do for your Bus today? |
BulliBill wrote: |
Bill Bowman |
That sounds just about perfect. _________________ nothing |
BarryL Samba Member
Posted: Fri May 10, 2019 11:43 am Post subject: Re: What did you do for your Bus today? |
EZ Westy wrote: |
Pulled the engine... |
That look to be a pretty together engine with not a lot of grime, leaks, and road mess. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri May 10, 2019 5:32 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
EZ Westy wrote: |
just needs some proper heater boxes _________________ regards
Uli
BarryL Samba Member
Posted: Sat May 11, 2019 10:29 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
just needs some proper heater boxes |
Sheesh, fer sure. Full-on shroud air going nowhere. I overlooked that part. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon May 13, 2019 7:52 am Post subject: Re: What did you do for your Bus today? |
Added a new horn button to my '62 Flipseat
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
BarryL Samba Member
Posted: Mon May 13, 2019 6:42 pm Post subject: Re: What did you do for your Bus today? |
My '65 driver door after being opened a billion times was just too worn out to open from inside or outside. I had a door lock/latch from a low mile bus that had tipped over onto the driver side and the lock latch was bent so bad I had never considered using it. I didn't feel like trying to fix it but since people have brought back busses on here from vitually dust I figured ashamed if I didn't try.
I don't have the before picture but after 2 days of trying every conceivable holding and bending jig and grip I got it straightened out and it's like new mechanically.
Here's the old worn inside pull and outside push contact points.
Here's the replacement one from tipped over bus...no wear at all...yay...a sow's ear turned into a silk purse.
BarryL Samba Member
Posted: Tue May 14, 2019 6:43 pm Post subject: Re: What did you do for your Bus today? |
These cracks have been bugging me on my '65's driver's door lower hinge so today while the door was opened up I thought I'd try to slow down the cracking.
I'm the world's worst welder but I think I managed to cross a couple places with molten steel.
Is that inside structure the "extra strengthener" that VW added in January 1965 or is there something else? |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed May 15, 2019 8:15 am Post subject: Re: What did you do for your Bus today? |
Cargo doors are mostly sorted
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
silkvw Samba Member
Posted: Wed May 15, 2019 7:04 pm Post subject: Re: What did you do for your Bus today? |
[quote="BarryL"]These cracks have been bugging me on my '65's driver's door lower hinge so today while the door was opened up I thought I'd try to slow down the cracking.
I'm a little late in saying, but some folks drill a small hole at the end of the crack, to keep it from continuing. Your welding may be all you needed. _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
silkvw Samba Member
Posted: Wed May 15, 2019 7:14 pm Post subject: Re: What did you do for your Bus today? |
Erik G wrote: |
crofty wrote: |
the sun goes on top |
OK, I give up. Where is your ignition switch?? _________________ '64 single cab Big Bend Bus Bash 2015 '16
Posted: Wed May 15, 2019 7:17 pm Post subject: Re: What did you do for your Bus today? |
silkvw wrote: |
Erik G wrote: |
crofty wrote: |
OK, I give up. Where is your ignition switch?? |
Locking column? _________________ nothing |
Posted: Thu May 16, 2019 7:04 am Post subject: Re: What did you do for your Bus today? |
cdennisg wrote: |
silkvw wrote: |
Erik G wrote: |
crofty wrote: |
Locking column? |
Yeah, locking column. _________________ Your Vanagon sucks, Stop waving at me.
thom Samba Member
Posted: Sat May 18, 2019 3:25 pm Post subject: Re: What did you do for your Bus today? |
Finally broke down and bought a sander with a vacuum port - should have done this years ago; sanding is virtually dust-free now.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
nzvwfan Samba Member
Joined: January 07, 2006 Posts: 145 Location: New Zealand
Posted: Sun May 19, 2019 11:19 pm Post subject: Re: What did you do for your Bus today? |
Great sanders but they can turn straight panel wavey pretty quick |
thom Samba Member
Posted: Mon May 20, 2019 6:08 am Post subject: Re: What did you do for your Bus today? |
nzvwfan wrote: |
Not if you start with a wavy panel! _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
