LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Jan 18, 2020 6:12 am Post subject: Re: What did you do for your Bus today? |
Wow I didn't know they were bolt on either, very interesting info and cool pic thanks vwbus55 .
Who.Me? wrote: |
vwbus55 wrote: |
I installed my OG widebed kit
Kit? So did all the widebed parts sit on top of the standard bed? I see screw holes that look like it's attached to the standard bed rear gate hinge holes. Is that so?
I've not seen one in person. I'd assumed that the standard bed and bulkhead were removed and the wide bed parts were permanently welded on in to replace them. Interesting if they're actually bolt-ons. |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sat Jan 18, 2020 7:07 pm Post subject: Re: What did you do for your Bus today? |
The 306 Kombi had been used to store V8 engines for the last few decades.
Although its shed status is likely why it survived the crusher, one of the unfortunate side effects from that vocation was that it seems more engines were stuffed in there than would allow the cargo doors to close properly.
Consequently, they were forced closed, which resulted in both of them being bowed out at the bottom by a few inches.
I suppose I could have replaced the B Pillar up past the lower hinge mounts, but thought I would see if I could engineer a fix on the original metal.
Only one of the lower hinge screws came out without stripping, so I had to drill out the stubborn one.
Unfortunately, in the process, I messed up the threads on that captive nut so I had to cut into the back of the B Pillar to access the captive nut plate to replace it with a good used one.
Funny how a simple job of removing a cargo door can become an all day venture.
I fashioned a lever out of 3/8 steel plate, drilled a couple holes to line up with the captive nut plate on the lower hinge mounts and commenced persuading the B Pillar to return to its original orientation.
I was reasonably successful.
Now it looks as though I have to go caveman on the doors to bend them back into shape. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Jan 20, 2020 8:56 pm Post subject: Re: What did you do for your Bus today? |
Started out for a drive and never made it out of the driveway. This bumper just is too ratty. I managed to get it somewhat stripped and on its way to being a bit easier to look at.
b4thea4 Samba Member
Joined: March 24, 2011 Posts: 48 Location: Beaverton, OR
Posted: Thu Jan 23, 2020 6:00 pm Post subject: Re: What did you do for your Bus today? |
Swapped out the white wheels for white and green wheels. New tires are 195/75 D load range, old ones were 205/70 95 load rating. Installed 3 hub cap clips too. Looking forward to seeing any difference in handling.
_________________ It's always Quattro season!
'65 Bus |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Thu Jan 23, 2020 7:17 pm Post subject: Re: What did you do for your Bus today? |
zozo wrote: |
As nice as the original paint is on your bus, those bumpers will look great with a fresh coat of silver-white paint. _________________ Brandon |
zozo Samba Member
Posted: Fri Jan 24, 2020 5:39 am Post subject: Re: What did you do for your Bus today? |
oakman wrote: |
zozo wrote: |
As nice as the original paint is on your bus, those bumpers will look great with a fresh coat of silver-white paint. |
Thank you. I hope so. Overall it's in pretty nice condition. Everything came off and apart without stripping or breaking any bolts. I've never hammer and dollied anything, so I thought I'd give it a try on those dents in the middle. I got rid of more than I expected, and am happy with it. The gouges in the metal are staying as well earned character scars. The uprights are pretty dented, and there are a few dents in the towel bar, but what the hell, it's a driver, not a show bus.
Posted: Thu Jan 30, 2020 8:43 pm Post subject: Re: What did you do for your Bus today? |
I commissioned my daughters boyfriend to create a Pink Floyd motif on the door cards in the cargo area of the 306 Kombi.
Not everyone's cup of Hemlock, but damn, these are cool!
- Daniel Boorstin |
oakman Samba Member
Posted: Thu Jan 30, 2020 9:18 pm Post subject: Re: What did you do for your Bus today? |
Riff Raff wrote: |
That's sweet!! I've always loved that album cover. _________________ Brandon |
Posted: Sun Feb 02, 2020 11:50 am Post subject: Re: What did you do for your Bus today? |
Acting on a consensus amongst posters in this forum, I bought a set of LT 195R15C Thunderers for the Kombi.
This is the stance they create.
I am pleased with them.
(I was fortunate enough to have 3 original to the bus rims in original paint)
They are slightly wider than the Nexen SV820, but still fit in the rear wheel wells.
They are a light truck tire, so have a robust enough sidewall to keep me in my lane I hope.
- Daniel Boorstin |
calsurfnative Samba Member
Joined: November 06, 2014 Posts: 161 Location: Lancaster ca
Posted: Sun Feb 02, 2020 12:15 pm Post subject: Re: What did you do for your Bus today? |
Attached accelerator cable and Lubed cable, made a rubber type boot for the clutch pedal,attached the mid mount,Trying to figure out how to remove the heater control knob out,making a tail gate table less the palm tree umbrella (On order) and chairs !!! Prepping the bike to match the bus also.
zozo Samba Member
Posted: Sun Feb 02, 2020 2:55 pm Post subject: Re: What did you do for your Bus today? |
Well, it’s an improvement, I reckon. I’m pretty happpy with the blades, but the overriders were just beat to hell. The back one had been bent in half, and the overriders were welded on when I got it. C’est la vie.
The color difference is the lighting or phone or whatever.
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun Feb 02, 2020 3:51 pm Post subject: Re: What did you do for your Bus today? |
Striped down the H-case that was in my '66 Singlecab, got to open it up & see what the fuck is going on in there ....... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
FCBulli59 Samba Member
Joined: November 27, 2019 Posts: 78 Location: Germany, Rheinland-Pfalz, Hunsrück
Posted: Wed Feb 05, 2020 2:37 am Post subject: Re: What did you do for your Bus today? |
...peeling the mango again and again
zozo Samba Member
Posted: Sun Feb 09, 2020 10:42 am Post subject: Re: What did you do for your Bus today? |
Working on reviving the paint on my ‘65.
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
zozo Samba Member
Posted: Sun Feb 09, 2020 4:56 pm Post subject: Re: What did you do for your Bus today? |
Trying to reclaim OG paint from under the poorly matched blauweiss that’s been there for more than ten years.
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
MikeHemingway411 Samba Member
Joined: November 11, 2018 Posts: 5 Location: Salt Lake City, UT
Posted: Sun Feb 23, 2020 9:53 pm Post subject: Re: What did you do for your Bus today? |
Today I spent scrubbing and wire brushing the bottom of 66 bus in-progress restoration. Removing unknown years of grime and rust from frame and bottom of cargo floor, so I can get some rust protectant on there to preserve what I can. Pulled that heater tube cover off and the tube came with it .
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Clara Samba Member
Posted: Thu Feb 27, 2020 12:02 pm Post subject: Re: What did you do for your Bus today? |
I did a post SStrip lube on my 15 window the other day.
About 900 miles since the 6k service including lube.
Adjusted the valves
Lubed the suspension.
This bus still has one tie rod and the drag link with zerk fittings on the ends.
The roads in my town are particularly bad. The back roads on the trip were better that the local roads. Apart from Mina Road and Tomki.
The bus had gotten squeaky, which bugged me.
I pulled the cab door handles off and smooshed grease into the lock boxes.
Reassembly, and a light smear of lube on the striker plates, and the cab doors shut very nicely, thank you.
I used the ginker can to lube the door hinges, cargo door lock boxes, engine lid hinges and latch.
It's my impression the suspension should be lubed every 3k miles. Yes I lube the suspension and adjust brakes at the 3K service.
It should be lubed more often if driven on bad roads.
adjust link pins at the 6K mile service.
This 1959 Transporter Service Booklet says to bring it to VW for a lube every 1200 miles:
1,200 miles lube:
bigger lube:
30k service:
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC |
