VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Thu Jun 25, 2020 4:45 pm Post subject: Re: What did you do for your Bus today? |
pyrOman wrote: |
Picked up a few bits for it!
That's pretty. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Thu Jun 25, 2020 6:45 pm Post subject: Re: What did you do for your Bus today? |
pyrOman wrote: |
Picked up a few bits for it! |
Aluminum case? |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Fri Jun 26, 2020 4:27 am Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
pyrOman wrote: |
Aluminum case? |
Indeed! _________________ Some people are so busy being clever they don't have time enough to be wise. |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Jun 26, 2020 4:58 am Post subject: Re: What did you do for your Bus today? |
Yes looking forward to that FAQ, I'd love to learn how to take mine apart and get all the tumblers sent out to key alike without braking anything
EverettB wrote: |
cdennisg wrote: |
BarryL wrote: |
Finished reconditioning my rear hatch latch/lock.
Anyone want play-by-play pics? |
That would be handy for future reference. |
Yes, please do a dedicated brand new thread on it and I can add it to the Split Bus FAQ afterward. |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
robin.richard Samba Member
Joined: February 17, 2012 Posts: 497 Location: V. Beach VA
Posted: Fri Jun 26, 2020 6:26 pm Post subject: Re: What did you do for your Bus today? |
Finally got around to rebuilding my 67 Westy's driver side RGB. It had considerable play even after replacing the lower outer bearing so I decided to open it up. I followed the rebuild thread and built a few tools along the way. It was much easier than anticipated. The culprit was the inner bearings, both upper and lower. The bottom one was toast. There was some very fine metal shavings in the bottom of the RGB. I cleaned everything, and then cleaned it again.
I
forgot to peen the inner hex nut so I had to take the spring plate and plug out a second time. Used a screw and nail puller. Worked like a champ both times. Dealing with the spring plate was by far the hardest part of it all. And I had to do it twice.
Took it out for a test drive and it was like night and day. I will likely change the trans fluid tomorrow... just because.
Thanks to Erric&Barb and BarryL for advice and inspiration to dig into it.
If anyone needs their RGBs rebuilt, don't be afraid. Just get in there!
Cheers
Rich _________________ Drive your bus! |
pyrOman Fire Master
Posted: Fri Jun 26, 2020 7:49 pm Post subject: Re: What did you do for your Bus today? |
Got more bits for it today! Webers and Panchos!
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 246 Location: Cambridge UK
Posted: Sun Jun 28, 2020 2:23 pm Post subject: Re: What did you do for your Bus today? |
Set valve clearances, replaced the horn, and did a bit of investigation into why it dies when idling as soon as the choke cuts off - might be an air leak... |
farnhamassoc Samba Member
Joined: February 16, 2010 Posts: 122 Location: Riverside ca
Posted: Sun Jun 28, 2020 8:53 pm Post subject: Re: What did you do for your Bus today? |
check this out my single cab resto super rusted and I am still fixing it am I crazy
_________________ Owned Countless VWs over the last 35 years.
Restored near 100 vws.
80 Rabbit diesel 1.9 TDI turbo 45mpg
06 Jetta TDI 45mpg
Restored several 11 window kombi and standard
Current inventory 66 delux hard top, so23
60 ragtop and 61 hard top bugs 54 hardtop bug
67 tin top so42 62 SO10 ruthmann bucket truck |
Posted: Mon Jun 29, 2020 8:26 am Post subject: Re: What did you do for your Bus today? |
Nice farnhamassoc, I've always wanted a plasma cutter, thanks for letting me know 220 is worth it
farnhamassoc wrote: |
Maui Roadsters
Lind wrote: |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Mon Jun 29, 2020 12:16 pm Post subject: Re: What did you do for your Bus today? |
Put the first dozen miles on the rebuilt engine to bed the rings in...
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Manfred58sc Samba Member
Posted: Tue Jun 30, 2020 7:59 pm Post subject: Re: What did you do for your Bus today? |
Got the super cool 58 only "Skier" plates on my 58. Just figured out the lettering on the nose says "Duke University"- had an easy life for awhile
_________________ Fat chick owner/operator |
bobrk Samba Member
Joined: March 07, 2002 Posts: 288 Location: Beautiful Downtown San Jose
Posted: Tue Jun 30, 2020 10:00 pm Post subject: Re: What did you do for your Bus today? |
Finally started taking the brakes apart on my bus, getting ready to buy all new parts for them, including doing a dual circuit master cylinder conversion, new brake cylinders, shoes, and drums. Looks like I'm going to have to do some seal work on one of the reduction boxes.
I even got some new tires I can't wait to put on. 195/70-15's
_________________ 1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats |
BarryL Samba Member
Posted: Wed Jul 01, 2020 6:33 pm Post subject: Re: What did you do for your Bus today? |
What a shame it appears the brakes had zero miles on them.
On another note are we still allowed to say "master" and "slave" cylinder? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Wed Jul 01, 2020 7:23 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
Yes. And yes. Maybe. _________________ nothing |
pyrOman Fire Master
Posted: Thu Jul 02, 2020 5:45 am Post subject: Re: What did you do for your Bus today? |
cdennisg wrote: |
BarryL wrote: |
Yes. And yes. Maybe. |
Hussein, puhleeze!
bobrk Samba Member
Posted: Fri Jul 03, 2020 2:09 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
No shame, I took 14 years off to raise kids. At least I hung on to my bus. _________________ 1959 Single Cab “Otto”
BarryL Samba Member
Posted: Sun Jul 05, 2020 6:11 pm Post subject: Re: What did you do for your Bus today? |
Bled the single circuit '65 today. I know...yawwwnnn...but it's what I did.
volksair Samba Member
Posted: Wed Jul 08, 2020 8:38 pm Post subject: Re: What did you do for your Bus today? |
My March 1964 Kombi that I have owned for the last 28 years. Not so much what I did to my bus today, but more like what I have been doing to it over the last two and a half months! The result of scraping and sanding by hand. Most of the paint loss was when the body was "prepared" for paint in the '80s. With care and patience I was able to save much of the remaining L87 Pearl White paint.
Posted: Wed Jul 08, 2020 8:53 pm Post subject: Re: What did you do for your Bus today? |
More before and after pics of my March 1964 Kombi.
iubhounds Samba Member
Joined: July 22, 2003 Posts: 339 Location: Southern Indiana
Posted: Wed Jul 08, 2020 9:35 pm Post subject: Re: What did you do for your Bus today? |
I received my new 64 Panel/Camper on Monday afternoon when the seller was nice enough to drive over 500 miles to my house. His first time in SE Arizona
This morning right after I got off the phone with Arizona MVD getting my temp registration and plate ... I stepped outside in the morning heat and finished cleaning the windows that I started on yesterday. After that I vacuumed everything from front to back, then hand washed everything from front to back. Threw on some Armorall on the cab and cargo floormats. All of that cleaning was perfect for me getting to know about my new bus. Headed out to fill the tank with gas and a short spin due to the high temps by that time of day. She is solid as a rock, drives like new and has new tires to get me anywhere my FJ takes me (well maybe not but at least some forest roads) ...
It was a perfect day.
