tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Mon Sep 17, 2018 4:45 am Post subject: Re: What did you do for your Bus today? |
25 new Hub Cap clips installed on 5 of 6 wheels off to sand blasting and then powder coating.
_________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Wed Sep 19, 2018 7:23 pm Post subject: Re: What did you do for your Bus today? |
On our way back, I wasn’t aware that the old Sinclair gas stations were still around!
_________________ Some people are so busy being clever they don't have time enough to be wise. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Wed Sep 19, 2018 8:49 pm Post subject: Re: What did you do for your Bus today? |
tpinthepack wrote: |
I just did this too, it's very satisfying.
pyrOman wrote: |
We just got a new Sinclair station up here in the High Desert.
They only exist in......THE TWILIGHT ZONE!! _________________ Brandon |
landkholdings Samba Member
Posted: Sun Sep 30, 2018 5:48 am Post subject: Re: What did you do for your Bus today? |
Got it a trophy yesterday... or a giant belt buckle. We took home the Save Acworth History Foundation choice.
_________________ Kevin |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sun Sep 30, 2018 8:30 am Post subject: Re: What did you do for your Bus today? |
congratulations Kevin. bus looks great.interior does too _________________ regards
Uli
Posted: Sun Sep 30, 2018 8:55 am Post subject: Re: What did you do for your Bus today? |
Thanks! _________________ Kevin |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Sep 30, 2018 6:33 pm Post subject: Re: What did you do for your Bus today? |
landkholdings wrote: |
We took home the Save Acworth History Foundation choice. |
Really looking fun and together.
Decided to file the '67 Westy's points, clean the cap contacts, replace the plugs and set the timing. Well...#4 sparkplug wouldn't tighten. Spent the day teaching myself how to do the Save-A-Plug tool and insert. It worked fairly well and time will tell. At least #4 is the easiest to work on. |
67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Fri Oct 19, 2018 6:04 am Post subject: Re: What did you do for your Bus today? |
pyrOman wrote: |
That looks like St George Utah. We have Sinclairs all over up here. |
mastorna Samba Member
Posted: Fri Oct 19, 2018 6:17 pm Post subject: Re: What did you do for your Bus today? |
I installed some WW pop out window rubber to the frame of the body today and noticed that they provide plenty of extra rubber that you have to cut and glue back together. I ended up cutting at the area that they had originally glued their section together once I found out that they had too much slack. It fit pretty snug and I don't think it'll require glue to hold it in place but we'll see. _________________ 1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Fri Oct 19, 2018 9:41 pm Post subject: Re: What did you do for your Bus today? |
mastorna wrote: |
I installed some WW pop out window rubber to the frame of the body today and noticed that they provide plenty of extra rubber that you have to cut and glue back together. I ended up cutting at the area that they had originally glued their section together once I found out that they had too much slack. It fit pretty snug and I don't think it'll require glue to hold it in place but we'll see. |
Weird, I wonder if something changed because I've installed those and they were snug but fit with no trimming _________________ How to Post Photos
pyrOman Fire Master
Posted: Sat Oct 20, 2018 6:53 am Post subject: Re: What did you do for your Bus today? |
EverettB wrote: |
mastorna wrote: |
Weird, I wonder if something changed because I've installed those and they were snug but fit with no trimming |
I’ll take a wild guess that it will eventually shrink! _________________ Some people are so busy being clever they don't have time enough to be wise. |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sat Oct 20, 2018 12:50 pm Post subject: Re: What did you do for your Bus today? |
Finally got a cover for the bus. Now that I rent I no longer have the safety and cover of a garage. This is the 4 ply Wolfsburgwest cover.
There seems to be a stitched area with a grommet on each side. Is that if I want to poke a hole and use a bungee cord to hold it down? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
pyrOman Fire Master
Posted: Sat Oct 20, 2018 2:06 pm Post subject: Re: What did you do for your Bus today? |
orangebug60guy wrote: |
There seems to be a stitched area with a grommet on each side. Is that if I want to poke a hole and use a bungee cord to hold it down? |
I believe it is to throw a cable and lock on it so no one can just pull it off. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Sat Oct 20, 2018 7:01 pm Post subject: Re: What did you do for your Bus today? |
Today, i turned the key on my bus for the first time.... it didn't start, but it turned!
Headlights works (somewhat), flasher don't..
But engine turned!!!! _________________ 1964 Turkis Flipseat |
Posted: Sat Oct 20, 2018 7:35 pm Post subject: Re: What did you do for your Bus today? |
Enkiel wrote: |
But engine turned!!!! |
one step at a time _________________ regards
Uli
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Oct 22, 2018 3:19 am Post subject: Re: What did you do for your Bus today? |
Very exciting
Enkiel wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Atlantic Samba Member
Joined: July 24, 2008 Posts: 704 Location: Kalifornien
Posted: Sat Oct 27, 2018 3:17 pm Post subject: Re: What did you do for your Bus today? |
... I splurged and vowed myself to this brand forever: I put an optima in the bus! I have really had it with all that other stuff.
Also I installed some engine fire retardand system or whatever it is called.
Wonder if the Made in Germany will do any good ...
_________________ _______________________
"If we believe absurdities, we shall commit atrocities." [Voltaire] |
swharris Samba Member
Joined: September 10, 2010 Posts: 500 Location: N. Orange County
Posted: Sun Oct 28, 2018 9:16 am Post subject: Re: What did you do for your Bus today? |
pyrOman wrote: |
Is that one of the new reproduction Doormobile tops? |
pyrOman Fire Master
Posted: Sun Oct 28, 2018 12:28 pm Post subject: Re: What did you do for your Bus today? |
swharris wrote: |
pyrOman wrote: |
No. It's vintage 1969. _________________ Some people are so busy being clever they don't have time enough to be wise. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sat Nov 03, 2018 9:01 am Post subject: Re: What did you do for your Bus today? |
Front end refresh.
