mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Jul 10, 2020 6:42 pm Post subject: Re: What did you do for your Bus today? |
wish they could all look like that. _________________ regards
Uli
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sat Jul 11, 2020 11:59 am Post subject: Re: What did you do for your Bus today? |
iubhounds wrote: |
I received my new 64 Panel/Camper on Monday afternoon when the seller was nice enough to drive over 500 miles to my house. |
Yes, clean bus. How did he get home? |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1215 Location: IRELAND
Posted: Sun Jul 12, 2020 7:26 am Post subject: Re: What did you do for your Bus today? |
Solomon Grundy Samba Member
Joined: December 26, 2004 Posts: 747 Location: Silicon Valley
Posted: Fri Jul 17, 2020 6:45 pm Post subject: Re: What did you do for your Bus today? |
I had a shocking experience today. Last month I purchased new front Bilstein shocks from shock warehouse for my 1963 Double Cab. Not sure why the Front sets are more expensive then the Back ones. Any clues as to why that might be...?
Bilstein Front: 24-632799 - Current price $158
https://www.shockwarehouse.com/site/product.cfm/id...ransporter
Bilstein Back: 24-181488 - Current price $79
https://www.shockwarehouse.com/site/product.cfm/id...-24-181488
Even when you go the main Bilstein page they call out the same numbers.
https://www.bilstein.com/us/en/product-search-deta...4709395141
This morning I started to put them on and found out that the shock sleeves were too long. In fact, about a half inch too long. No way were they going to fit the Bus. So, after some research and frustration I decided to modify them to fit. Certainly I could have just cut the bottom ones and used a longer bolt on the top, but then the center axis of both collars would be slightly off. So I cut both ends down to 1.25”.
Original sleeve was 1.25” and the new shocks were slightly over 1.75”.
The pictures bellow should explain it better. So now the Bus rides much nicer. Hope it is worth the dollars I spent.
I hope this experience helps someone ells from falling into the same situation. Not that hard of a mod but certainly frustrating after spending so much money and thinking I had an easy 30 min. job this morning.
The ride is much better but we will see over time if it was worth the extra money. _________________ "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Dr. Seuss
VW 181 Archive: https://sites.google.com/site/jeffgilleland/vw_archive
| _______
| |_______| '73 Thing "481"
| _\_\_|_/_/_
| |O||_4_||O|
http://vwthingregistry.com
https://doublecabshaka.wordpress.com |
iubhounds Samba Member
Joined: July 22, 2003 Posts: 339 Location: Southern Indiana
Posted: Fri Jul 17, 2020 7:07 pm Post subject: Re: What did you do for your Bus today? |
Before it got too hot here in SE Arizona, I drove it east on Hwy 90 to check out the fire that took place Sunday night along the San Pedro river. They had to call in the big plane to drop some retardant. Im glad I was there about five days later instead of getting splattered orange Sunday night. The real highlight of the day was getting one of the cargo doors open on the driver side. I thought it was locked for the first two weeks I owned it. I thought I was going to have to have a key made to unlock it.
_________________ 1960 VW Single Cab |
teahead Samba Member
Joined: October 30, 2019 Posts: 326 Location: Seattle
Posted: Mon Jul 27, 2020 11:56 pm Post subject: Re: What did you do for your Bus today? |
Retrofitting a Mercedes clock that works.
Removed the old vw bezel and put it on the Mercedes clock
_________________ '63 German Walk-Thru Deluxe 15-window - SOLD |
Rawq Samba Member
Posted: Sun Aug 16, 2020 8:46 am Post subject: Re: What did you do for your Bus today? |
So over the past 18 years I've been slowly, ok really slowing resto on my 58 bus... as I come across little issues the forums here have been a great help.. Thanks all..
I figured I would share my shifter issues and story maybe helping someone else in the future.
After rebuilding the motor, adding a new transmission, replacing the shift rod, couplers, shifter etc. it was time for the fist drive. The motor fired up right away and I let it warm uo a bit then pulled it out of the garage, I put the bus in first gear and slowly rolled out. Stopping before I was completely out I figured I better check reverse... No reverse!
The is where the forum came in handy..
I started with the simple recommendations like adjusting the shifter plate, no luck, I had changed the shift to an EMPI shifter so I figured maybe it was the problem. put the stock on back on, still no reverse.
So rather than stew over it I decided to remove the entire drive train and check every part.
To make a long story short the problem ended up being the smallest part of the entire shifter assembly.. The front coupler... it was poorly manufactured and the holes driller were out 1/16th of an inch, enough to prevent reverse...
The EMPI shift went back in and worked however it had catastrophic failure on the first trip, a weld inside the unit failed..cheap junk, so I went back to the stock shifter and all is good.. I hope this helps someone else if they experience the same issues..
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Mon Aug 24, 2020 6:54 pm Post subject: Re: What did you do for your Bus today? |
So after 15 years of dealing with rattling windows, I finally called Ronnie and ordered new rubber kits.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Maximillion Samba Member
Joined: August 07, 2016 Posts: 46 Location: Seattle, WA
Posted: Sat Aug 29, 2020 2:44 pm Post subject: Re: What did you do for your Bus today? |
Been a looong time since I’ve done anything for my bus. About two years ago I tried to fix it (after it sat for 4-5 years) and realized the engine lost compression so then I was going to trailer it from NH to Seattle but my trailer was way too unsafe so I finally had it shipped out a few weeks ago. Had a zoolander moment when I was cleaning the main floor mat! Our one year old absolutely loves the bus though! I guess these busses are pretty timeless!
thom Samba Member
Posted: Mon Sep 07, 2020 4:23 pm Post subject: Re: What did you do for your Bus today? |
I decided to finally replace the front windshield seals - they were rock hard, and had been siliconed several times. It was a PITA just to get the windshields out - I carefully heated and cut the old rubber out, then cleaned everything up. My wife helped me reinstall them with the news seals, and everything was golden. I had a couple of house chores to do, and when I went back to clean the fingerprints off the windshields, I discovered that the driver's side had cracked
1956 Single Cab
1963 Unimog 404
1965 E-Type |
pmcnulty Samba Member
Posted: Sat Sep 26, 2020 4:39 pm Post subject: Re: What did you do for your Bus today? |
Finally was able to source a decent Hehr window crank replacement. New metal screens installed and a little drill out and modification and all 5 looking good and working fine. Fresh air at last. 😜
Deluxe2164 Samba Member
Joined: January 29, 2010 Posts: 123 Location: Palmetto Bay / Conch Key
Posted: Sat Sep 26, 2020 9:20 pm Post subject: Re: What did you do for your Bus today? |
Added air shocks to the front end to stop passenger side from rubbing when I have more than four people.
Posted: Sat Sep 26, 2020 9:30 pm Post subject: Re: What did you do for your Bus today? |
pmcnulty wrote: |
looks great _________________ regards
Uli
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
burnite2 Samba Member
Joined: September 08, 2010 Posts: 30 Location: Albuquerque, NM
Posted: Mon Oct 05, 2020 11:15 am Post subject: Re: What did you do for your Bus today? |
Installed my new distributor. Marcel from VWNOS.com restored it for me and I can’t speak more highly of him. Great work and customer service!
Clara Samba Member
Posted: Wed Oct 07, 2020 9:35 am Post subject: Re: What did you do for your Bus today? |
Installed a replacement wiper blade on the passenger side of the Cragar Kombi. Those rubber blades just don't last as long outside in California as they did in Washington! There is rain in the forecast for Thursday.
Also snugged the screw for the ignition switch, which was loose.
Added 1/2 qt oil, since the oil level was at the bottom line.
I checked the cap nuts on the oil drain, they were not quite snug, so snugged them up.
The oil filler was loose on the gen stand, so tightened that funny bolt down its throat.
Hopefully that reduces oil seepage and loss.
Only have put about 1300 miles on it this year, been driving the red bus more. And haven't taken it on any camping trips, or to any shows. Not that I've been to any shows this year. Greg went to BBB, in the blue bus ('56 westy), but I stayed home to help my Mom who was having some health issues.
The blue bus stays in the garage. The wipers on it seem okay still, they are not dried out and cracked. |
newbie68 Samba Member
Joined: September 13, 2015 Posts: 33 Location: Oceanside, CA
Posted: Wed Oct 07, 2020 9:39 pm Post subject: Re: What did you do for your Bus today? |
This past weekend, I was cruising around on my '65 bus when a truck that had been behind me (on the left hand lane), came around and paired up with me on the right. He yells out wondering if I knew my brake lights were out. I told him no, thanked him and continued on my way. So today, I finally got to it and tested the wires going to the MC brake switch, and sure enough, they definitely had juice and made my brake lights work when I made a direct connection (I had already decided to replace the wire clips). I next cleaned the brake switch connecting tabs and connected the wires. The brake lights did come on, but it was sporadic -- sometimes they came on with a light touch of the brake, and the next time, only with the brake pedal all the way to the floor, and sometimes not at all. It was at this point I decided to go get a new (2 prong) brake switch and also splurged on a boot to cover the switch and the connections. This meant I had to once again remove the wire clips in order to fit the wires through the boot (lesson learned). I removed and replaced the new brake switch, and voila! The brakes came on with just a light touch of the brake pedal. Also while down there, I discovered why my horn didn't work -- the wire had broken off from the connector, so I replaced that connector and got the horn to work. All in all, I'm happy that I'm once again California legal (and that I saved a few bucks, all the while gaining a bit more confidence in doing the work myself ) Oh, lest I forget -- all you guys rock! _________________ '65 VW Bus and '68 VW Bug
"Tell the truth and Run." ~ Yugoslav proverb |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Mon Oct 19, 2020 10:14 am Post subject: Re: What did you do for your Bus today? |
I've been working on this thing a bit lately. Got some fresh meats mounted up this weekend and took it to its first show. Tiiiight
aeromech wrote: |
in my opinion you don't know shit |
Posted: Wed Oct 21, 2020 10:14 am Post subject: Re: What did you do for your Bus today? |
I decided not to sell my 64 Double Door and canceled my Samba for sale ad I put up last night, early this morning.
I sprayed Simple Green in engine bay, under the engine and transmission but only let it soak an hour before taking it to the car wash. I have no patience and decided if it didn't clean up well enough then I would let it soak overnight and wash it again tomorrow. It turned out pretty well.
Before and after photos are being loaded in my Gallery. _________________ 1960 VW Single Cab |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Oct 24, 2020 11:33 am Post subject: Re: What did you do for your Bus today? |
It may not seem like a lot to all of you V-dubers but this is my first VW and now my first carburetor install and it turned out a lot easier than I thought. I bought the 34 PICT 3 last year from Tim of VolkzBitz with the old carb failing yesterday it was finally time to install and she never sounded better. Yes I need to clean the area install the tin etc. but that is for another day. Thanks Tim.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
