mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Fri Apr 02, 2021 8:49 pm Post subject: Re: What did you do for your Bus today? |
pretty nifty _________________ regards
Uli
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 245 Location: Cambridge UK
Posted: Sat Apr 03, 2021 11:14 am Post subject: Re: What did you do for your Bus today? |
"What did you do for your Bus today?"
Sheared off an inlet manifold stud |
amishman Samba Member
Joined: March 09, 2004 Posts: 3215 Location: California
Posted: Sun Apr 04, 2021 11:07 am Post subject: Re: What did you do for your Bus today? |
After a bit of a hiatus away from wrenching and my VW, I finally finished my 1967 SO42 Front Brakes. Took my bus for a test drive and seems like I may have done what I set out to do. lol.
Now, more to come. Last two Fridays I found time to play in my shop most of the days and get some projects done, so I am happy about that.
Was nice to drive my bus around. Going to order some new fuel house and drain my tank of old gas, install the new fuel line, ordering a vacuum distributor so I can relegate the 009 to the spare parts box, as well as starting to explore rear brakes next.
Kaizen! Little steps for me!
_________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
BarryL Samba Member
Joined: November 01, 2004 Posts: 14255 Location: Casa de Oro, California
Posted: Sun Apr 11, 2021 6:34 pm Post subject: Re: What did you do for your Bus today? |
Do you know what it was timed at when it was sputtering? |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2204 Location: UK (South)
Posted: Thu Apr 22, 2021 11:06 am Post subject: Re: What did you do for your Bus today? |
I gave him his own padded cell. He lives with me. I'd drive anyone nuts...
They're actually fireproof kapok-filled drapes designed to protect walls, particularly in lifts, from impact damage and abrasion during renovation work.
I bought them last autumn, because they were advertised as welding curtains. Easy mistake for the seller to make as they have the same fire rating.
I was going to keep a couple and sell the rest.
I Googled the manufactuer to see how much they sell for new and found out what they're really for. I figured there wouldn't be much of a market for them, so I decided to hang them up.
The garage is narrow. I was tired of scraping along the rough brick to get past the truck and banging the door on the wall getting in and out of the cab. When I work on the brakes etc., I have my back against the wall. These are soft and warm. Should help keep the garage warm too. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
67DC CB Samba Member
Joined: March 08, 2009 Posts: 63 Location: Athol, Idaho
Posted: Mon Apr 26, 2021 8:23 pm Post subject: Re: What did you do for your Bus today? |
Went from this
To this
I’m not 100% on the color, but I sure as heck like these better than the bug wheels. |
Posted: Wed Apr 28, 2021 6:28 pm Post subject: Re: What did you do for your Bus today? |
BarryL -
I don’t remember where the timing was when it was sputtering, but it was significantly off as I had to change it quite a bit.
On a separate note, I have a vented gas cap, and a bay 15 gallon tank in my split. Today was one of the first “hot days” in NC getting up to 86 degrees. With about 1/3 of a tank, I drove the bus, parked in the sun, and drove home around 6pm. Within 15 min of parking the bus I started to hear a hissing from the vented fuel cap. I opened it and a lot of air went into the tank, as there was a significant vacuum in there. I assume from he fuel and vapor in the tank cooling off. So then after it was equalized, I waited another 15 min and I could hear the hissing again! So I opened it and it was about half the amount of suction this time.
So I assume the venting hiss is enough to slowly equalize this pressure without imploding the tank. Does anyone else have experience with the “rate” of tank venting on warm days to avoid implosion? _________________ Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Thu Apr 29, 2021 7:58 am Post subject: Re: What did you do for your Bus today? |
A "vented cap" ought to keep up with your fuel expansion or contraction. I suspect it really isn't venting much if at all. If you have some, swap caps and see if it re-occurs? Or start to rotate/tighten the cap but leave it a little loose and hope that vents it better?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Thu Apr 29, 2021 8:52 am Post subject: Re: What did you do for your Bus today? |
Does your bay tank have the vent line on top still? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Daddybus Samba Member
Posted: Sat May 01, 2021 10:17 am Post subject: Re: What did you do for your Bus today? |
I run a bay tank in the '67 daddybus. I used the bay neck (I used screws and 3 flat washers to "pinch" the round filler lip against the bus body ( no holes drilled in bus). In the bay neck, I welded in a fuel flap from the neck of a fuel injected truck gas tank (Toyota I think). I use a non-vented cap. I ran the breather hose to a charcoal-filled reusable fuel filter. After the filter, the end of the breather hose is clamped to the gas filler tray (with the drain pipe). Breathes like stock and no sloshing out on turns.
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun May 02, 2021 7:18 pm Post subject: Re: What did you do for your Bus today? |
Got the front doors open !!!!!!!!!!!!
1st time in 5-6 years ! This Bus sat in my back field for YEARS as a storage unit for VW engines, Finally got a trans in it to move it around, and now the front doors open _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri May 14, 2021 3:03 pm Post subject: Re: What did you do for your Bus today? |
I did this-
For no other reason than I could! The ultimate Anti-theft device. The "nut" is from a VW Military vehicle. Not sure of the vintage or model. Had to rethread it to the Bus column. I took the actual button out of the original assembly. I used a button made for a Bug 3-spoke Standard wheel in the nut hole. Made by MSW in Thailand. Nice piece. Kinda spendy. But, whatever. So, I fixed it, too-
_________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
BarryL Samba Member
Posted: Fri May 14, 2021 6:34 pm Post subject: Re: What did you do for your Bus today? |
Trippy. Will you wear the wheel when you go in a store? |
cru62 Samba Member
Posted: Fri May 14, 2021 7:48 pm Post subject: Re: What did you do for your Bus today? |
Fo’ Sho’!! On a fat chain with my grill..... _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
