mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Sat Jun 19, 2021 10:54 pm Post subject: Re: What did you do for your Bus today? |
mikelars wrote: |
Driving my 66 Deluxe 13 window and the clutch suddenly went a bit “looser” on me - turns out at the front of the Bowden tube the connector wasn’t quite on the tube, causing the cable to rub and eventually half snap and fray about half the filaments of the clutch cable.
I do love that the failing clutch cable gives you some warning, but I wish the warning period was longer. I've still driven home from the mountains with no clutch. Come to think of it, I've driven home with no brakes too. Driving a bus makes you a better driver. _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sat Jun 19, 2021 11:00 pm Post subject: Re: What did you do for your Bus today? |
MrWhoopee wrote: |
I do love that the failing clutch cable gives you some warning, but I wish the warning period was longer. I've still driven home from the mountains with no clutch. Come to think of it, I've driven home with no brakes too. Driving a bus makes you a better driver. |
yes, it does _________________ regards
Uli
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Sat Jun 19, 2021 11:30 pm Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
MrWhoopee wrote: |
yes, it does |
And perhaps more patient haha. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Jun 21, 2021 2:43 am Post subject: Re: What did you do for your Bus today? |
I'm always learning more about our buses by these posts. I'll now check my cables and that Bowded tube. I was able to locate a video on it's location and install tips. I now see how difficult it is to reach from under the bus.
mikelars, you have done an amazing job with your bus as before & after photos are amazing. Keep up the great work.
mikelars wrote: |
So I got 2 new clutch cables - the “B” length for split bus walkthrough- and a new Bowden tube since mine seemed a bit kinked. Fed it through with grease and managed to get a good bend in the Bowden tube without my washers. Re-connected the cable to the pedal and managed to adjust the wing nut without taking the heater box off - tight fit for 2 hands…
Happy with the result - but man this is a messy job. I wished I had used rubber gloves and rubber sleeves…. |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
donald.lemay Samba Member
Joined: March 01, 2009 Posts: 484 Location: Rhode Island
Posted: Thu Jul 01, 2021 1:44 pm Post subject: Re: What did you do for your Bus today? |
That’s funny I finally put one on today as well- bus has been painted for 14 yrs ^^^ _________________ 66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 539 Location: Geneva, Florida
Posted: Fri Jul 02, 2021 7:27 pm Post subject: Re: What did you do for your Bus today? |
I parked it between the posts on the lift, again.
Tomorrow I swear the engine comes out and the fuel lines get redone. _________________ ...david - '66 SO-44 #231 |
Posted: Sun Jul 04, 2021 1:06 pm Post subject: Re: What did you do for your Bus today? |
David Raistrick wrote: |
Tomorrow I swear the engine comes out and the fuel lines get redone. |
and it did! of course, I screwed up my hardline-from-tank-to-bulkhead-fitting design and installed it without the starter in place.... so waiting for replacement fittings (one time use compression fittings).
in the meantime - installed a butty's bits throttle linkage and cable roller. tore one of the ball and socket boots when pulling the throttle rod boot over it.
installed the other 2 pedal boots, and new brazil pedal covers since my 80's era aftermarket (with the triangle) covers finally died (clutch fell off, brake should have fallen off, but magic seemed to be keeping it there.
and found one of the split swing axle boots that seem like they had to have been new when I installed the trans in '01 has split. so new febi pair on the way. _________________ ...david - '66 SO-44 #231 |
swharris Samba Member
Joined: September 10, 2010 Posts: 500 Location: N. Orange County
Posted: Sun Jul 04, 2021 1:17 pm Post subject: Re: What did you do for your Bus today? |
While cleaning up and moving boxes in the garage, I came across a nice surprise. Apparently, years back I bought some Ambulance fans. Not NOS, but damn near. Haha. I vaguely remember buying some at a Pomona swap. This has to have been 20+ years ago. NFS btw. |
Posted: Sun Jul 04, 2021 1:33 pm Post subject: Re: What did you do for your Bus today? |
Pulled the rear drums off the '62 SC. They are soaking wet. I went to pull it out of the garage(steep incline into the alley) and stomped on the brakes and they went to the floor!! Almost hit my neighbor's wall. A quick E-brake hail mary and a hard full left avoided the concrete block.
These were new cylinders about 10 years ago. Shouldn't the piston seals last longer than that?? Who makes a good rebuild kit nowadays??
Posted: Sun Jul 04, 2021 3:29 pm Post subject: Re: What did you do for your Bus today? |
and found one of the split swing axle boots that seem like they had to have been new when I installed the trans in '01 has split. so new febi pair on the way. |
nope. german from busdepot in '05. yay records. _________________ ...david - '66 SO-44 #231 |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun Jul 04, 2021 4:02 pm Post subject: Re: What did you do for your Bus today? |
Front disc Brakes on the '66 Singlecab, kit from Brian @ Type E Motorsports, all said & done $1,225, installed, VERY happy w/ them !! _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sun Jul 04, 2021 9:03 pm Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
Front disc Brakes on the '66 Singlecab, kit from Brian @ Type E Motorsports, all said & done $1,225, installed, VERY happy w/ them !! |
I saw someone link to that kit on FB - what rotor/caliper does it use? no modifications required to either? (like the babystang uses a mustang II but you have to machine it if I recall)
I want to update my notes... _________________ ...david - '66 SO-44 #231 |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jul 04, 2021 9:35 pm Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
I want to update my notes... |
https://www.thesamba.com/vw/classifieds/detail.php?id=2436021
https://type-emotorsports.com/collections/type-2-b...4739508284 _________________ nothing |
Posted: Mon Jul 05, 2021 7:00 am Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
this details the rotors/calipers they use: https://type-emotorsports.com/pages/type-e-ez-stop-split-bus-disk-brake-kit-instructions
sadly there's not a great market for performance pads for '89 celebrities, so no good way to specifically select an engineered compound. but still - not a bad kit if you're able to find a set of pads that work well for you. _________________ ...david - '66 SO-44 #231 |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Mon Jul 05, 2021 7:40 am Post subject: Re: What did you do for your Bus today? |
Cleaned up and gutted an old voltage regulator. Used it to hide a couple of modern cube-style relays.
Now I know they fit, I'll make a bracket to replace the zip ties and mount it a little further back.
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Mon Jul 05, 2021 8:24 am Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
sadly there's not a great market for performance pads for '89 celebrities, so no good way to specifically select an engineered compound. but still - not a bad kit if you're able to find a set of pads that work well for you. |
As with the Celebrity, not much need for high performance pads on an old bus. _________________ nothing |
Posted: Mon Jul 05, 2021 8:30 am Post subject: Re: What did you do for your Bus today? |
cdennisg wrote: |
As with the Celebrity, not much need for high performance pads on an old bus. |
no, but having a performance market means you have more options when you find you need to adjust your front/rear brake balance (as I experienced with fully functional stock rear brakes locking up long before the fronts would, when cold or wet) by changing compounds. Being able to looking at dyno charts for brake pads and choose a pad change based on the charts is really helpful. It's still trial and error, but it helps! _________________ ...david - '66 SO-44 #231 |
Posted: Mon Jul 05, 2021 9:07 am Post subject: Re: What did you do for your Bus today? |
cdennisg wrote: |
no, but having a performance market means you have more options when you find you need to adjust your front/rear brake balance (as I experienced with fully functional stock rear brakes locking up long before the fronts would, when cold or wet) by changing compounds. Being able to looking at dyno charts for brake pads and choose a pad change based on the charts is really helpful. It's still trial and error, but it helps! |
Wouldn't it be better to install an adjustable proportioning valve? _________________ nothing |
