mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri Dec 03, 2021 10:59 pm Post subject: Re: What did you do for your Bus today? |
Great weather today, clear and 75 degrees on Dec 3rd in Missouri! I decided to give my '59 D.D. Panel an engine oil change and an air cleaner oil change and light engine compartment tidy-up.
I might just replace all the braided fuel lines and a new in-line fuel filter tomorrow with new Flennor braided cloth-covered fuel line that stands up to ethanol fuels...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2206 Location: UK (South)
Posted: Sat Dec 04, 2021 2:37 am Post subject: Re: What did you do for your Bus today? |
BulliBill wrote: |
Bill |
Any chance you could post a picture of the markings on that line, if you fit it? I've tried finding it in the UK, but no one lists it. Can't even stocksts on mainland Europe who advertise it, which is odd because Flennor are German.
I'm wondering if it is stocked but the sellers aren't stating the manufacturer, so it would be helpful to be able to compare markings with the product pictures (it might have a logo or product code etc.?) _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sat Dec 04, 2021 1:53 pm Post subject: Re: What did you do for your Bus today? |
Sure Andy, but it maybe tomorrow... Here is a link to Belmetric' s site and the hose I have, there is a photo there, not sure if it is enough to read all the markings...
https://www.belmetric.com/multifuel-hoseethanol-ap...0olmklnfn6
Thanks for any help! |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Dec 04, 2021 3:40 pm Post subject: Re: What did you do for your Bus today? |
Pulled an engine out of my Barn today it came from my older Brothers Westy from back in the '80's, going to clean it up, pull the funky oil cooler, and see if I can get it to run in the '66 Singlecab. With the lack of snow, I was happy to still access the Barn at this time of the year. Love the Rabbit truck for these kinds of jobs. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Mile High Puma Samba Member
Joined: November 11, 2009 Posts: 211 Location: Salida, Colorado
Posted: Sat Dec 11, 2021 6:32 pm Post subject: Re: What did you do for your Bus today? |
Sanding the first application of high build primer from the bed, I have a new respect for single cab owners that have done this.
_________________ 1965 Velvet Green DC |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Wed Dec 15, 2021 3:13 pm Post subject: Re: What did you do for your Bus today? |
I pulled wires from the rear to the front. Up the right side of the frame into the area inside the lower/front tin and on to the valance and up inside the dash.
I use silicone jacket wire, flexible, heat resistant, pulls well. I pulled a 10 gauge,
2-16 gauge, and three 14 gauge. As you will see, I cut a 3/4" hole to access the frame channel.
Then I pushed a length of rigid throttle cable through the hole and it emerged at the other end of the channel without a hitch. I fished it through afterwards to see if I could get more wire through without issue.
I cut another 3/4" hole in the bottom of the valance and pushed the wire up into the dash. Very easy.
I attached some photos of the process and route.
Cheers, dgsaz
dgsaz Samba Member
Posted: Wed Dec 15, 2021 3:17 pm Post subject: Re: What did you do for your Bus today? |
Here are the photos:
Hole to access the frame channel.
Coming out of the frame channel
Into the valance and up behind the ash.
, d
dgsaz |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Sun Dec 19, 2021 7:00 am Post subject: Re: What did you do for your Bus today? |
Sweet!
dgsaz wrote: |
, d
dgsaz |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Sun Dec 19, 2021 9:54 am Post subject: Re: What did you do for your Bus today? |
Added fuel shut off solenoid with 6an tank fitting. I had some (infrequent) carb drippage after shutting off the engine, so this eliminates the gravity fed pressure from the tank when the engine is off. Since I have a split with a bay 15 gallon tank, when full I think there was decent gravity pressure on the fuel…
Now when you turn the key to on (but don’t start it yet) you can hear the faint clicking of this solenoid under the bus. I was going to leave my manual shut off valve in line after the solenoid, but it didn’t fit before my rubber Mount bracket, so I just removed the manual shut off, since it is shut off anyway when the key isn’t in the ignition…
I considered a bracket, but between the 6an fitting and the rubber bracket on the other side, it is solidly held in place. This should make it impossible for more fuel to get into the carbs, once the engine is off…
Hoping to smell less fuel when the bus is parked - time will tell if this works…
_________________ Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sun Dec 19, 2021 10:23 am Post subject: Re: What did you do for your Bus today? |
Nice^^^ I need something like that for my single cab. A little stiffer and a little longer. (giggity) _________________ nothing |
dgsaz Samba Member
Posted: Sat Jan 01, 2022 11:08 am Post subject: Re: What did you do for your Bus today? |
While the engine is out I installed velocity stacks on the carbs and replumbed the fuel delivery system with hardlines.
Photos:
Hardline:
Hardline ready to pump up and pressure test.
And that's how I spend my Christmas holidays.
dgsaz |
64 ragtop volks Samba Member
Posted: Fri Jan 28, 2022 9:55 am Post subject: Re: What did you do for your Bus today? |
woke up the big boy today, its been a minute |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Fri Jan 28, 2022 11:14 am Post subject: Re: What did you do for your Bus today? |
64 ragtop volks wrote: |
that is a good look. _________________ regards
Uli
Micron Samba Member
Posted: Mon Feb 14, 2022 12:40 am Post subject: Re: What did you do for your Bus today? |
Not sure this is the right place to post this, but i just wanted to ask, If you slam the brakes, does a bus feel like it wants to do a stopee? just a short question, thanks |
Posted: Mon Feb 14, 2022 10:02 am Post subject: Re: What did you do for your Bus today? |
Micron wrote: |
No. Just because the cab is all forward, the weight bias is not. _________________ nothing |
dgsaz Samba Member
Posted: Tue Feb 15, 2022 5:19 pm Post subject: Re: What did you do for your Bus today? |
mikelars wrote: |
Similar same here. I replumbed the fuel delivery, new line off the tank, to a 100 micron filter and a shut off valve. That line runs to a blulk head fitting. It's quite nice to be able to disconnect and turn off the fuel.
I'm done plumbing for a while. Brake hard and flex line replacement is next
dgsaz |
khalimadeath Samba Member
Posted: Tue Feb 15, 2022 6:32 pm Post subject: Re: What did you do for your Bus today? |
dgsaz wrote: |
mikelars wrote: |
[img]https://www.thesamba.com/vw/gallery/pix/2244802.jpg
[img]https://www.thesamba.com/vw/gallery/pix/2244801.jpg |
[img]https://www.thesamba.com/vw/gallery/pix/2252375.jpg
dgsaz |
I would like to plumb mine in a similar fashion. is there a brand or specific kit you used to build this? Or just 1/4 in fuel line? _________________ The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi |
