dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Fri Feb 18, 2022 5:29 pm Post subject: Re: What did you do for your Bus today? |
It’s just parts and line. But, use the copper/ nickel tubing. Buy a flaring tool.
The AN 4 fittings are available all over the net. Push lock hose if you don’t want to use hose clamps. I think the German woven will work w/o clamps if you have a stock fuel pump.
I admit to going on the Airkewled site and following there component picture to establish the parts list. After buying the tools (flares, benders, etc) and materials I only saved about $25. But I have the tools and experience. I’m branching out into brake line next.
Cheers,
dgsaz |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Sun Feb 27, 2022 8:05 am Post subject: Re: What did you do for your Bus today? |
It was last weekend but over the past couple of years I've gotten to know some extended family in Chattanooga, TN. (about 170miles away) Some I hadn't seen since I was a child, some I'd never met. One cousin (second cousin technically) and I realized we have a lot in common and talk regularly. Last year he ended up with a '60 ragtop Beetle and naturally we talk more and more. His 30th b'day was last weekend so my grandmother and I drove up in my Bus and spent the weekend. She mostly with her sister, me mostly with my cousin and his family. It's been so great to get to know family better. We spent one day mostly cruising around. I let him drive my Bus and now he wants a Bus too.
_________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
RBurn Samba Member
Joined: May 08, 2016 Posts: 115 Location: Northern Ca
Posted: Sat Mar 12, 2022 8:48 am Post subject: Re: What did you do for your Bus today? |
Picked up a 62 single cab. Gas tank was leaking multiple spots, Po said they filled it up with fuel and didn’t know it leaked but it was obvious to me with the wet and major smell. It also had no strapping at all. At any rate, I pulled it and ordered new www tank. Also, both treasure chest doors held by bailing wire. I found a matching pair of really nice latches using thesamba wtb. It drives but I many things to fix. Enjoy!
_________________ 70 Karmann Ghia Vert
67 Beetle deluxe
62 Single Cab
70 T2 Model 221 *CARR FIRE Victim
70 T2 Model 231 *CARR FIRE Victim
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Mar 12, 2022 9:23 am Post subject: Re: What did you do for your Bus today? |
RBurn wrote: |
Picked up a 62 single cab. Gas tank was leaking multiple spots, Po said they filled it up with fuel and didn’t know it leaked but it was obvious to me with the wet and major ... It drives but I many things to fix. Enjoy!
wow, that looks pretty nice. good call on installing a new tank. peace of mind.
Every time i look at how the gas tank is installed in the single cabs i wonder why they did it that way.
in the regular space they could have put a much larger tank without any downside at all.
Another option would have been to move it on the tray farther back, which would increase treasure chest storage by quite a bit.
i would have told them, but they did not ask me, not having been born and alll _________________ regards
Uli
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Fri Mar 18, 2022 10:48 am Post subject: Re: What did you do for your Bus today? |
I finally got around to fixing my idle stalling when it's cooler and high humidity ! The first shows the carb heat locked out for hot weather . The middle picture shows it in automatic operation and the last shows the part that I welded to fix what I had broken last summer 😒
_________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Fri Mar 18, 2022 12:06 pm Post subject: Re: What did you do for your Bus today? |
^^^ It's amazing how much that little flap can change cold/damp weather performance.
Curious, what is the date stamp on the flap? Should look something like this...
_________________ nothing |
amishman Samba Member
Joined: March 09, 2004 Posts: 3217 Location: California
Posted: Fri Mar 18, 2022 4:20 pm Post subject: Re: What did you do for your Bus today? |
A couple of weeks ago new 8ply tires 185R14 for my 1967 Westy and today a Bosch Vacuum Advance Distributor.
TJ
_________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Fri Mar 25, 2022 8:59 am Post subject: Re: What did you do for your Bus today? |
LAGrunthaner wrote: |
Looking good for spring camping Amishman. |
Thanks!
The goal today is to drain the transmission and do a complete refill, and if I find more time, replace my speedo cable.
After that, either buy and install a more time correct and good fuel pump or do my rear brakes. Probably will do rear brakes next but we shall see.
Slowly doing work as I can.
How is your bus coming along?
TJ _________________ tj (the Amishman)
Posted: Fri Apr 01, 2022 4:10 pm Post subject: Re: What did you do for your Bus today? |
46mm Axle But Removal for the 1st time on my 67 Bus using a cool new tool (made it like butter to remove) and drums removed, transmission and rgb's drained, and inspection of brakes so I can order all the parts needed to do brakes as well and fix as leaking gear oil it appears from the seals as it was gooey inside and been seeping for a while.
Don66bus Samba Member
Posted: Mon Apr 04, 2022 1:52 pm Post subject: Re: What did you do for your Bus today? |
Drove it on the road for the first time since November. I had run it up and down the driveway in winter every couple of weeks, but I wait until spring rains remove the last road salt before taking it out on the street. The first drive in April, the bus feels fragile and I am listening to every new sound it makes. Then I reflect that it completed a 6000 mile trip before I put it away in the fall, and it will probably do so again.
So I filled it up with expensive gasoline and then changed the oil on my return. Tomorrow it takes an old toilet to the Habitat ReStore. Back to treating it like an everyday vehicle. |
Posted: Mon Apr 04, 2022 3:17 pm Post subject: Re: What did you do for your Bus today? |
Awesome, to hear and your Westy looks great Amishman.
What is that cool new tool? Always good to learn a bit more.
amishman wrote: |
TJ |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Mon Apr 04, 2022 4:48 pm Post subject: Re: What did you do for your Bus today? |
Klutch Torque Multiplier, and will say, made my life easier.
I am growing past doing things that will cause me bodily harm. haha.
So found this device and gave it a try and loved it!
Not for everyone as it is not cheap but for me, worth the price.
TJ
[quote="LAGrunthaner"]Awesome, to hear and your Westy looks great Amishman.
[quote="amishman"]46mm Axle But Removal for the 1st time on my 67 Bus using a cool new tool (made it like butter to remove) and drums removed, transmission and rgb's drained, and inspection of brakes so I can order all the parts needed to do brakes as well and fix as leaking gear oil it appears from the seals as it was gooey inside and been seeping for a while.
Posted: Mon Apr 04, 2022 4:52 pm Post subject: Re: What did you do for your Bus today? |
Rear brake components were ordered for my 1967 along with rear-wheel seal kit to halt the dripping of fluids onto my brakes.
Hoping most arrive by Friday but may be next week.
Want to get cranking on getting things done!
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Apr 05, 2022 6:09 pm Post subject: Re: What did you do for your Bus today? |
This happened several weeks ago.
My ’65 needed gas today so I went to my local Chevron to purchase fuel. Two 2.5 gallon gas cans also needed filled for yardwork tools. I put the gas cans in the side door on a plastic tray in case I spill. I had to back in to the pump to access my fuel door and side door so I left plenty of room to swing open and maneuver around. As I was backing a stander-by was directing me with hand motions that made no sense as he didn’t realize I needed to give the pump wide berth. His bicycle was upside-down and he was wearing camo-fatigues. Clean face his hair was beyond his shoulders.
He spoke, “I love you”. I acknowledged him but was leery to engage him too far as there are panhandlers that I usually give spare-change but I wanted to see what he was up to so I could go about my task.
As I got the pump ready he began to correct himself and say, “I love your …vehicle…” .
I nodded, thanked him and assumed he was not missing too many brain cells, just dorky. As I started to pump gas he began telling me while highly animated and peering inside my windshields about how he had a bus several years ago and was driving in an emergency to get his pregnant wife to the hospital to birth their child in the pouring rain at night but a vehicle had hydroplaned and spun wildly ahead of him. I knew by his body language he was telling the truth as he mimicked the close-to-the-windshield terror grip as he looked out and down to the ground below while simulating the brake pedal panic. We laughed together. He had grown white and pale reliving the experience. As I continued my gas station duty he jabbered and rocked on his now upright bicycle.
When I had finished and made sure all the gas caps were secure he stood focusing between the front of my bus and my face. He slowly turned to me and asked, “Where all have you stopped?”. I wasn’t sure what he meant as we stared quizzically at each other when he suddenly relaxed, stared deep into my eyes, took a breath and said, “You’re a Time Traveler, right?”. |
Posted: Tue Apr 05, 2022 6:58 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
Duh! _________________ regards
Uli
Posted: Sat Apr 09, 2022 12:20 pm Post subject: Re: What did you do for your Bus today? |
Nice video Amishman I even started from the beginning. Awesome tool to save your health. Also good stage presence in front of the camera. Your Westy looks great, like it rolled off the showroom floor. Is it an early 67 with the pointed front bumper and slash in rear?
[quote="amishman"]Klutch Torque Multiplier, and will say, made my life easier.
TJ
amishman wrote: |
TJ |
Maui Roadsters
Lind wrote: |
Posted: Sat Apr 09, 2022 12:53 pm Post subject: Re: What did you do for your Bus today? |
Thanks for the kind compliment. Yeh, I guess I like to make videos on retro computers and gaming systems so enjoy making videos like these. hah.
My bus was born in December 1966 so not sure if that is considered early or not, but think the rear bumper is not the correct year bumper as someone in the Samba Facebook group pointed that out to me.
I really did not know that. As there is some cracking paint where Bondo was once put on the rear corner, my guess as some point that number was replaced.
Rear brake work not going as planned today as I keep rounding off the brake lines so more work for me now. Oh well. haha
TJ
[quote="LAGrunthaner"]Nice video Amishman I even started from the beginning. Awesome tool to save your health. Also good stage presence in front of the camera. Your Westy looks great, like it rolled off the showroom floor. Is it an early 67 with the pointed front bumper and slash in rear?
TJ
amishman wrote: |
TJ |
BarryL Samba Member
Posted: Thu Apr 14, 2022 1:39 pm Post subject: Re: What did you do for your Bus today? |
Decided to discover why there was always a drip at my oil cover and my pressure relief fitting. While changing oil, torquing the heads' bottom row and a valve adjust I examined the two items.
The oil relief had a crush washer that didn't seal well againt pits.
I talked to Paradise VW Motorsports and Jason gave me his latest fix.
Solid new on the left with wimpy crush on the right.
I found a better way to tighten the fitting using a hard washer. Also discovered the pressure spring rides against the plunger instead of inside. I always assumed the spring was inside.
My old oil cover on the left had a slope to the stamping thus not allowing the acorn nuts to sit square against the cover. New flat shaped cover on the right with better drain plug seal and acorn nuts sit perfectly square.
After many test miles and hot oil the two items seem to not drip at all.
Mundane I know but a happiness maker for me. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Apr 14, 2022 2:02 pm Post subject: Re: What did you do for your Bus today? |
You might confusing the '65 with a pointed rear and slash front.
66-67 never had slash bumpers. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
