Larmo63 Samba Member
Posted: Thu Sep 22, 2022 6:27 pm Post subject: Re: What did you do for your Bus today? |
Rebuilt my headlights with euro lenses (I like them, I know) and finally got the bumpers on after three tries. My painter struggled with bad hardener, he had to strip them twice.
Im having fun with this thing. Next is a humpback cover from Corey and new interior panels.
Im hoping to have most of what I intend to do to done by OCTO.
_________________ Lawrence
61 Mango Green Single Cab
'62 Pearl White Ragtop sedan
'66 Ruby Red Cabriolet
'86 Porsche 911 Carrera
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Thu Sep 22, 2022 6:41 pm Post subject: Re: What did you do for your Bus today? |
Wowie...that thing just glistens. |
Posted: Sun Sep 25, 2022 8:39 pm Post subject: Re: What did you do for your Bus today? |
Interior panels from WW:
'86 Porsche 911 Carrera |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2210 Location: UK (South)
Posted: Mon Sep 26, 2022 11:00 am Post subject: Re: What did you do for your Bus today? |
Broke the clutch cable.
Bought a new clutch cable.
Fitted the new clutch cable.
I only went out for a 15 minute run round the block. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Daddybus Samba Member
Posted: Wed Sep 28, 2022 11:07 am Post subject: Re: What did you do for your Bus today? |
Bus went dead with electrical issue. Pulled the Summit Racing CD ignition box, PerTronix module, Summit Racing ignition coil for ignition box and went back to stock...Blue coil, points & condenser. Dumped the oil pressure safety switch in favor of an inertia switch. Less electronics to go bad. Less wiring. Easier to diagnose and fix. Less headaches. |
mdege Samba Member
Joined: January 16, 2018 Posts: 939 Location: Niederkruechten, Germany
Posted: Sun Oct 02, 2022 10:57 pm Post subject: Re: What did you do for your Bus today? |
I switched back to the old original fuse box on mine.
My headlights were randomly going out. I noticed, the fuses didn't have proper contact any more. The reason behind it is, that the tabs gut hot and the fuse box plastic started melting.
The new fuse boxes are made of plastic and that melts. The old ones are made of Bakelite and they don't have that issue.
As with most parts it is better to stick with the original stuff. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
Posted: Tue Oct 11, 2022 10:06 pm Post subject: Re: What did you do for your Bus today? |
Installed Coreys humpback seat covers today
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 246 Location: Cambridge UK
Posted: Sun Oct 16, 2022 2:13 pm Post subject: Re: What did you do for your Bus today? |
Made some progress on my D pillar:
Easy part:
Tricky part:
Sliced:
Filler piece:
Filler piece wedged in:
Welded to the rest of the bracket:
Painted with bonda:
Clamped up the inner D panel with the engine web bracket:
Pau Samba Member
Joined: April 09, 2002 Posts: 341 Location: Euskal Herria
Posted: Wed Oct 19, 2022 3:13 pm Post subject: Re: What did you do for your Bus today? |
I picked it up yesterday from reduction seals changing and today it had new 205/70 tires. I know it is not stock, but few things are in this Westy. I like them...
_________________ Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!! |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Wed Oct 19, 2022 5:02 pm Post subject: Re: What did you do for your Bus today? |
Pau wrote: |
Looks great! The tires look like a perfect fit. It appears the cat is checking the lugnuts for you too _________________ Brandon |
Pau Samba Member
Posted: Wed Oct 19, 2022 11:59 pm Post subject: Re: What did you do for your Bus today? |
Thank you. I was affraid about bigger tires when turning. But it passes very, very well. We will see in mountain when passing big holes or "stones".
It was the first meet between Turbo (the cat) and the Westy. It is funny because he passed a lot of time inspecting this wheel. It was loose when they changed tires and they had to tighten it again... The 6th sens of cats?
Have a nice day! _________________ Freedom for the Catalan Countries
GRIFF55 Samba Member
Joined: September 06, 2008 Posts: 33 Location: SO. CAL
Posted: Sat Oct 22, 2022 8:02 pm Post subject: Re: What did you do for your Bus today? |
Picking my 55 double door from Washburns. _________________ Always giving 100% 10% at a time. |
Pau Samba Member
Posted: Sun Oct 23, 2022 2:01 pm Post subject: Re: What did you do for your Bus today? |
Sorry for posting little things I do on my bus. Maybe not as interesting as some marvelous skills most of you do have (congrats and RESPECT!)
I put new Zanetti mirrors. They are against dead angle. They're plastic, I thought they were going to fit horrible; they are ugly but they give security and confort compared with little round instable repro's. Don't blame on me. I only drove 21windows until now
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Sun Oct 23, 2022 8:58 pm Post subject: Re: What did you do for your Bus today? |
Interesting mirrors, I kinda like them. I wonder how they would look if the narrow end was pointed out, or down? _________________ nothing |
Posted: Mon Oct 24, 2022 5:26 am Post subject: Re: What did you do for your Bus today? |
Flipped the canopy slats over. Glad I followed the advice on Dropgates.com and chamfered the ends so they could be turned periodically. They'd really sagged, particularly where there are knots in the timber. Much straighter now..
And I made a dash tray mat out of foam fabric. I'm amazed at how much quieter it's made driving. Everything on that tray rattled over every bump.
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Sun Nov 13, 2022 11:23 am Post subject: Re: What did you do for your Bus today? |
re thread a beaten RG
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Colorado Bulli Samba Member
Joined: April 16, 2012 Posts: 107 Location: Western Slope, Colorado
Posted: Tue Nov 15, 2022 2:03 pm Post subject: Re: What did you do for your Bus today? |
Completed my first complete replace/rebuild of the braking system on my 56!! _________________ 1956 Standard
1964 Beetle |
BarryL Samba Member
Posted: Tue Nov 15, 2022 7:14 pm Post subject: Re: What did you do for your Bus today? |
perello wrote: |
re thread a beaten RG |
How did you build it up before cutting. What all was wrong? |
Posted: Wed Nov 16, 2022 2:39 am Post subject: Re: What did you do for your Bus today? |
it was mushroomed
so I needed to first do some facing to get the correct geometry to start threading. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
a smith Samba Member
Joined: October 01, 2008 Posts: 189 Location: Medford, Or
Posted: Wed Nov 16, 2022 7:45 am Post subject: Re: What did you do for your Bus today? |
perello wrote: |
it was mushroomed
so I needed to first do some facing to get the correct geometry to start threading. |
WOW! It looks to have partially collapsed the hole for the pin as well. Sledge hammer do that? I can't imagine a puller doing it but stranger things have happened. |
