LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Feb 20, 2023 5:56 am Post subject: Re: What did you do for your Bus today? |
Bill can you explain that proper tool as I see an Allen screw/bolt he is adjusting.
BulliBill wrote: |
LAGrunthaner wrote: |
Nice job madmanvan, on both valve adjustment and video. How did you start & stop the video with greasy hands?
madmanvan wrote: |
Adjusted the valves - and completed week five of BusLust - my goal to shoot a weekly video in my '67.
I agree with Linda! Nice job on the video, I would recommend it for viewing, especially to folks new to VWs and tuning them. A lot of people learn visually. About the only suggestions I would have for newbies is explaining that most of them will need a proper sized screwdriver to adjust the threaded valve adjusting screw and not a Allen tool. And it appears that your fan belt is fairly loose. How to correct that could be the topic of your new great how-to video! Thanks for posting your video for others!
Bill |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Colorado Bulli Samba Member
Joined: April 16, 2012 Posts: 107 Location: Western Slope, Colorado
Posted: Tue Feb 21, 2023 10:07 am Post subject: Re: What did you do for your Bus today? |
BulliBill wrote: |
Colorado Bulli wrote: |
While not a big deal to most, I completed my first complete brake job. Made a couple novice mistakes along the way but nothing major.
The Schwaben pressurized brake bleeder was the best 60 bucks I've spent in a long time. perfect bleed first shot, 10 minutes max! |
Congrats on your brake rebuild! It's really nice to hear that you are happy with using the Schwaben pressurized brake bleeder. Can you detail it's use a bit more? Any leaks, messes and how to avoid them? Any tips for use on a Type 2 Bus? I bought one a year or two ago, but I still haven't used it yet! Thanks for any more suggestions/tips on it's use...
Bill |
Thanks Bill! Funny thing is I read in another thread where you had replied about purchasing this product. I was like "this guy knows his shit!" which is why I picked it up!! As I stated previously the "deluxe" cap had a thicker washer which did need to be tightened heavily (pretty much as tight as I could go by hand) to prevent leaks. a couple of scraped knuckles from the bottom of the floor an taking the cap back off, but everything else worked incredibly well. 18 PSI and it worked as easy as the videos.
D- _________________ 1956 Standard
1964 Beetle |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Tue Feb 21, 2023 5:13 pm Post subject: Re: What did you do for your Bus today? |
I installed new tie rods and a steering damper in my 66 today.
I would have installed a new drag link, however, my first and last order from
"All the wrong parts your car would never need"
they sent me a 66-68 beetle tie rod instead of a drag link. Their return policy isn't worth the savings of the parts. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Thu Mar 09, 2023 1:31 pm Post subject: Re: What did you do for your Bus today? |
Back home after having the Link pins & King pins done on the '66, can't wait to hit the bumpy back roads!! _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 717 Location: Laguna Hills, Ca
Posted: Tue Mar 14, 2023 3:06 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
When will you show your engine build? |
Barry,
Because you asked...While not "today" here is what I recently did for my bus:
As the story goes, I had a sunk valve seat at the exhaust #3, no room to adjust my valves...so I started down the merry road of replacing my heads.
Had all the parts delivered, and was about to re-assemble (with some tutelage from Dan aka Braukuche)...when he noticed this:
He said "welp this engine is coming apart today"...
While the engine was apart, I decided to replace everything, except my 69mm crank and case...
Parts
Me building the engine, again under the tutelage of Dan.
Motor went back in, to my surprise, it even started and ran...until:
Out it came again...and I found this:
New cylinder shims:
And back to this:
Moral of the story, make sure you use oil with ZDDP in it, not full synthetic, and break in your cam/lifters correctly, also don't re-use cylinder shims as they are cheap compared to the time and effort it takes to break the engine down again to replace them.
My first build, did I learn a lot, yes, did I make mistakes, yes. Could I have done it without Dan, no.
TheHatch is running strong again, and has been to Havasu and back on this new motor. _________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
mtnbus Samba Member
Posted: Tue Mar 14, 2023 4:46 pm Post subject: Re: What did you do for your Bus today? |
nice work ! |
Daddybus Samba Member
Posted: Mon Apr 03, 2023 2:08 pm Post subject: Re: What did you do for your Bus today? |
This weekend I changes the oil, adjusted the carbs/linkage, installed a front sway bar (stock), and replaced the upper door seal (no more rain drops in side the bus). The seal was probably the one installed in November 1967, so it had to be cut out in segments (PITA). the West Coast Metric replacement seal was a liiiiitttle bit oversize, so I had to open up the channel on the door frame so that I could spend an hour and a half using every muscle fiber in my body to pull the seal through the channel and into position. Now the door sticks shut and is hard to open due to the high quality of the new seal...no water gonna get in through there! (water will just have to get in through the safaris). |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 539 Location: Geneva, Florida
Posted: Mon Apr 03, 2023 2:21 pm Post subject: Re: What did you do for your Bus today? |
installed my flat4 steering wheel yesterday with new red sportgrip 500 wrap. (the color looks a lot darker in this picture than it does in reality. it's a pretty close match to the underside of my OE wheel)
of course, the taper is cut wrong, so it doesnt seat all the way (sits about 1/4" too high). new 813 end mill on the way so I can cut it deeper (thanks chad for the tip).
installed some silver-beige door hardware from WW (pulls and levers)
and installed my ABS cab roof panels (from https://www.thesamba.com/vw/classifieds/detail.php?id=1395327). (just put the original insulation back)
_________________ ...david - '66 SO-44 #231 |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Thu Apr 06, 2023 7:58 pm Post subject: Re: What did you do for your Bus today? |
Found some material at Joann Fabric store that is close enough to mesh gray panels
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
Posted: Sat Apr 15, 2023 4:44 pm Post subject: Re: What did you do for your Bus today? |
today I built a pedal pan out of the twisted approximation that CIP1 sells
Posted: Sat Apr 15, 2023 4:52 pm Post subject: Re: What did you do for your Bus today? |
As I was exiting the parking lot at work, I felt the clutch cable "give" and the clutch pedal drop to half travel. I knew the cable was giving out, so I nursed the daddybus home (20 miles). I took the next day off to fix it (new cable and bowden tube).
I proved that "clutch arm" is one of them multiple meaning words.
Posted: Sat Apr 15, 2023 6:14 pm Post subject: Re: What did you do for your Bus today? |
Daddybus wrote: |
I proved that "clutch arm" is one of them multiple meaning words |
roflmao. I know this meaning well. _________________ ...david - '66 SO-44 #231 |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat Apr 15, 2023 8:16 pm Post subject: Re: What did you do for your Bus today? |
David Raistrick wrote: |
Daddybus wrote: |
roflmao. I know this meaning well. |
Same here. We nee done more elbow for that job. _________________ nothing |
Posted: Thu Apr 27, 2023 3:13 pm Post subject: Re: What did you do for your Bus today? |
Take pics of it
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Thu Apr 27, 2023 6:45 pm Post subject: Re: What did you do for your Bus today? |
Got rid of the Interstate MX-47/H5 Flooded Lead/Acid 12 volt battery in my '67 and put in an Interstate MTX-47/H5 Absorbed Glass Mat 12 volt battery.
These batteries have the correct mating flange for the battery tray.
The AGM is heavier. |
Posted: Thu Apr 27, 2023 7:54 pm Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
These batteries have the correct mating flange for the battery tray. |
...you late model guys and your battery clamps.....
btw, a group 51 fits nicely under the strap with tons of room to spare but tight. don't ask how I know.
Stocknazi Samba Member
Posted: Fri Apr 28, 2023 9:03 am Post subject: Re: What did you do for your Bus today? |
turbo_g wrote: |
Moral of the story, make sure you use oil with ZDDP in it, not full synthetic, and break in your cam/lifters correctly, also don't re-use cylinder shims as they are cheap compared to the time and effort it takes to break the engine down again to replace them. |
Check out this blog: https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Zinc/phosphorous are not the only elements to consider when choosing the correct oil. For an air-cooled engine PSI sheer strength and the performance of the oil under high heat conditions are much more important.
I have been a die-hard user of Shell Rotella-T 15W-40 and Castrol GTX 20W-50 for years. VERY disappointed with the performance of the old and new variants of Shell Rotell-T. I don't think I'll be using it anymore.
Castrol GTX preformed well in all weights: 20W-50 being only slightly better in sheer strength.
Valvoline TR1 preformed better and is also a good choice. It's very surprising that MANY expensive/racing/brand name oils preformed poorly compared to cheaper alternatives. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Fri Apr 28, 2023 10:32 am Post subject: Re: What did you do for your Bus today? |
StockNazi wrote: |
turbo_g wrote: |
Valvoline TR1 preformed better and is also a good choice. It's very surprising that MANY expensive/racing/brand name oils preformed poorly compared to cheaper alternatives. |
Not wanting to turn this into an oil debate thread, just curious how you are determining the oil's performance. Independent lab testing? _________________ nothing |
aa390392 Samba Member
Posted: Fri Apr 28, 2023 11:50 am Post subject: Re: What did you do for your Bus today? |
CD., there is a Midwest guy on YouTube that tests all sorts of things, try him, I enjoyed his test methods. Oils, polishes, tools, etc
YouTube
PF Farms. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
