limited slip differential
Page: 1, 2, 3  Next
sathing
sathing is offline
PostPosted: Mon May 28, 2007 1:03 am    Post subject: limited slip differential Reply with quote
I have read somewhere that some Things came out with a limited slip differential. Are there any markings or perhaps a number on the casing I could check, to tell if my thing has a limited slip differential?
pjmacua
pjmacua is offline
PostPosted: Tue May 29, 2007 2:25 am    Post subject: Reply with quote
Hello
This option (limited slip differential - M220) was not available for the Thing (US market).
You can check if your transaxle has the special filler plug (that warns the mechanic to use special oil).
The transaxle codes for the limited slip differentials are :
- swing axle : AL
- IRS : AW or GB
You can put the car on jacks, turn one wheel (transaxle in neutral). If the other wheel turns the same way, your car has an LSD.
If it turns the opposite way, your car has an regular (open) differential.
Regards
Pierre-J MACUA
sathing
sathing is offline
PostPosted: Tue May 29, 2007 3:42 am    Post subject: Reply with quote
Hi,
Thank you for your comprehensive answer. I’ll put the car on jacks this weekend and do the “wheel-turn test”. Will let you know how it turns out.
Thanks
GregZA
GregZA is offline
PostPosted: Wed May 30, 2007 1:15 pm    Post subject: Reply with quote
En toe?
Ian Epperson
Ian Epperson is offline
PostPosted: Wed May 30, 2007 1:24 pm    Post subject: Reply with quote
Just talked to a transmission shop yesterday and asked about an LSD. The only one they can get is the Quaiffe for $1400!! From what I've read, a Quaiffe is a great diff - less good than a ZF offroad, but the flat-out best diff on road.
sathing
sathing is offline
PostPosted: Sat Jun 02, 2007 3:52 am    Post subject: Reply with quote
GregZA Ja, inderdaad toe ʼn beperkte glip differensiaal Wink
Hello all,
I did the “wheel turn test” as described by Pierre-J and yes it is a LSD. I just whished I had known this three weeks ago when I topped up the transmission oil with standard gear lube (HP 80W-90). I added about 1 liter gear lube.
Pierre-J mentioned in his post that the LSD uses special oil. Does anyone have an idea what oil should be used? What is the best way to rectify my current mess, will it be ok to just drain the current oil and then replace it or should I also flush out the differential before adding new oil?
GregZA
GregZA is offline
PostPosted: Sat Jun 02, 2007 4:18 am    Post subject: Reply with quote
The only manual I have specifically for European 181's with reduction boxes is the Intereurope # 157.
It says:
Transmission Capacity 2.5 litres
Reduction Gears Capacity 0.25 litres
Recommended lubricant Hypoy Transmission Oil SAE 80/90 (MIL-L-2105 B)
So in my little world you have used the correct oil unless Pierre-J has more info for us from the horses mouth so to speak.
The manual also covers the LSD so I always assumed this to be the correct specification.
Cheers
sathing
sathing is offline
PostPosted: Sat Jun 02, 2007 10:33 am    Post subject: Reply with quote
Thanx Greg, I’ll sleep a tad better tonight.
pjmacua
pjmacua is offline
PostPosted: Sat Jun 02, 2007 1:35 pm    Post subject: Reply with quote
Hello
The oil is specific : FORD M2C28B
Look here :
http://www.181spirit.com/menu/technique_fichiers/differentiel_ZF/ZF_SA_01.jpg
or here
http://www.181spirit.com/menu/technique_fichiers/differentiel_ZF/ZF_IRS_01.jpg
Sorry, text is in french.
I personally use Elf Tranself BLS 90. You can use some others specific oils or add additives to your regular oil.
Regards
Pierre-J MACUA
GregZA
GregZA is offline
PostPosted: Sat Jun 02, 2007 3:39 pm    Post subject: Reply with quote
We deal with Castrol/BP I'll ask them to check what the Ford spec translates to on monday and report back when I hear from them.
kubelmann
kubelmann is offline
PostPosted: Sat Jun 02, 2007 6:27 pm    Post subject: Reply with quote
I have a Quaffe diff in my Thing and I run Swepco 201... 80/90
GregZA
GregZA is offline
PostPosted: Mon Jun 04, 2007 9:49 am    Post subject: Reply with quote
No reply yet from Castrol, I will follow up with them again tomorrow.
kubelmann
PostPosted: Mon Jun 04, 2007 11:20 am    Post subject: Reply with quote
I have run Castrol 80/90 GL-5 in a stock VW trans with open diff with no troubles. That is one of the products that VW used to fill VW transaxles with.
Ian Epperson
PostPosted: Mon Jun 04, 2007 11:26 am    Post subject: Reply with quote
Can you write about that a bit? Do you notice a big difference? How is it in the dirt?
Basically, is it worth the $1400?
kubelmann
PostPosted: Mon Jun 04, 2007 11:45 am    Post subject: Reply with quote
I love it and anybody who ride in the dirts comments about wanting one. I got a nearly brand new unit from a mini sprint hill climb race that blew the engine after under 75 miles. They guy was way hard up for money (it was just after race season) and had it out of the trans and cleaned. He needed $300 asap, I had $300. Having run it, if I had the $1400 in the budget, I would get another one in a second. It is totally fun to blow dual rooster tails over the front of the body. I get major traction in the dirt and do not suffer from the overpowered rear end but do have to back off and steer out of some major fish tails. Push the gas and my Thing moves regardless of terrain. I have a 1915 with dual Dell 36 mild cam 9.51:1 compression and a custom built (using all Weddle parts) trans with all the tricks close 3rd adn fourth and so on. 4 wheel disc brakes very tweaked suspension. The differential is the icing on the cake of the set up. I run BFG AT KO 235 75 15 on Centerline wheels in the rear and Dominator 205 75 15 in front ..
GregZA
GregZA is offline
PostPosted: Tue Jun 05, 2007 1:21 am    Post subject: Reply with quote
According to Castrols' technical department the Ford code M2C28B relates to a GL5 90 oil.
Their product that meets this specification is EPX SAE 90.
kubelmann
PostPosted: Tue Jun 05, 2007 8:30 am    Post subject: Reply with quote
I looked at a bottle of Castrol 80/90 Gl-5 in my shop and it says right on the bottle. contains limited slip differential additive.
GregZA
GregZA is offline
PostPosted: Tue Jun 05, 2007 2:30 pm    Post subject: Reply with quote
I think maybe the biggie is that it is GL5, quite a few European Ford manual transmissions require a GL5 oil and Ford normally uses straight 90 in these cases, but people have been using the GL5 80/90 for years with no noticeable problems.
Bruce
Bruce is offline
PostPosted: Wed Jun 06, 2007 11:26 am    Post subject: Reply with quote
sathing: What is the trans code on your T181? (or is it a 182?)
Ian, I can set you up with a genuine VW ZF for almost half the price of a Q. Send me a message.
Oil: Read the label. If it says no additive necessary, use it. If it says compatible with LSDs, you need the additive. In the USA, every Chevrolet dealer sells a small bottle (150ml) of LSD additive. In other countries, your local auto parts stores should have an equivalent product.
I highly recommend synthetic gear oil, 75W-90, and it must be GL-5 to get you the superior extreme pressure additives to protect your spider gears and side gears. DO NOT USE GL-4!
sathing
sathing is offline
PostPosted: Wed Jun 06, 2007 11:46 pm    Post subject: Reply with quote
Hello Bruce,
I’m not sure where to look for the trans codes, but to answer your question, yes it is a 182. (I posted a pic of my thing in the Roll Call section on 23 May 07)
If you could perhaps point me to where the trans codes are located, I’ll get those to you if you are interested.
Page: 1, 2, 3  Next
