Coolant Bleeding the No Stress, No Mess Way!
?Waldo?
?Waldo? is offline
PostPosted: Sat Jan 26, 2008 7:38 pm    Post subject: Re: Maybe I'm missing something? Reply with quote
funagon wrote:
I've read your description twice. Correct me if I'm wrong, but I think I've achieved the same effect by jacking up the rear of the van until coolant reservoir is at least as high as the radiator bleed bolt.
You are not wrong. You achieved the same effect. I have actually done the same by parking nose down on a very steep driveway at my last house. Certainly it is much easier to attach the bleeder tube than it is to jack the rear of the van up in the air. Actually it's easier to attach the bleeder than it is to move the van to an inclined parking space even.
Terry, you're right. It is limited. But, it works well and is incredibly cheap and easy to make. I imagine I'll make a pressure tester at some point as well, when the need arises. For now, I'm happy with using this tool.
Andrew
HIGHEST QUALITY M-TDI PUMPS FOR SALE. PM for details.
tencentlife
tencentlife is offline
PostPosted: Sun Jan 27, 2008 8:43 am    Post subject: Reply with quote
I used the Libby pipe method
I hereby dub this device, "The Libby Bong".
See innovative Vanagon accessories at the Vanistan shop:
Hmmm, provincial much?:
"I wouldn't go much on whats written on the samba, they love a "theory" and rarely ask any Europeans what is actually correct."
hiram6
hiram6 is offline
PostPosted: Mon Jan 28, 2008 11:13 am    Post subject: Reply with quote
Built mine this morning.
Grand total for the parts from the Home Depot: $7.34
Rare that I get out of HD for less than $50!!! Very Happy
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
smg1021
smg1021 is offline
PostPosted: Mon Jan 28, 2008 3:48 pm    Post subject: Libby Bong Reply with quote
Sweet!!! I also have a question, I am glad I came by this, I to will build one it looks slick easy and yes a GREAT CONVERSATION PIECE. I was wondering, I replaced the head gasket and seals last summer, now I have water leaking out of the top two head stud on the left side. I suspected that I should have replace the heads as I saw pitting and it was not good. ( no money at the time) I was looking at the breakdown in the big green book, and saw nothing about samll o-rings etc.In the stud areas I reused the heads and nuts on both sides. I am now getting ready to replace the heads here in a couple of weeks. Am I missing something? Confused please help
BoneStock67
BoneStock67 is offline
PostPosted: Sun Feb 03, 2008 10:19 pm    Post subject: Reply with quote
Today I used my Libby bong for the first time, and it definitely got the job done quickly and easily. My only issue was a little bit of coolant leakage at the seal between the bottom of the PlumbQwik connector and the mouth of the expansion tank, but perhaps I was trying to seal against the cap threads. Next time I'll pay more attention to where on the tank mouth I'm tightening the PlumbQwik hose clamp.
1986 Wolfsburg Westfalia Weekender 2.1L stock
1967 Beetle, now becoming my daily driver again, after a long rest in the garage
"There are two possible outcomes: if the result confirms the hypothesis, then you've made a measurement. If the result is contrary to the hypothesis, then you've made a discovery. -Enrico Fermi
Terry Kay
Banned
Terry Kay is offline
PostPosted: Mon Feb 04, 2008 7:05 am    Post subject: Re: Libby Bong Reply with quote
<< I replaced the head gasket and seals last summer, now I have water leaking out of the top two head stud on the left side. I suspected that I should have replace the heads as I saw pitting and it was not good. ( no money at the time) I was looking at the breakdown in the big green book, and saw nothing about samll o-rings etc.In the stud areas I reused the heads and nuts on both sides.>>
Sounds like you forgot to lay a bead of the head gasket sealer on the studs.
You can re-use the head nuts with no problems, as long as you have the sealer on the threads of the studs where they meet the head.
Next round use GM engine assembly sealer pt. # 1234 6141, & you'll never have any engine leaks --anywhere.
T.K.
need2boat
need2boat is offline
PostPosted: Sat Mar 08, 2008 8:23 am    Post subject: pressure bleeder Reply with quote
I saw this idea on the VanagonSubie list and thought I would pass it on as another idea. Like many others I've already got a pressure pot sitting around doing nothing along with an old tank cap.
This is a quote from Jeff who posted it:
"I just bled my 2.2 last week after replacing the radiator and had great
success using a $14.99 pesticide sprayer from the hardware store. I
adapted the hose to an old burp tank cap which I removed the valve from
by prying it out with a narrow flathead screw driver. Then I filled the
sprayer with coolant, hooked it to the burp tank (via old cap) and
pressurized the system. I didn't use much, but since I didn't have a
gauge in the system I can't be sure. I'm pretty sure it was way under
20lbs. Anyways, I filled this way and was able to easily bleed the
system solo. Best bleed job I've had yet. BTW, I filled the system
with the backend elevated as full as I could prior to going with the
pressure..."
1987 Syncro Adventurewagen: Vincent Van-Go
1998 SAAB 900 SE Coupe: Black Swan
msinabottle
msinabottle is offline
PostPosted: Sat Mar 08, 2008 1:02 pm    Post subject: Interesting! Reply with quote
What's interesting about this gadget is that it's almost identical to the brake pressurizing system I use when I bleed Winston's hydraulic system.
I imagine you need to open the radiator bleed screw before you start pressurizing... And that you'd want to get in as much as you can normally, first.
I'm wondering now about making a second hose for my brake system pressuirizer ending in the altered pressure tank cap and using the sprayer/bump for both uses--after a lot of careful cleaning, of course!
The 'Hookah' gadget that started this thread looks brilliant, and has been used with a lot of success--but I've already MADE the sprayer/pressurizer.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
blackglasspirate
blackglasspirate is offline
PostPosted: Thu Apr 24, 2008 9:30 am    Post subject: Reply with quote
So I gave this a try today and had a few questions, try and hang with me here.
I've known for months that I needed to bleed the air out of my coolant system. The other day I was driving and noticed the coolant temp was kind of high(3/4 up) and wondered if it could be because it needed to be bled(it was also the hottest day of the year so far).
I got everything together and started, trying to follow the directions to the T. The only thing is that there is no spot on my property where I can get my van level, so I parked nose down.
After I started the van, I noticed a lot of air bubbles coming into the tank and up through the bong-gadget. I proceeded to follow the directions, open radiator, rev, close, etc.
Well, most of the time, it seemed that instead of the level of coolant in the contraption going down, it kept going up. Is that normal? The final one or two times it went down a little. I wasn't sure if I was doing something wrong.
One other thing to note is that the coolant I got back out of the gadget was a lot darker than when it was put it, does that mean something is dirty?
I planne don taking a 300 mile trip tomorrow, but now I'm kind of iffy.
Thanks for the help.
'87 Vanagon GL Westfalia
IG: @holidayatsee
FB: https://www.facebook.com/holidayatsee
need2boat
PostPosted: Thu Apr 24, 2008 11:25 am    Post subject: Reply with quote
One other thing to note is that the coolant I got back out of the gadget was a lot darker than when it was put it, does that mean something is dirty.
Two things come to mine. You don't need to this setup to bleed a system with a small amount of air. You better off just topping off the level in the tank when it's cold. jacking up the front end starting the van, running it at around 2K (heaters on high) then opening the bleeder, letting it bleed till you see bubbles coolant coming out. Then closing the bleeder. You should do this a few times till the air is all out.
You want to do this quickly so the van doesn't get hot. If it does and you have the top off the tank it will start to fill up. This sounds like what was happening.
The issue of the dirty coolant could be a type of leak that's allowing oil into the coolant? do you see oil mixed in it? If so, you should check the system for leaks. You shouldn't be bleeding the system that much if everything it working OK.
JFF
blackglasspirate
PostPosted: Thu Apr 24, 2008 12:56 pm    Post subject: Reply with quote
I will try topping it off when cold and bleeding it. Right now I think I've gotten just about all the air out of it, but I think there still may be some.
As far as it being dirty, I'm not sure how it got like that but I'm pretty sure I don't have any leaks. I don't know if it's oil or not, but I guess that would make sense, since it seems slightly blacker. I'll try checking, but I haven't noticed any small puddles underneath or anything.
With the temp gauge going kind of high, should I risk a 300 mile trip? Or do you think it's too close to overheating or something?
IG: @holidayatsee
Last edited by blackglasspirate on Thu Apr 24, 2008 12:57 pm; edited 1 time in total
?Waldo?
?Waldo? is offline
PostPosted: Thu Apr 24, 2008 12:57 pm    Post subject: Reply with quote
As the coolant gets hotter it will expand and cause the level to rise.
Andrew
floggingmolly
floggingmolly is offline
PostPosted: Wed Jun 18, 2008 6:47 pm    Post subject: Reply with quote
Another satisfied customer, worked like a charm.
Actually the principle is quite simple, a matter of hydraulic head. Get the level of the coolant above the bleeder on the radiator and that's it. A few taps on the gas and you're good. Just don't be lazy like me and not install the small tube. Siphoning the coolant out of the bong is a drag, tastes like crap. I got about 3.5 gallons out during the removal, so all seems good. I was a little low.
'85 Wolfsburg Weekender
?Waldo?
?Waldo? is offline
PostPosted: Thu Jun 19, 2008 7:55 am    Post subject: Reply with quote
But wait, I installed the smaller tube because I'm lazy. Laughing
Andrew
woggs1
woggs1 is offline
PostPosted: Sat Mar 07, 2009 1:49 pm    Post subject: Reply with quote
I am going to try the Libby Bong today. Wish me luck.
4 speed 88 Westy
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sat Mar 07, 2009 1:56 pm    Post subject: Reply with quote
I will do more than wish you luck.
My experience as a newb to the Libby Bong, was that I made the mistake of revving the engine with bong too full. It back splashed out the top a little. Otherwise worked like a hot damn. Just an FYI.
Good luck! Smile
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
Pascal
Pascal is offline
PostPosted: Sun Mar 08, 2009 5:06 am    Post subject: Reply with quote
Same thing happend to me exept the who bong poped off...I got an instant steam bath. Shocked Next time I use it Iwill try to midify the bong so that the top is supported/suspended somewaht to prevent it from falling over.
Another problem I had was I could not get a good seal between expansion tank and the bong. It kept weeping coolant there so I put a few wraps of electrical tap on the threads of the expansion tank to get a better seal. Works great now.
'84 Westy - 2.2wbx
'91 EA Cabby
insyncro
Banned
insyncro is offline
PostPosted: Sun Mar 08, 2009 7:19 am    Post subject: Reply with quote
I use the same parts Terry K is talking about.
Very simple to use and never had a issue with air in cooloing system.
dylan
Terry Kay
Banned
PostPosted: Sun Mar 08, 2009 9:17 am    Post subject: Reply with quote
The pressure tester bleed set up is easy, fast, and fool proof--plus you have the pressure tester to locate any leaks in the system quick if they ever happen.
However, I'll have to say that I do like the looks of the garden sprayer set up too.
It's the same pressure bleed theory--will work plenty quick, and there is a couple of gallon reservour of anti freeze to work with---neat idea.
The only addition to this idea would be to put a pressure gauge of some sort on the tank--
I don't know that I'd be wanting to over pressurize the antique cooling system to 20-30 psi.
Ka-Bang.
I don't pump up any mre than 15 psi on the pressure tester to bleed the syetm.
I also don't think I'd be using the same sprayer for the brake pressure bleed & the antifreeze bleed in Winston .
I know , your going to clean it out good.
It's the one "Oops" that worries me--
T.K.
Wildthings
Wildthings is offline
PostPosted: Sun Mar 08, 2009 9:41 am    Post subject: Reply with quote
One could easily make a gravity fill device that connected to the nipple on the pressure cap. Just have a gallon jug that you could hang from the top of the door frame and run a hose from the bottom of the jug to the pressure cap nipple. Should work just fine and a valve in the line would cut out the mess when you disconnect it.
Page 2 of 9
