r39o Samba Polizei
Posted: Thu May 31, 2007 9:47 am Post subject: |
kayakwesty wrote: |
front kit is a straight bolt up kit, it mounts behind the glove box and ties into the refrig system with "t" fittings.
he even has a bigger rear unit for our westy's ! ! ! |
CO$T????? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
kayakwesty Samba Member
Joined: February 15, 2007 Posts: 687 Location: East Tennessee
Posted: Thu May 31, 2007 10:03 am Post subject: |
$ 850.00 for the small front unit
$1050 for the bigger front unit
$1050 for the bigger back unit
includes all fittings, hoses, mounts, vents, and evap unit with instructions, and it is made for the Vanagon |
Posted: Thu May 31, 2007 11:21 am Post subject: european cooler air |
My 85 westy had pre-existing, non-functional air. I bought an entire AC system from Jerry at European Cooler Air. Including: new larger parallel flow condensor, new dryer, larger front unit and larger rear unit, and larger compressor, all new ac lines and electrical wiring. The whole kit and Kaboodle.
Installation was done by Bill at Affordable German. Jerry has modified the large rear unit based on the installation to make it easier to install. The large front unit fits, but is a tight fit. But, I didn't lose any glove box space. It is really quite amazing how small the front unit is.
The quality is top notch. This was the first installation for Bill (of this type of AC). So there was a learning curve involved. But Jerry was very helpful along the way, and has modified the back ac unit.
I don't like the center dash vent (that replaces the ash tray). Jerry is working on coming up with a set of vents that fit in the radio hole, and a new radio holder. |
r39o Samba Polizei
Posted: Thu May 31, 2007 1:42 pm Post subject: Re: european cooler air |
[email protected] wrote: |
All well and good, but, since the vents in those units go up why not use that to your advantage?
If you mount a big console on the top of the dash, you can cut out the top of the dash and feed air in there. The console I have in mind is the $75 big one with the fold out table. Many dashes are trashed on the top anywyas. With the console, you can mount gauges, switches, vents and all the happy non-sense. I consider this very DIY, too.
On the radio front there are other options. Basically all revolving on a remotely mounted unit. Of course, you can mount one in the upper console too. All no big deal.
This is my opinion, what's yours? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Thu May 31, 2007 5:35 pm Post subject: Re: european cooler air |
r39o wrote: |
This is my opinion, what's yours? |
I think that is indeed a very good idea, but my only problem with it is that the dash consoles i've seen that you are talking about tend to be made of pretty thin plastic. I certainly haven't seen them all, though... _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
r39o Samba Polizei
Posted: Thu May 31, 2007 7:26 pm Post subject: Re: european cooler air |
wbx wrote: |
r39o wrote: |
I think that is indeed a very good idea, but my only problem with it is that the dash consoles i've seen that you are talking about tend to be made of pretty thin plastic. I certainly haven't seen them all, though... |
http://secure.mycart.net/catalogs/catalog.asp?prodid=4757900&showprevnext=1 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
usedcarr Samba Member
Joined: May 04, 2006 Posts: 67 Location: Calabasas CA
Posted: Thu May 31, 2007 11:33 pm Post subject: |
kayakwesty, I may have missed it, do you already have AC or are you totally retrofitting your van? I had talked to Jerry about a van I wanted and it was close to 4 grand to retrofit an 82 w/ a Subie conversion. I would have bought it at the prices you quote there. _________________ 10'0" Lance Carson
6'3" Hamisch Fish
Schwinn Beach Cruiser
Sold the westy, never even drove it |
Posted: Fri Jun 01, 2007 5:31 am Post subject: |
I have existing air and it works good...not great...I'm tired of the back of my head getting cold and my face cooking
I want more cold air in the front _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/ |
Posted: Fri Jun 01, 2007 6:41 am Post subject: Re: european cooler air |
[quote="r39o"]
hmmm.. didn't know these existed. Would hate to cover up my new pretty black dash. Had the old cracked brown swapped out during the AC install.
driving up to sequioa soon (after the new engine goes in hopefully). the road trip will give me a chance to feel it out..... |
roadguy Samba Member
Joined: December 15, 2005 Posts: 21 Location: Ponca City, OK
Posted: Tue Aug 28, 2007 8:15 pm Post subject: Warning - WWW.Europeancoolcrair.com |
Volks,
My self and another friend have purchased front AC Units from Jerry West at WWW.Europeancoolcrair.com and had him injstall both systems. Neither system, worked for long.
My system went thru three compressors before I gave up. When I went inside the dash to remove the wiring for this unit I found wires with melted insulation and cicuits that were overload and not fused. It was a mess and a diaster wanting to happen. The other syetm does still wrok, but will only blow slightyl cool air when you first recharge it. A short while later the temps rise to just barley cool. Jerry talks a good game but I have yet to see a successful, long term, functioning system instale dor sold by him. I apoligize if someone has been able get one of these systems to work and would really like to undertand the details of how you were successfull.
larry c |
r39o Samba Polizei
Posted: Wed Aug 29, 2007 10:23 pm Post subject: |
Larry,
I am sorry to read this. I called Jerry a few times. He talked like a book. No stopping him. But, he never did send me the information he promised. I never did find out, for example, what it would cost, let alone, the pictures of what it looked like. I gave up.
I have now collected two Behr units and will integrate them into my van when the weather cools down.
No body likes to pay for a job and then it just does not work. Sad. Not only do you have a system that does not work, but you have, what amounts to be, an expensive anchor installed in your van.
Where are you? Maybe some one can fix it for you. There are other good AC places in Texas besides him. San Antonio is the headquarters of Vintage Air (Jay Leno loves these guys) for example. http://www.vintageair.com/
Best of luck.
-Walt _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
dr. no Samba Member
Joined: August 06, 2004 Posts: 578 Location: Santa Fe
Posted: Thu Aug 30, 2007 6:15 am Post subject: |
I will try to get a picute of mine this afternoon; along with more of the story... _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
Tomswesty Samba Member
Joined: July 06, 2005 Posts: 194 Location: Moscow, ID
Posted: Thu Aug 30, 2007 6:49 am Post subject: |
This is a post by someone over on the suby conversion group about european. Just thought it would help too.
""I've posted this before, but for anyone new on the list I want to
reiterate the problems I have had with europeancoolerair.com (Jerry
West) and his installation of dual a.c. system in my '85 Subie-
Westy. Avoid this guy at all costs! I have spent an embarrassing
amount of money trying to a.c. my bus and am about to give up. When
he put the system in (using Freeze 12) it worked beautifully for a
couple of weeks back in early 2005. Since then I have gone back to
him (from Santa Fe to Dallas) once and had it worked on by others
twice. No one in New Mexico would work with the Freeze-12 so it is
converted to R-134 now.
I charged it up before a recent trip across country and back and
when driving in roughly 100 degree temps the temp in the bus is over
90. So I get "coolish" air, but not enough to provide any real
relief - only sweat!
I have recently seen some of the under-dash wiring that was done by
Jerry on another Westy - fried to a crisp, bare wire showing, and no
fuses! More on that later.
Maggie
'85 Subaru-Westy "Anne Bonney""" _________________ 87 Westy
2.2L Suby convert |
r39o Samba Polizei
Posted: Thu Aug 30, 2007 10:53 am Post subject: |
FYI: D&S in Costa Mesa California has made dual systems for Vanagons. Works just fine. No BS place. But, you do get what you pay for and it is not cheap.
He will make my system work after I prep it for him. I do not want to pay the big bux for him to do the tedious parts that any some what handy person can do.
D&S Auto Air
1661 Superior Ave # D
Costa Mesa, CA 92627
(949) 645-7802
(714) 835-3666 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
westy81 Samba Member
Joined: July 07, 2007 Posts: 141 Location: Irvine, California
Posted: Fri Aug 31, 2007 9:44 pm Post subject: |
r39o wrote: |
FYI: D&S in Costa Mesa California has made dual systems for Vanagons. Works just fine. No BS place. But, you do get what you pay for and it is not cheap. |
How much is "not cheap", specifically? |
r39o Samba Polizei
Posted: Sat Sep 01, 2007 3:57 pm Post subject: |
westy81 wrote: |
r39o wrote: |
Call him! His name is Steve.
He quoted me several thousand to do the job, if I supply the basic under dash Behr unit. He would put it all in including all new low leak lines, new compressor and what ever else needed to make it all work.
They are VERY handy there and can fix or make most anything A/C related.
Since I am picky ands somewhat cheap, I will set up all the stuff I can and let him repair the plumbing, clean the system and do what he thinks. But, I will have done the time consuming dash stuff including the custom venting. So he basically would make the system work,. That will save me a lot. But, the exact cost is unknown for that way. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
vwsyncroguy Samba Member
Posted: Sat Sep 01, 2007 7:19 pm Post subject: Behr Install |
I have a Behr unit.
I installed the front evaporator, switches and vent hoses myself.
A local AC shop (San Francisco) still charged me almost $1600 to make the system work....which involved making the custom hoses to tie the Behr system into my factory rear overhead Westy system and install a later model R134 compressor I bought for my Suby 2.2L engine.
System worked well for 2 years before the compressor died. The opinion of another good AC shop was that the first shop did not put in enough compressor oil to compensate for the dissipation throughout all the extra length of hoses in the new system.
There's a very good AC shop in San Diego, called I.C.E. that installs custom front units in Vanagons for about $2000 ....if you already have air in your van.
Warren
Warren C.
Posted: Sat Sep 01, 2007 7:27 pm Post subject: Behr Install |
The Behr unit has a custom made dual center vent that goes in the radio slot with a curved 90 degree plenum behind it and moves the radio to a custom plastic box that mounts vertically onto the front of the heater unit cover. I had to remove my cigarette lighter to get the fat center vent hose in and covered the hole with stick on VW emblem.
That custom radio box is hard to find with a salvaged Behr unit and I don't much like this location anyway since the new radio displays are not meant to be seen from a position that is below the radio face...I can't read the radio display on my particular radio....a Sony....and my remote won't work the radio when lying in the back ...guess line of sight is required for the infra red remote.
I plan to make some kind of a custom mount for the radio that will mount on top of the dashboard.
Warren |
Posted: Sat Sep 01, 2007 7:44 pm Post subject: |
Some points about these front AC units....Behr or otherwise.
They all draw their air supply from under the dashboard....often a very hot place when the van sits in the sun. None of them draw fresh air from outside the van. So the unit must cool down the air that is heated up inside the van. So they take longer to cool down the van than we are used too in modern cars.
They also replace the heater vent ducts from your side vents in the dashboard with the vents for the AC unit...so you have floor heat after installing one...but no heat coming out the dashboard.
I did a bit of "customization of my left vent hoses...both heater and AC....by cutting the thin plastic vent hose with scissors so the hoses would mesh together....kinda in a "Y" shape.....so that the two hoses could be joined together where they hook to the dashboard vent with good duct tape. So I still get some heat out the drivers side vent. With a Behr unit, the big evaporator sits rig ht behind the glovebox and the left vent and connects to the vent with a very short coupling so this is not possible.
Warren |
dr. no Samba Member
Posted: Thu Sep 06, 2007 4:43 pm Post subject: |
Finally, a conjunction of camera and bus:
This is the vent that replaces the ashtray, installed by Jerry. I had no real problems with his install, it was done on time and tucked in neatly. Other than the extra knob for the front unit and the vent itself, nothing shows. Cold air comes out of the two side vents as well. As I remember, these were only fresh air before, not heated. This setup worked well the first two summers, except driving into the sunset, then you are warm.
The next summer it would not come on. At all. I could never find the short in the wiring; Jerry emailed a circuit diagram which did not match what he installed, but insisted that it should. I eventually "wired around" the switch and it again works very well, to the point where (except driving right into the sun) we run it on the lowest setting to stay cool. This is on R-134a without changing all the hoses.
I don't know what the current price is, but 4 years ago I paid $6xx for the conversion/addition. Maybe some customer skills are lacking, but a much better deal than some of those above...[/i] _________________ Scott
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'77 Bay
'71 Bay
'74 Things (2)
'91 Fox |
