Bleyseng Samba Member
Posted: Wed May 30, 2007 8:41 pm Post subject: track covers, how to remove |
77 Westy and I am trying to remove those pestky track covers on the rear of both sides of the bus. Got the two screws removed but they don't budge. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Wed May 30, 2007 8:56 pm Post subject: |
Try to slide it forward a bit (at least sliding door side with slider open). Then tap it up out of the groove.
Does that make sense? _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Posted: Wed May 30, 2007 8:58 pm Post subject: |
I'll try that! _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 30, 2007 9:21 pm Post subject: |
I had to tap mine upwards with a piece of lumber, once they were broken loose they came off ok. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 30, 2007 10:06 pm Post subject: |
got the sliding door side off by tapping it forwards then up.
Do you just tap the other one up?
Pretty rusty on the backside of the covers, darn. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
visibleink Samba Member
Joined: May 03, 2002 Posts: 1668 Location: Austin, Texas
Posted: Wed May 30, 2007 10:07 pm Post subject: |
Should be three screws total, two on the side near the nose of the bus. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
Posted: Thu May 31, 2007 5:59 am Post subject: |
Tapped it up a bit at each end, the rear is tapered so you have to be careful not to nick the paint as it wedges itself in there. Once it's moving tap it forward a bit as it goes up.
Had another bus with more advanced rust that I had to use a piece of 1x4" with the end shaped like a wedge so I could pound from underneath, right beside the upper joint.
Different years have different amounts of screws, the newer it is the less screws. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 31, 2007 8:54 am Post subject: |
yep, tapped off the drivers side straight up to get it off....
now to clean and sand the mess..... _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
